Yamaha xj6 exhausts
Jonny491
PostPosted: 14:16 - 25 Jan 2016    Post subject: Yamaha xj6 exhausts Reply with quote
HI guys
I've recently bought a yamaha xj6 N and it has the standard exhaust on and I'm looking to buy a full aftermarket can like the arrow?
I'm just wondering is it a straight swap of or is there and 02 sensors or anything?
Also does anybody know where I can buy just the downpipes as I like the look of the mivv double gun exhaust but I can only find a slip on of that and not a full system?
Cheers in advance
Honda cbr 125 2006- Sold, Current 2012 yamaha XJ6N
Recluso
PostPosted: 13:39 - 26 Jan 2016    Post subject: Reply with quote
This is going back a couple of years, but when I was considering swapping out the exhaust on my XJ6 Diversion, I was told it would need to be a complete system swap because whacking an end-can onto the shoebox sized catalytic converter underneath means you still get sod all sound.
System-wise, I know a couple of years ago it was only a couple of places that did it and it was a good few grand. This might have changed by now, but from what I was told then, that you couldn't just bang on a set of any old downpipes. Someone I knew was tinkering with a set of R1 downpipes to fit, but I don't know what came of it. I was given the distinct impression that not an awful lot was available for the XJ6, probably because the amount of people willing to sink 4k on a new exhaust system are probably few and far between.
If you want just the look of an exhaust without the noise, you can get end cans to fit the XJ.
If you want the extra noise factor, the whole lot needs doing and that isn't (or at least when I looked, it wasn't) cheap.
'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900
fatjames
PostPosted: 15:07 - 26 Jan 2016    Post subject: Reply with quote
When I had an 2012 ER6f it was the same sort of deal. The stock exhaust was 1 piece front to back, but there was something you could do..
The older bikes (<2011) had a 2 piece exhaust so you could buy downpipes from an earlier model cheap from ebay then add the end can of your choice.
The other option I saw on youtube, and you'll like this, was someone taking a long, big drill to the cat and drilling through the tip of the exhaust down into the cat to remove some sound suppressant - It worked..! But I didn't copy him. I haven't got sound in work, but this might be the vid - https://www.youtube.com/watch?v=b4KMDVzKEVU
After about a year or so I started seeing complete systems coming down in price and got a yoshi system for about £700.
Worth noting, you'll probably need a lambda bung welder on or plug in jumper for the wiring harness and, of course, a power commander to get the full benefit.
HTH
FJ
iooi
PostPosted: 16:42 - 26 Jan 2016    Post subject: Re: Yamaha xj6 exhausts Reply with quote
Jonny491 wrote:
HI guys
Cheers in advance
!st off The workshop is where this should be.. Followed by a lot more info on the bike....
As the XJ6N's have been available since 1992 & a such can make a major difference to any advise given Rolling Eyes
Werny
PostPosted: 10:44 - 27 Jan 2016    Post subject: Reply with quote
Assuming you mean the new model XJ6's from 2009(?) onwards, as you know it's a complete system swap, I put a full Arrow system on mine for £700. It was more than I wanted to pay for it but the original thin steel system was rotting away after a winter's hard use.
It just bolted straight on, there is a sensor in the original that you remove, and it screws into the new exhaust. Make sure the specs for the new exhaust state it has mounting for the Lambda sensor, I think you can get models without it.
The Arrow is held on at the rear by a kind of crappy(ish) bracket that attaches to your rear footpeg hangers, it doesn't look awful but it could be better.
I also saw discussions about using R6 downpipes, but it would all require a lot of tinkering and bodging to get them to fit.
The last post was made 10 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 45.86 Kb
