| Tracey Suntan-King |
 Tracey Suntan-King World Chat Champion
 Posted: 18:20 - 14 Jan 2016 Post subject: Diesel Glowplugs Problem |
Can anyone help please? Is my 2011 Subaru Forester boxer diesel kaput?
Two warning lights are on, one for the engine and the other for the Vehicle Dynamics Control. This gives an error code of P1380 at my local Subaru dealers, who don't want the repair job
This means that one of the glowplugs has gone. Strangely, the car runs fine but I don't feel safe as the ABS And VDC are not active and the hill start function is also inactive. No cruise control either.
Not a lot of info on Google but indications are that replacing a glowplug costs around £425 unless it (glowplug) breaks which can lead to thousands of £.
None of the garages I've enquiried at are ringing me back. If I knew it was definitely going to cost £425 I wouldn't have a problem there appears to be a risk of a much higher bill.
Is it time for a trade in and take the massive hit on value, or repair, or what?
Do glowplugs break easily?
BCF help please!
Thank you
There is a ray of hope, Sid has found one of the glowplugs fuses has blown. So it could just be a fuse, but if the replacement blows (we won't get that till tomorrow) it's the plug and back to the problem above.  ____________________ Whether you think you can, or think you can't, you're probably right |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 18:29 - 14 Jan 2016 Post subject: |
Glow plugs don't break, just being there. The only time they break is when you force them out. That is the fun part of changing them. If a glow plugs breaks, then it's the head down in 9 out of 10 cases.
The ABS and other systems should not be connected to a glow plug failure. If there is snow where you drive, it is possible the snow covered one of the speed sensors at the wheels, so the system does not know how fast the wheels are spinning, therefore disables the ABS and other systems that are related to the actual speed of the individual wheels.
Even if there is no snow, I'd be checking the sensors and then scale it reads the speed from.
It could also be a faulty ABS pump.
EDIT: https://legacygt.com/forums/showthread.php/got-odd-code-yesterday-p1380-193852.html? ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| mysterious_rider |
 mysterious_rider World Chat Champion
| J4mes |
 J4mes World Chat Champion
 Posted: 19:36 - 14 Jan 2016 Post subject: |
Paid £2500 to have the plugs changed on my discovery
There are tools around which vibrate them out which you can hire or find a specialist which has one. |
| Nexus Icon |
 Nexus Icon World Chat Champion
| Polarbear |
 Polarbear Super Spammer
| stevo as b4 |
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 21:33 - 14 Jan 2016 Post subject: |
| Nexus Icon wrote: | Rhino, as soon as a Subaru throws up an engine light the system turns off all of the driver aids, ABS, Cruise, traction control, etc. and lights up the dash like a Christmas tree. I had the same when the reverse switch broke on my Impreza. |
I had surmised this from what I've read in the owners manual.
I have found a blown 40A slow blow fuse.
There are three 40A fuses, in a separate part of the fuse box that seems to contain the fuses and relays for the glow plugs.
The two fuses that are intact are marked "MINI HTR (RH)" & "MINI HTR (LH)". Presumably mini heater left and right hand, does "mini heater" refer to the, actual, glow plugs?
Next to these is a relay marked "PTC HTR RELAY", not sure what "PTC" refers to.
At the opposite end of this compartment there is another relay marked "GLOW RELAY" and directly underneath this is the blown fuse which has no identifying marks other "40A No.9 SBF"
Can anyone take an educated guess as to what the blown slow blow fuse is protecting? ____________________ "Everybody needs money, that's why they call it money!"  |
| J4mes |
| Suntan Sid |
 Posted: 21:56 - 14 Jan 2016 Post subject: |
I should be able to get some new fuses tomorrow morning, local motor factors has ordered them in, they had every amperage apart from the one I needed, obviously!
I was wondering if the fuse that has blown directly protects the glow plugs. Going by what's written on the fuse box, I'm guessing it doesn't, if that's the case what does it protect.
No garage, so too dark and cold to be doing anything at the moment! ____________________ "Everybody needs money, that's why they call it money!"  |
| mysterious_rider |
| J4mes |
| Rogerborg |
 Rogerborg nimbA
 Posted: 22:37 - 14 Jan 2016 Post subject: Re: Diesel Glowplugs Problem |
| Tracey Suntan-King wrote: | my local Subaru dealers, who don't want the repair job |
Wow, such support, very reassure.
