Calling all VFR750 owners!
qarka
PostPosted: 12:47 - 03 Feb 2016    Post subject: Calling all VFR750 owners! Reply with quote
Hi. I've been after a Vfr750 for a while, specifically a 94-97 model in red. Probably something to do with my dad having one when I was at an impressionable age. Anyway I'm now at a stage where I'm making enough disposable income to be able to save quite a bit and finally get myself my dream bike.
I just want to know what are the usual things to look out for when buying one of these. I know replacement stainless downpipes would be a bonus, also the rear shock on higher mileage machines is likely to be shagged. What else should I be checking for when viewing bikes? Also does a budget of about 2k seem realistic?
Thanks all.
PostPosted: 14:40 - 03 Feb 2016    Post subject: Reply with quote
Electrical fun.
I recall assisting to fix one in Belgium in the rain. Laughing
PostPosted: 14:45 - 03 Feb 2016    Post subject: Reply with quote
Have a wiggle ar the rear hub bearings. There is over £200 worth of bearings in there.
Make sure the chain adjuster isn't seized (either in the swingarm or to the bake plate).
They have a flexible PCB backed dash. It's prone to corrosion/failure of the wiring tracks. Any malfunctioning gauges or lights should be viewed with suspicion.
Reg-recs go pop. Usually every 16k miles unless they have been replaced with a different one (most will have).
Clutches rattle after some miles for no readily discernable reason.
Starter clutch rollers can start to slip. Squeals on startup. Not a big deal, rebuild kits are available.
Have a look at the solid, chromed steel oil pipes running up to the oil cooler for corrosion.
Radiators are very expensive to replace.
Check the tags where the fairing side pieces locate into the nose piece.
ADSrox0r
PostPosted: 14:50 - 03 Feb 2016    Post subject: Reply with quote
As already stated, regrecs go pop. Will either have been replaced or had a 12V fan rigged to it in a more 'draughty' position if the previous owner was keen.
Had a go on a friend's '92 750 once, good fun lovely old thing with lots of character but his carbs were fucked and ended up needing far more work than it was worth.
I could've killed him for letting it go for a song, I wanted the 8 spoke rear wheel for my 800.
Because Honda.
PostPosted: 16:35 - 03 Feb 2016    Post subject: Reply with quote
Vincent wrote:
Get one that's had a stainless exhaust fitted Thumbs Up
Or if it hasn't, allow £450 for a motad one and make sure you're going to be able to remove the mainstand, because you need to to fit a new exhaust.
Alex A
PostPosted: 20:28 - 03 Feb 2016    Post subject: Reply with quote
Paddy. wrote:
Electrical fun.
This. I had a '92 VFR750 (in 2008-9). I had a reg-rec go shortly after I bought it, causing extensive damage to the harness (i.e. burned out connectors). Big job to fix, fortunately under dealer Warranty.
Aside from that, I thought it was a great bike at the time, but I wouldn't own one now. They're too old, too complicated for easy home maintenance, and not that brilliant. I bought a VFR800Fi some years later because I remembered the 750 fondly, but it was a big let down really. It felt tired, heavy and dull. But by that time I knew better.
There are better, simpler and equally practical bikes. At a similar budget, I'd choose a tidy VTR1000 Firestorm any day.
Robster
PostPosted: 20:39 - 03 Feb 2016    Post subject: Reply with quote
Had my 97 FV for nearly a year now, It has the CPU fan jerry-rigged to it. mine's been dropped umpteen times by previous owners but is low mileage for the age and runs like a dream.
Mine's developed a random non-start issue that i'm yet to diagnose - not the reg/rec as far as I can tell, tis difficult to start in cold weather, all of them are getting a bit long in the tooth and need TLC, but otherwise its a lovely thing, easy to ride, makes a great noise and is good at long trips. Mine's got the GBMoto bar raisers fitted which help.
Replacement Fairings are expensive so try not to drop it like I did! Embarassed
2 grand should get you a minter Thumbs Up
Up the bum no babies.
Copyhat
PostPosted: 10:24 - 04 Feb 2016    Post subject: Re: Calling all VFR750 owners! Reply with quote
Thanks all.
I bought a '91 VFR in December, but haven't collected it from the dealer yet - it's too fine for salty roads Laughing
It was my choice because they seem to be great for both commuting and touring - and parts are plenty. Secondly, it has the same heritage as my first bike, the NTV 650 with similar steering geometry, single sided swing arm and a torquey V-engine. Fairings and greater power is a big plus for me, and it's a good looking bike.
Common issues have been mentioned, and it is easy to find a nice one if you know what to look for. Replacement fairings are pretty expensive, so I am considering to use crash bongs the first few months of getting used to it.
Past: '91 Honda NTV650, '93 Kawasaki GPZ 500S
Current: '91 Honda VFR750F, '83 Suzuki GSX400F
Moxey
PostPosted: 13:26 - 04 Feb 2016    Post subject: Re: Calling all VFR750 owners! Reply with quote
I hope your proud of yourself, just choked on a bit of my lunch reading that Laughing
At op
Check for corrosion on the radiator chiefly, mine had a severely rusted bracket which sheared and removed a sizeable chunk of radiator with it.
Also as mentioned check the concentric chain tensioner isn't seized.
Sure fire way of telling electrical issues are afoot is ro look at the dash and the lights at idle, if they flicker a little it's a sign if a charging issue.
My 1994 3rd gen was outstandingly reliable and economical for a 145mph machine but I only have fine memories of where the bike got me not necessarily the journey....it was a bit dull!
PostPosted: 15:34 - 04 Feb 2016    Post subject: Reply with quote
They really aren't.
Especially the 3rd gens which were practically designed to be worked on..
Litle things like access holes in the frame to get at otherwise inaccessable carb mount screws, a cutaway in the belly pan for sump plug access, a hinged radiator mount for front plug access.
Once you get your head round the fact you're going to have to remove the (quick release) side fairings to do most of the jobs, they are a delight to work on.
As ever, there are some ball-aches. Mixture screws are one of them. The swingarm cannot be removed with the mainstand in place and god help you if you ever need to remove the rear exhaust manifold but there's generally no good reason why you'd need to.
Bit of a PITA removing the silencer to take the wheel out. I have a slip-joint on mine for quickness. If you're lucky/rich you can also get high level or left hand exit pipes.
Oil change every 9k miles. Tappets every 24k but I really wouldn't bother.
johnnyarctic
PostPosted: 19:01 - 04 Feb 2016    Post subject: Reply with quote
Paddy. wrote:
Electrical fun.
i got home on it Thumbs Up Thumbs Up Mr. Green
i've had mine for a few years and when i've got a minute i'll add to the already informative posts above. Thumbs Up
Current Ride: VFR750
qarka
PostPosted: 19:04 - 11 Feb 2016    Post subject: Reply with quote
Ta for the very informative posts everyone. That gives me a list of stuff to check.
The last post was made 10 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 83.5 Kb
