Push rod fell into engine!!! Help!
rob24
PostPosted: 14:39 - 07 Feb 2016    Post subject: Push rod fell into engine!!! Help! Reply with quote
Ok so I needed to change the cylinder head on my lexmoto vixen 125, all went well with swapping over valves etc, but... When it came to me putting the fucker back together, one of the push rods fell straight through into the engine. What is the best way of getting it out? If I take the cylinder block off will there be enough access to get it out or am I gunna have to split the crankcase? Also any suggestions as to why it fell through in the first place? Cheers
Rob coxon
Itchy
PostPosted: 14:50 - 07 Feb 2016    Post subject: Reply with quote
One of these things?
https://www.amazon.co.uk/SE-Telescopic-Magnetic-Grabber-Black/dp/B000RB3XA6
Pushrods are comparatively big and therefore if it can fall in you can extract it out the same hole... usually.
It's when you drop stuff like shims into the engine. You have to split the engine. IIRC GX thought he'd lost a shim into his engine (turned out it had fallen into his pocket). He ended up tearing the engine apart.
Hahadumball
PostPosted: 21:59 - 07 Feb 2016    Post subject: Reply with quote
Laughing Laughing Laughing Laughing Laughing Laughing Laughing
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Ed Case
PostPosted: 22:25 - 08 Feb 2016    Post subject: Reply with quote
Assuming that the push-rod is steel of course and not ally !. If it is ally but with a steel 'cap' you could have a chance.
PostPosted: 06:48 - 09 Feb 2016    Post subject: Re: Push rod fell into engine!!! Help! Reply with quote
By "engine" I assume you mean combustion chamber? If you can't get it with the magnet on a stick, just whip the head off and get it out, you've already had the head off once, so it should be a breeze.
PostPosted: 08:55 - 09 Feb 2016    Post subject: Reply with quote
I'm guessing that OP has managed to miss the cup on the cam follower and drop the rod down past the gear.
https://cdn.rideapart.com/wp-content/uploads/2012/10/CG125.jpg
So yes, if a magnet on a stick doesn't fish it out, that's a strip down.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:43 - 09 Feb 2016    Post subject: Reply with quote
Having spent far too much time re-shimming modern engines, can you set a date so that we can all come and watch how people recovered from fuck-ups back in the ninteenth century?
Triumph Sprint ST 1050
PostPosted: 23:58 - 09 Feb 2016    Post subject: Reply with quote
Steam, Nobby my friend, steam Thumbs Up
You didn't fuck up with them cause they would kill you.
https://weymouth-dmes.co.uk/Exhibition_06/Beam_engine.jpg
Triumph Trophy Launch Edition
The last post was made 10 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 58.79 Kb