I see Subaru UK doesn't provide any way to contact them other than "raising a case" via https://subaru.co.uk/support
Did they try resetting the error? If you do trade it in, I imagine that'd be the first thing they'll do. Buying a basic OBD II reader (under £10 on eBay) is essentially a no-brainer. ____________________ Biking is 1/20th as dangerous as horse riding.
| Suntan Sid |
 Posted: 22:59 - 14 Jan 2016 Post subject: |
Some intense googling has turned this up.
From page 13 page of this Subaru press release document:-
https://www.motorshow.me/GalleryDocs/Doc2774.pdf
| Quote: | The Impreza 2.0D diesel engine possesses good heat efficiency meaning that water temperature does not readily increase during normal driving, making it necessary to use a Positive Temperature Coefficient Heater that provides supplementary heating in addition to the heating system used for regular petrol vehicles. Use of this heater guarantees heating performance immediately after starting the vehicle and in regions of extremely cold temperatures |
So I assume the "PTC HTR" fuse, which has blown, is the "Positive Temperature Coefficient Heater" fuse and, as such, has sod all to do with glow plugs!
This may, of course have nothing to do with the error code we've got, a blown fuse may just be pure coincidence!
| Rogerborg wrote: | Did they try resetting the error? If you do trade it in, I imagine that'd be the first thing they'll do. Buying a basic OBD II reader (under £10 on eBay) is essentially a no-brainer. |
No they didn't, however they did say they were not a main Subaru dealer, (the nearest is in Sheffield), and didn't have the equipment to do it! They didn't charge for telling us the error code! ____________________ "Everybody needs money, that's why they call it money!"  |
| robs321 |
 robs321 Could Be A Chat Bot
| mysterious_rider |
| Suntan Sid |
 Posted: 13:30 - 15 Jan 2016 Post subject: |
Well, got the new fuse, no difference!
Just spoken to the main dealer service centre and yes it's a known problem.
Their view of the problem is, with it being a 4 year old, 60k mile, engine they don't expect it to be the glow plugs it's more likely to be the glow plug relay.
They take the view that if one, or more, glow plugs were on the way out, then we would get the specific glow plug warning light on the dash, (which we're not getting), not just the engine management light.
They also said, if it had been the PTC Heater fuse, throwing up the warning lights, once the fuse is replaced the dasboard warning lights would disappear, although the fault code would remain in the system, until it's cleared.
For starters, it's £73 + vat just for a diagnostic hook up!
Then it's fingers crossed that it's just the relay.
If it's the glow plugs, it's fingers and toes crossed that they come out in one piece.
The service manager is confident they can get them out without damaging anything, he says the problems highlighted on the web, usually, stem from hamfisted attempts to remove them by owners, who then give up and take the vehicle to the dealer. Hmmmm, all we can do is take his word for it, I guess!
Specialist tools required, very inaccessible, middle of winter, no garage, so there's no way I'm looking at anything other than basic maintenance right now! ____________________ "Everybody needs money, that's why they call it money!"  |
| RhynoCZ |
| bugeye_bob |
 bugeye_bob World Chat Champion
| Suntan Sid |
| Suntan Sid |
 Posted: 15:33 - 15 Jan 2016 Post subject: |
| RhynoCZ wrote: | I was thinking it could be the relay, as I had nothing better to do and googled the fault code, some people just changed the relay (£60 or so, not sure how old the page was) and the car ran like a champ again. |
Hopefully it is just the relay!
The real problem is, because the system has detected a fault it has shut down a lot of features, ABS, Stability control, hill start brake, cruise control, etc.
The car starts and runs fine, it's not in limp home mode, we could, probably, run it for thousands of miles as it is, however with the warning lights, on the dash, lit up it'll never pass another MOT! ____________________ "Everybody needs money, that's why they call it money!"  |
| Nobby the Bastard |
 Posted: 16:50 - 15 Jan 2016 Post subject: |
Thanks for all the comments and advice, chaps.
Also big thanks to Sid for spending so long hunched over the fuse board squinting at the hieroglyphics therein.
Booked into main dealer so no more to do now, except consider what car to have next and when  ____________________ Whether you think you can, or think you can't, you're probably right |
| Suntan Sid |
The last post was made 10 years, 173 days ago. Instead of replying here, would creating a new thread be more useful? |
