| Rogerborg |
 Rogerborg nimbA
 Posted: 00:13 - 19 Jan 2016 Post subject: Rear brake use: not enough, too much, just right? |
I keep seeing folk talking about using the rear brake for slow speed manoeuvres. It's not something that I ever got into the habit of doing to "balance" the bike, and nor have I needed to given that I tend to plan ahead enough to not use the brakes much[*], but I'm beginning to wonder if there's something to it.
Talking about it is one thing, seeing how much someone actually does it is another.
TRIGGER WARNING: vlogger.
On and off but mostly on the rear brake while filtering.
To me that looks extreme: he's pressing (not just covering) the rear brake while accelerating, not just occasionally but repeatedly. In this section here for example.
It seems like a fair old waste of energy to be doing that. Fuel, brake pads: am I being a bit Scotch about it?
How does that compare to your cut-and-thrust heroics? Do you London-wallahs habitually ride the rear like that?
[*] With one comical exception. Being quicker onto or poised on the rear might actually have helped there.  ____________________ Biking is 1/20th as dangerous as horse riding.
| ScaredyCat |
 ScaredyCat World Chat Champion
| weasley |
 weasley World Chat Champion
| Shaft |
 Shaft World Chat Champion
 Posted: 00:42 - 19 Jan 2016 Post subject: |
I got about half way through that and I would say I probably use my rear brake in a similar fashion.
I was brought up riding off road, where the rear brake is often used for balance, kicking the back out a bit or simply because using the front, in certain circumstances, isn't very sensible.
Before I went on the road, I did a training course and it was quite a change to stick to their recommended 70/30 ish front to rear brake bias, I had to make a concerted effort during observed tests.
While I'm filtering (more at slow speeds) I prefer to use the rear as a steady, you don't get the same level of weight transfer and certainly no diving forks, which I find makes control a bit easier, but maybe it's just me. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Pigeon |
 Pigeon World Chat Champion
| andym |
 andym World Chat Champion
 Posted: 01:30 - 19 Jan 2016 Post subject: |
When I had my lesson(s) for my MOD 2 the instructor told me not to use my front brake at all  |
| barrkel |
 barrkel World Chat Champion
 Posted: 01:53 - 19 Jan 2016 Post subject: |
For low speeds especially with frequent variation in speed, the rear keeps lash / slop out of the drive. Slack in the chain, gearbox, cush drive etc. all adds up to potential for jerkiness if you let engine braking kick in.
Different story on scooters; there it's essential for fine control over the output of the centrifugal clutch. You effectively slip the clutch by preventing the rear from getting too much speed despite the action on the drum. I replace rear pads on the scooter about every 7k miles. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| NJD |
 NJD World Chat Champion
 Posted: 02:09 - 19 Jan 2016 Post subject: |
Similar to andym. During my training I was told continuously by all bar one instructor that it was rear brake only at low speeds, slow control and to the final part of coming to a dead stop, if I attempted to use the front brake for anything other than the first part of coming to a dead stop or slowing down they'd moan and reminded me about the rear brake only.
While riding the GS 500 that method worked because in comparison to my tiddler the GS had a powerful rear brake and provided very good feedback and feel through the pedal and reacted and stopped, slowed and behaved just how I wanted it to. On my tiddler, and possibly as an inadvertent comparison to the GS, I find that the rear drum brake is so utterly useless that it doesn't even help at the lowest of speeds despite any attempts to adjust it that I've made in the past I just find that I don't have any confidence in it at all and feel like I'm going to end up not being able to stop or end up in the rear of the car in-front if I did attempt to rely on the rear only. Due to the lack of trust in the rear I use the front most and if not all of the time and then a combination of clutch and throttle at low speeds, filtering etc.
Personally I'd like to be able to ride with more rear brake only action but have given up trying (as above) because of the utterly crappy brakes. The only time I apply the rear when at slow speeds or filtering it to scrub of that little bit of extra speed and then continue with a clutch and throttle combination. Front brake whenever I need to stop, has dipped the front a few times but I've learnt to adjust, when and how much brake to apply etc. At this point I think I ride thinking that I'm using the rear brake but probably don't, I've caught myself a few times thinking I'm pressing on the pedal and I haven't been, out of habit.
Everyone has a different method of riding and an idea of how it should or shouldn't be done but I'd say ride the way that you're comfortable with and gives you the most control.
I seem to recall being more confident on the rear in ankle boots and getting a far better feel of my tiddlers rear brake through the pedal than I ever have while wearing my RST boots or full on sized boots. Should probably invest in a decent usable pair of ankle boots and see if that's the case or not. |
| mentalboy |
 mentalboy World Chat Champion
| Polarbear |
 Polarbear Super Spammer
 Posted: 08:49 - 19 Jan 2016 Post subject: |
On a normal braked bike I hardly use the rear at all. Emergency stops
etc. yes but usually just front brake.
On bloody linked brake systems like my Trophy has then it's a mixture but the back brake lever operates a percentage of the front brake as well so you can't get away with just the front.
Overcomplicated and unnecessary but getting more and more popular.  ____________________ Triumph Trophy Launch Edition |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 09:12 - 19 Jan 2016 Post subject: |
Despite my wrath about 'Drag 'n' Slip taught as 'first course' to 'under-drive' the gear-box for slow-speed manoeuvres.... yes, I do use fair bit of back brake where appropriate, but then I ride a quarter ton barge, usually 2-Up...
Found I use it a bit more on the Guzzi, too, but then, front brake lever only works one disc, back brake pedal works back brake disc and the other front.
Curiously, in trials I use a lot less back brake... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Rogerborg |
 Rogerborg nimbA
| Doovy |
 Doovy World Chat Champion
| Matt B |
 Matt B World Chat Champion
| Islander |
 Islander World Chat Champion
| Silver_Fox |
 Silver_Fox World Chat Champion
| winz |
 winz World Chat Champion
| someotherguy |
 someotherguy Crazy Courier
| smallfrowne |
 smallfrowne Scooby Slapper
| andym |
 Posted: 15:04 - 19 Jan 2016 Post subject: |
| chris-red |
| el_oso |
 el_oso World Chat Champion
| M.C |
 M.C Super Spammer
| Piercee100 |
 Piercee100 Trackday Trickster
| Irn-Bru |
 Irn-Bru World Chat Champion
 Posted: 20:21 - 19 Jan 2016 Post subject: |
Some bikes just have crap rear brake set ups, not surprised some don't touch it. My DRZ was a nightmare, it was either on or off, when I changed to a braided line it would just lock up all the time unless you were careful. Swapped it out for a master cylinder off a crf 450, still a Nissin but much more progressive so now I can comfortably use the rear. I use it quite a lot, mainly for slow speed stuff so I can have full control of the throttle, junctions, filtering etc. On rare occasions I might use it on those gravelly death trap roads that have been resurfaced, total nightmare, logic is it's easier to control losing the back end than the front. Even then I try my very hardest not to touch the brakes, even a sudden down change will lock up the rear, absolutely despise when they leave the roads in that condition, especially on biker roads, they did it quite a bit in the Lakes last year. ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
The last post was made 10 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
