cleaning heavy soiling from bike?
baderlfc
PostPosted: 19:57 - 31 Jan 2016    Post subject: cleaning heavy soiling from bike? Reply with quote
Guys, can anyone recommend a powerful cleaner/degreaser to get rid of heavy soiling from lower fairing/swingarm and other lower areas of the bike that won't damage anything?
I tried neat autosmart triple citrus degreaser yesterday and it didn't touch it..
chickenstrip
PostPosted: 20:19 - 31 Jan 2016    Post subject: Reply with quote
Jizer, Gunk. Muc Off also do a degreaser spray. WD40 works too, sprayed on a rag and wiped over. Not sure what any of those are like on painted bodywork though.
Inb4 Fairy Liquid contains ...oops, beat me to it Rolling Eyes .
Keir
PostPosted: 20:24 - 31 Jan 2016    Post subject: Reply with quote
i use APC but dilute it as its like paint stripper neat.
EBAY ad here
5L will last ages.
Current : '08 Yamaha FZ1s
temeluchus
PostPosted: 20:35 - 31 Jan 2016    Post subject: Re: cleaning heavy soiling from bike? Reply with quote
For bare metal, the likes of acetone, white spirit, petrol etc will get pretty much any gunk off.
Brendan110_0
PostPosted: 22:14 - 31 Jan 2016    Post subject: Reply with quote
I use a great de-greaser from autosmart - B.C.E Freinet. Dissolves all oil type substances.
sreeB fo gniK
ADSrox0r
PostPosted: 22:34 - 31 Jan 2016    Post subject: Reply with quote
Paraffin.
Parson
PostPosted: 08:16 - 01 Feb 2016    Post subject: Reply with quote
I use Muck Off.
You might not have done any good using the stuff neat though. A lot of TFR's need water to activate them. We used to use it to clean the heavy plant in work, neat it was shite, a bit of water made the difference.
You will still need some elbow grease and a good brush though, no matter what you use.
Then gsx650F - Now VFR800F
mudcow007
PostPosted: 10:01 - 01 Feb 2016    Post subject: Reply with quote
if im feeling flush - which isnt very often...carb cleaner will remove most pesky marks no matter how long they have been on for
just remember carb cleaner isnt that kind to paint
Kerosene/ Parrafin is good at cleaning oily crap too
Supermoto_Fan
PostPosted: 11:01 - 01 Feb 2016    Post subject: Reply with quote
FYI I've never found anything that works simply spraying on and spraying off. Even the most expensive amazing products need agitation by sponge or brush.
Matt B
PostPosted: 11:19 - 01 Feb 2016    Post subject: Reply with quote
WD40 is fine on the bodywork, it's good at removing gunk and road tar. I use it to clean the swingarm and the wheels on my bikes.
PostPosted: 11:29 - 01 Feb 2016    Post subject: Reply with quote
I picked up 5 litres of WD-40 in B&Q of all places for ~£25. They also had decent shop towels for eBay-equivalent prices. You won't find this stuff on their web site, but have a poke around and you can sometimes find dusty boxes of goodies at the bottom of the stacks.
c-m
PostPosted: 13:11 - 01 Feb 2016    Post subject: Reply with quote
The problem is that you sponges and brushes will be filthy after the first wipe. And you then need to clean them constantly by dunking them in something like paraffin all the time to avoid just spreading the grease.
Baffler186
PostPosted: 13:42 - 01 Feb 2016    Post subject: Reply with quote
I've also had more success with the likes of WD40 or GT85. it seems to slip in behind the dirty stuff and slide it right off.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
ADSrox0r
PostPosted: 14:20 - 01 Feb 2016    Post subject: Reply with quote
Baffler186 wrote:
Slip in the dirty stuff from behind
https://i.dailymail.co.uk/i/pix/2014/01/02/article-0-1A6084F700000578-696_634x422.jpg
Moo.
PostPosted: 14:23 - 01 Feb 2016    Post subject: Reply with quote
Asdas own brand WD40? 400ml can for £1.50 I go crazy with the stuff. Laughing Smells the same, so must be the same Laughing
A2 Passed 18/6/10
Evil Hans
PostPosted: 14:41 - 01 Feb 2016    Post subject: Reply with quote
+1 ... I've been using this to shift the road grime off the Bandit. Cheaper than WD and even seems to work better.
Davie J
PostPosted: 15:16 - 09 Feb 2016    Post subject: Reply with quote
400ml eh.
I'll need 2 or 3 of the fuckers. What shiny side up is is debatable at the moment.
Kwak Z750R Black Edition
Marauder 125 K3 (Murdered by a Megane), Varadero 125 V7 (sold), Varadero Thou (Sold), CB500S (Sold).
Andy_Pagin
PostPosted: 15:19 - 09 Feb 2016    Post subject: Reply with quote
ADSrox0r wrote:
Paraffin.
Gets my vote, removes the crap and leaves things lightly oiled.
Val
PostPosted: 19:37 - 10 Feb 2016    Post subject: Re: cleaning heavy soiling from bike? Reply with quote
You soak the dirt with something (WD40, white spirit, diesel, paraffin) and need to scrape the dirt with some wooden or plastic scrapper. I use wooden kitchen spatula from Tesco.
I use WD40, paraffin from B&Q: https://www.diy.com/departments/bq-paraffin-4l/257116_BQ.prd
I have cleaned parts and dirt with diesel too. It is more or less the same as kerosene only paraffin content is slightly different. And diesel is cheapest.
You can't remove heavy dirt just by spraying it. Elbow grease is required.
Put some cardboard or big plastic bag under the bike to collect the dirt.
talkToTheHat
PostPosted: 02:30 - 12 Feb 2016    Post subject: Reply with quote
For road dirt, muc off. For stubborn grease, jizer. Muc off can be found on ebay for 20 squid for two five lite bottles. Get litre spray bottle from b&q and spray 1:1 dilited muc off on painted surfaces and near jizer elsewhere. A 5 litre garden sprayer of water, a microfibre cloth for painted areas and a brush for elsewhere and everything is easy. The only thing muc off doent easily shift is chain goop, but jizer or chain cleaner shifts that. I don't know whether jizer is safe on o ring chains.
Bandit. does. everything.
The last post was made 10 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 114.27 Kb
