Tdr250 tag id/id info
Bugsy
PostPosted: 11:17 - 22 Jan 2016    Post subject: Tdr250 tag id/id info Reply with quote
Ok have given up on tdr250.uk cant acess site and admin are not responding.
Collecting a already stripped tdr250 on sat.
All numbers match and hpi check is clear.
Know its a 3ck
Going to check numbers again on the side of the headstock.
Main query is some seem to have a silver plate on the frame some dont?
Assume if its a uk bike should have a steel swingarm?
Any id tips etc would be appreiciated.Wink
andys675
PostPosted: 20:41 - 22 Jan 2016    Post subject: Reply with quote
bit of a pain trying to find the right rivets to stick the plate on iirc so after powder coating the frame there is no need to stick the plate back on as the frame is stamped anyway
yes a jap bike has an alloy swinger and the uk bike has steel
mine was jap, and had a jap spec TZR250 2xt engine with extra ports and plated bores, jap bikes had no engine numbers only the model prefix
my login for the tdr forum works fine, and so does the site
was probably one of the most fun bikes I ever had besides the triple
tony_d123
Yes UK bikes have steel swing arms. I think its just the Japanese imports that are alloy.
Be patient with tdr250.uk they do take a while. I ended up emailing them after a couple of weeks at admin@[website address] and was registered within a couple of days.
Blackpool, Lancashire
c_dug
PostPosted: 20:47 - 22 Jan 2016    Post subject: Reply with quote
You can just take over my account on there if you get nowhere with the application process, I never use it anymore.
It's a wealth of top notch info, but as above, patience is required.
Bugsy
PostPosted: 21:49 - 22 Jan 2016    Post subject: Reply with quote
Thank you for all if you inputs.
Very Happy
Andy nice to see a fellow classic str owner Wink
tony_d123
PostPosted: 11:45 - 24 Jan 2016    Post subject: Reply with quote
It's not been down, I go on every day. I presume that Bugsys problem is getting registered?
The last post was made 10 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 51.61 Kb
