module 1 flip-up helmet
charlieh777
PostPosted: 10:22 - 03 Feb 2016    Post subject: module 1 flip-up helmet Reply with quote
is it frowned upon to do the slow riding parts of module 1 with a flip-up helmet in the up position?
Matt B
PostPosted: 10:43 - 03 Feb 2016    Post subject: Reply with quote
CBT instructor will probably tell you that riding with a modular lid flipped up is the same as riding without a helmet, because they aren't designed to be used like that...
Draw your own conclusions but I wouldn't.
Holdawayt
PostPosted: 11:45 - 03 Feb 2016    Post subject: Reply with quote
My AGV Compact and Caberg Duke are most certainly designed to be used with the lip flipped up. Not that I ever would... I use them for buying petrol etc without them kicking up a fuss.
As long as the chin strap can be locked in the upright position you'll be ok. They are tested for safety in both positions. If it's a non-lockable one then no, you'll need to wear it like a full face helmet.
As far as Mod 1 goes, I'd rather get used to riding with a full helmet anyway. I can't really see the benefit in flicking the chin guard up.
talkToTheHat
PostPosted: 11:54 - 03 Feb 2016    Post subject: Reply with quote
You might get away with it, but you might make your assessor frown and not get the benefit of some later doubt.
Bandit. does. everything.
someotherguy
PostPosted: 13:02 - 03 Feb 2016    Post subject: Reply with quote
I agree with the previous post. I reckon it's the same as turning up in jeans - I'd rather DSA "Safety First" Derek have a positive perception if it came down to something marginal.
PostPosted: 13:21 - 03 Feb 2016    Post subject: Reply with quote
[citation needed]
Helmets can be tested and certified as P (protective face), NP (non-protective face) or J ("jet", i.e. open face), or any combination of them.
My Nitro is "P" marked, so sucks to those who say they're all tested as open face.
<man crush>Andrew Dalton</man crush> touches on the legalities here[*]:
https://www.whitedalton.co.uk/motorbike-blog/2009/06/schuberth-c3-lid-review/
https://www.whitedalton.co.uk/motorbike-blog/2014/04/to-flip-up-or-to-shut-down/
He doesn't believe that there's any offence being committed by riding flipped up, and I agree. If it's appropriately marked and fastened then you're fully satisfying the letter of the law.
All that said, DVSA Derek may have a different (wrong) opinion, and he's the one with the clipboard and the red pen. Flip it down for 10 minutes, wear a dayglo bib even though you don't have to.
[*] He also pooh-pooh's T.C's assertion that flip fronts are snappyneck lids. Fite.
KnightsFall
PostPosted: 15:20 - 03 Feb 2016    Post subject: Reply with quote
I've had an instructor tell me that I would need to do mod 1 with it closed, although I am not 100% certain if the knew I was wearing a lid certified for use with it open. I'd assume that you will be told to close it but there is no harm in asking the examiner on the day, or so I would imagine.
PostPosted: 15:59 - 03 Feb 2016    Post subject: Reply with quote
No such language in Motor Cycles (Protective Helmets) Regulations 1998, chap.
MC(PH)R 1998 wrote:
every person driving or riding (otherwise than in a side-car) on a motor bicycle when on a road shall wear protective headgear.
[and that means a helmet which]
"(i) bears a [BSI or ECE] marking applied by its manufacturer indicating compliance with the specifications contained [later]
(ii) is of a type manufactured for use by persons on motor cycles which by virtue of its shape, material and construction could reasonably be expected to afford to the wearer a degree of protection from accidental injury similar to or greater than that provided by a helmet of a type prescribed by regulation 5;
(c) is securely fastened to the head by means of straps provided for that purpose
You could wear it backwards and still be compliant if it's secure.
Holdawayt
PostPosted: 16:09 - 03 Feb 2016    Post subject: Reply with quote
I wasn't aware that some helmets aren't tested in both positions! Either way, my two are and I still wouldn't ride with them open. It was more for scratching an itchy nose at lights, chatting to the neighbours without removing the helmet every time and buying petrol without being asked to remove it.
The thought of landing on my chin with it open makes me shudder.
KnightsFall
PostPosted: 16:39 - 03 Feb 2016    Post subject: Reply with quote
What's all the P and J homologation stuff about then? Not sure but I was under the (possibly wildly inaccurate) impression that if a lid is only homologated for use with it closed, keeping it open effectively means that it is not conforming to the relevant safety regs. Is this not the case?
andyscooter
PostPosted: 17:21 - 03 Feb 2016    Post subject: Reply with quote
buy an open faced cheapy one and wear that on the day
PostPosted: 17:37 - 03 Feb 2016    Post subject: Reply with quote
Eurobollocks. The situation may very well be different in Abroad, but we don't live there.
That's what the people selling the lids are keen to claim, but there's not a word about it in the one piece of UK legislation defining a helmet. Any relevant BSI or ECE label, securely fastened. Or as a fallback, "could reasonably be expected to afford".
As Dalton notes, there's no binding precedent so we won't really know until someone's been done for it and taken it to Crown.
