Diesel Glowplugs Problem
Bike Chat Forums Index -> Dear Auntie BCF... Goto page 1, 2, 3  Next
Tracey Suntan-King
PostPosted: 18:20 - 14 Jan 2016    Post subject: Diesel Glowplugs Problem Reply with quote
Can anyone help please? Is my 2011 Subaru Forester boxer diesel kaput?
Two warning lights are on, one for the engine and the other for the Vehicle Dynamics Control. This gives an error code of P1380 at my local Subaru dealers, who don't want the repair job Shocked
This means that one of the glowplugs has gone. Strangely, the car runs fine but I don't feel safe as the ABS And VDC are not active and the hill start function is also inactive. No cruise control either.
Not a lot of info on Google but indications are that replacing a glowplug costs around £425 unless it (glowplug) breaks which can lead to thousands of £.
None of the garages I've enquiried at are ringing me back. If I knew it was definitely going to cost £425 I wouldn't have a problem there appears to be a risk of a much higher bill.
Is it time for a trade in and take the massive hit on value, or repair, or what?
Do glowplugs break easily?
BCF help please!
Thank you
Very Happy There is a ray of hope, Sid has found one of the glowplugs fuses has blown. So it could just be a fuse, but if the replacement blows (we won't get that till tomorrow) it's the plug and back to the problem above. Sad
RhynoCZ
PostPosted: 18:29 - 14 Jan 2016    Post subject: Reply with quote
Glow plugs don't break, just being there. The only time they break is when you force them out. That is the fun part of changing them. If a glow plugs breaks, then it's the head down in 9 out of 10 cases. Thumbs Up Very Happy
The ABS and other systems should not be connected to a glow plug failure. If there is snow where you drive, it is possible the snow covered one of the speed sensors at the wheels, so the system does not know how fast the wheels are spinning, therefore disables the ABS and other systems that are related to the actual speed of the individual wheels.
Even if there is no snow, I'd be checking the sensors and then scale it reads the speed from.
It could also be a faulty ABS pump.
EDIT: https://legacygt.com/forums/showthread.php/got-odd-code-yesterday-p1380-193852.html?
mysterious_rider
PostPosted: 19:26 - 14 Jan 2016    Post subject: Reply with quote
Must be a twat of a job to do. Tbh if it runs fine in winter id leave it alone. They are only to assist in cold starts. Early diesels didnt even have them.
Otherwise a garage wont want to give you quotes. Just book it in somewhere you trust. People who ask for quotes are usually cheapskate time wasters. Seen it many a time.
KAWASAKIIIII
J4mes
PostPosted: 19:36 - 14 Jan 2016    Post subject: Reply with quote
Paid £2500 to have the plugs changed on my discovery Laughing
There are tools around which vibrate them out which you can hire or find a specialist which has one.
Nexus Icon
PostPosted: 19:39 - 14 Jan 2016    Post subject: Reply with quote
Rhino, as soon as a Subaru throws up an engine light the system turns off all of the driver aids, ABS, Cruise, traction control, etc. and lights up the dash like a Christmas tree. I had the same when the reverse switch broke on my Impreza.
Greetings from Shitsville!
PostPosted: 19:55 - 14 Jan 2016    Post subject: Reply with quote
I changed the glow-plugs on my trusty BMC1500 canal boat diesel. It was a fucking nightmare to get them out without breaking them and this is the simplest diesel known to man.
1/8 turn one way, then back again. Plus gas, slowly slowly catchee monkey job.
Took most of 6 hours to change 4 glow-plugs without breaking them. The trouble is a garage isn't going to do that, it will try and undo, and if it breaks - thats head removal time.
Triumph Trophy Launch Edition
stevo as b4
PostPosted: 20:36 - 14 Jan 2016    Post subject: Reply with quote
Id be chuffed at having to replace a few glow plugs on a Boxer diesel. Don't start looking up engine faults/damage for these engines whatever you do, as you will see plenty of carnage and destruction.
It's a shame, as the boxer Diesel has quite a nice and mellow unobtrusive sound compared to the VAG TDI knockers or the Harsh Ford TDCI engines etc.
Suntan Sid
PostPosted: 21:33 - 14 Jan 2016    Post subject: Reply with quote
I had surmised this from what I've read in the owners manual.
I have found a blown 40A slow blow fuse.
There are three 40A fuses, in a separate part of the fuse box that seems to contain the fuses and relays for the glow plugs.
The two fuses that are intact are marked "MINI HTR (RH)" & "MINI HTR (LH)". Presumably mini heater left and right hand, does "mini heater" refer to the, actual, glow plugs?
Next to these is a relay marked "PTC HTR RELAY", not sure what "PTC" refers to.
At the opposite end of this compartment there is another relay marked "GLOW RELAY" and directly underneath this is the blown fuse which has no identifying marks other "40A No.9 SBF"
Can anyone take an educated guess as to what the blown slow blow fuse is protecting?
J4mes
PostPosted: 21:49 - 14 Jan 2016    Post subject: Reply with quote
Any way any way to trace the wires at all? Or bell it out with a meter?
I'd stick a new fuse in and give it a whirl!
Suntan Sid
PostPosted: 21:56 - 14 Jan 2016    Post subject: Reply with quote
I should be able to get some new fuses tomorrow morning, local motor factors has ordered them in, they had every amperage apart from the one I needed, obviously! Laughing
I was wondering if the fuse that has blown directly protects the glow plugs. Going by what's written on the fuse box, I'm guessing it doesn't, if that's the case what does it protect.
No garage, so too dark and cold to be doing anything at the moment!
mysterious_rider
PostPosted: 22:19 - 14 Jan 2016    Post subject: Reply with quote
Well they are to protect the car from a fire. When you put the ignition on they will be live. Not too sure if for few seconds or perma.