Holdawayt wrote:
my two [helmets are tested both closed and open]
Can you have a look for the ECE 22.05 label: does it actually say both P and J?
Holdawayt
PostPosted: 17:53 - 03 Feb 2016    Post subject: Reply with quote
I shall have a look for you when I'm home good sir.
Matt B
PostPosted: 18:02 - 03 Feb 2016    Post subject: Reply with quote
Pass the popcorn
While we await the answer...
I remember seeing the Emergency Biker Paramedic guys (on the TV) riding round with their fronts flipped up a few times. They were in various situations - riding through pedestrian areas, shopping centres, platforms of train stations. If they do it, it must be OK surely?
Thinking
Holdawayt
PostPosted: 18:19 - 03 Feb 2016    Post subject: Reply with quote
Here we go.
https://i123.photobucket.com/albums/o317/Holdawayt/D3D8C059-A627-4684-A323-728D8E1550C9_zpsbg9o0qvv.jpg
Holdawayt
PostPosted: 19:10 - 03 Feb 2016    Post subject: Reply with quote
It's all gone a bit quiet...
bugeye_bob
PostPosted: 19:18 - 03 Feb 2016    Post subject: Reply with quote
https://www.webbikeworld.com/r2/motorcycle-helmet/caberg-duke/review.htm
"In fact, Caberg has probably done more to evolve and improve flip-up and "modular" helmets than any other manufacturer I can think of.
For example, Caberg pioneered the P/J dual-homologation feature on their flip-up helmets like the Caberg Sintesi (review).
This is an ECE certification that the helmet can be worn either as a full-face, with the rotating flip-up visor down and locked, or as a "Jet" style helmet with the rotating visor rotated up and locked."
"Rotating Flip-up Visor
The rotating flip-up visor opens by pressing a large rubberized button in the front. There's nothing to grab with the thumb when the button is pressed, other than the bottom edge of the chin bar. As the visor is raised, it offers no resistance until it hits a very stiff detent at the top of its range, where it clicks into place with a solid "thunk".
Since the Duke is both P and J homologated, it is legal to ride in Europe with the flip-up visor in the raised position. This is controlled with a spring-loaded lock on the left-hand side, just behind the face shield.
If the slider is pushed towards the front, in the "J" position (a P and J are molded into the plastic), the flip-up visor will rotate up but then lock in the raised position. To release it, you must snap the slider all the way back into its detent, which will release the visor so you can close the helmet.
If you're not planning on riding with the flip-up visor in the raised position, push the slider all the way back until it snaps into the "P" position. Now the flip-up visor can be raised or lowered and it will pause only in the detent at the fully raised position.
It took me a few tries to figure it out, but the system works well and feels very solid and it's what has allowed Caberg to obtain the dual homologation for the Duke."
Holdawayt
PostPosted: 19:23 - 03 Feb 2016    Post subject: Reply with quote
Is there anything like that regarding the AGV Compact? As the label that I posted was from my AGV, not the duke.
Bigvern72
PostPosted: 07:27 - 04 Feb 2016    Post subject: Reply with quote
My instructor advised me it was frowned upon to wear the flip visor up. While not illegal the examiner is looking for safety as well as competence and after all.....they're humans and thus are subject to mood swings for very little reason.
Better to wear it down for the 10 mins it takes and then the 30 mins it takes for mod 2......than to risk your money on the whim of a mood swing.
PostPosted: 07:33 - 04 Feb 2016    Post subject: Re: module 1 flip-up helmet Reply with quote
Why do you want to? Confused
KnightsFall
PostPosted: 09:38 - 04 Feb 2016    Post subject: Re: module 1 flip-up helmet Reply with quote
Comfort and increased field of vision maybe? Although if it is a major issue, it might indicate a poor choice of helmet I guess.
I have mine tomorrow and also a fairly nasty cold, so keeping it open for the purpose of coughing lungs up may be necessary. Razz
PostPosted: 10:00 - 04 Feb 2016    Post subject: Reply with quote
Holdawayt wrote:
Neat, thanks. Thumbs Up
For a wonder, that does appear to be a fully compliant marking. Shocked
Huh, the "resistant to wear" (printed fabric) label on my Nitro is now almost entirely illegible. That makes it technically illegal to use it in any configuration. Sad
DVSA Derek
PostPosted: 18:43 - 07 Feb 2016    Post subject: Reply with quote
We would just ask you to put the flip down.
It's just a job. Don't hold it against me!
PostPosted: 19:12 - 07 Feb 2016    Post subject: Reply with quote
Why?
KnightsFall
PostPosted: 19:43 - 07 Feb 2016    Post subject: Reply with quote
Well I passed my mod1 anyways, cold and all. One step closer. Very Happy
Kept the front down and did not ask to do otherwise. I generally have no problem with it but do quite like to pole around at low speed with it up from time to time.
Does this mean no open faced (with or without visor) then? Is it not sufficient that it simply be a helmet that is legal to wear on the road?
The last post was made 10 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 132.66 Kb