Either way if its touching frame... Not good.
KAWASAKIIIII
J4mes
PostPosted: 22:20 - 14 Jan 2016    Post subject: Reply with quote
If it protects the glow plug control relay it might be worth pulling it out and checking it. Is it just a basic 4 pin relay or does it look complex?
PostPosted: 22:37 - 14 Jan 2016    Post subject: Re: Diesel Glowplugs Problem Reply with quote
Wow, such support, very reassure. Mad
I see Subaru UK doesn't provide any way to contact them other than "raising a case" via https://subaru.co.uk/support
Did they try resetting the error? If you do trade it in, I imagine that'd be the first thing they'll do. Buying a basic OBD II reader (under £10 on eBay) is essentially a no-brainer.
Suntan Sid
PostPosted: 22:59 - 14 Jan 2016    Post subject: Reply with quote
Some intense googling has turned this up.
From page 13 page of this Subaru press release document:-
https://www.motorshow.me/GalleryDocs/Doc2774.pdf
The Impreza 2.0D diesel engine possesses good heat efficiency meaning that water temperature does not readily increase during normal driving, making it necessary to use a Positive Temperature Coefficient Heater that provides supplementary heating in addition to the heating system used for regular petrol vehicles. Use of this heater guarantees heating performance immediately after starting the vehicle and in regions of extremely cold temperatures
So I assume the "PTC HTR" fuse, which has blown, is the "Positive Temperature Coefficient Heater" fuse and, as such, has sod all to do with glow plugs!
This may, of course have nothing to do with the error code we've got, a blown fuse may just be pure coincidence!
No they didn't, however they did say they were not a main Subaru dealer, (the nearest is in Sheffield), and didn't have the equipment to do it! Laughing  They didn't charge for telling us the error code!
robs321
PostPosted: 23:10 - 14 Jan 2016    Post subject: Reply with quote
My mate swears by soaking them in coke-cola. He recons its so much better than plus gas or any other penetrating oil!!
mysterious_rider
PostPosted: 07:46 - 15 Jan 2016    Post subject: Reply with quote
Best thing is to run the engine hot first. Then strip it apart.
KAWASAKIIIII
Suntan Sid
PostPosted: 13:30 - 15 Jan 2016    Post subject: Reply with quote
Well, got the new fuse, no difference! Crying or Very sad
Just spoken to the main dealer service centre and yes it's a known problem.
Their view of the problem is, with it being a 4 year old, 60k mile, engine they don't expect it to be the glow plugs it's more likely to be the glow plug relay.
They take the view that if one, or more, glow plugs were on the way out, then we would get the specific glow plug warning light on the dash, (which we're not getting), not just the engine management light.
They also said, if it had been the PTC Heater fuse, throwing up the warning lights, once the fuse is replaced the dasboard warning lights would disappear, although the fault code would remain in the system, until it's cleared.
For starters, it's £73 + vat just for a diagnostic hook up!
Then it's fingers crossed that it's just the relay.
If it's the glow plugs, it's fingers and toes crossed that they come out in one piece.
The service manager is confident they can get them out without damaging anything, he says the problems highlighted on the web, usually, stem from hamfisted attempts to remove them by owners, who then give up and take the vehicle to the dealer. Hmmmm, all we can do is take his word for it, I guess!
Specialist tools required, very inaccessible, middle of winter, no garage, so there's no way I'm looking at anything other than basic maintenance right now!
RhynoCZ
PostPosted: 14:20 - 15 Jan 2016    Post subject: Reply with quote
He is right about the glow plugs removal. If you do not know what you are doing, you can end up taking the engine head off to clean the bits of the plugs from the head and the combustion chamber.
I was thinking it could be the relay, as I had nothing better to do and googled the fault code, some people just changed the relay (£60 or so, not sure how old the page was) and the car ran like a champ again.
bugeye_bob
PostPosted: 15:15 - 15 Jan 2016    Post subject: Reply with quote
Have you tried any Subaru independents for a price ?
Suntan Sid
PostPosted: 15:20 - 15 Jan 2016    Post subject: Reply with quote
Yes, that was the first place we went to, reading between the lines, I think they don't want to touch it, they claimed not to have the right equipment/tools to do the job and recommended the main dealer!
Suntan Sid
PostPosted: 15:33 - 15 Jan 2016    Post subject: Reply with quote
Hopefully it is just the relay!
The real problem is, because the system has detected a fault it has shut down a lot of features, ABS, Stability control, hill start brake, cruise control, etc.
The car starts and runs fine, it's not in limp home mode, we could, probably, run it for thousands of miles as it is, however with the warning lights, on the dash, lit up it'll never pass another MOT!
Nobby the Bastard
Harley Gaydar
PostPosted: 16:42 - 15 Jan 2016    Post subject: Reply with quote
Take all the bulbs out the dash...
Triumph Sprint ST 1050
Tracey Suntan-King
PostPosted: 16:50 - 15 Jan 2016    Post subject: Reply with quote
Thanks for all the comments and advice, chaps.
Also big thanks to Sid for spending so long hunched over the fuse board squinting at the hieroglyphics therein.
Booked into main dealer so no more to do now, except consider what car to have next and when Thumbs Up
Tracey Suntan-King
PostPosted: 16:53 - 15 Jan 2016    Post subject: Reply with quote
Where's the karma button for this post is naughty?
Suntan Sid
PostPosted: 17:17 - 15 Jan 2016    Post subject: Reply with quote
The thought had crossed my mind!
The last post was made 10 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 0.62 - MySQL Queries: 15 - Page Size: 134.93 Kb
