m11 bolts...
pompousporcup...
PostPosted: 12:50 - 08 Feb 2016    Post subject: m11 bolts... Reply with quote
Looking for ideas around an issue im having. I cannot find m11 bolts in the length i need -_-
long story short, the crash bungs i got from santa did not come with bolts long enough to fit. they don't specifically make crash bungs for the gpz500 so its a case of using one that will fit that were designed for another bike. The bolts that came with them are around 1.5 cms too short for me to consider safe.. ie have adequate thread for the self lock nut
i've looked at finding 7/16 bolts but am still struggling. Am i missing some awesome-o bolt place or do i need to go get these custom made?
yes, they're defo 11mm.. m10 is probably going to have too much play and m12 is unlikely going to fit.
PostPosted: 13:08 - 08 Feb 2016    Post subject: Reply with quote
Check it against the sizes in this table to confirm it is M11 x 1.5.
https://www.roymech.co.uk/Useful_Tables/Screws/Screw_Threads_1.html
Rare as rockinghorse poo though.
7/16 are easy to get. Just make sure you have thje right thread pitch and profile.
https://www.amazon.co.uk/s/?ie=UTF8&keywords=7%2F16+unc+bolts&tag=googhydr-21&index=aps&hvadid=82122795291&hvpos=1s1&hvexid=&hvnetw=g&hvrand=9837818265657924269&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_3zw5e5qhz2_b
Triumph Trophy Launch Edition
Evil Hans
What length are you after?
Until fairly recently most seat belt mounting bolts were 7/16. You could check out safety harness bolts from a motorsport supplier.
PostPosted: 13:20 - 08 Feb 2016    Post subject: Reply with quote
I'm unclear what you need it to be an M11 for?
Which bit of the system requires a bolt this size?
I can't think there'd be anything on a GPZ500 with an M11 thread.
PostPosted: 15:07 - 08 Feb 2016    Post subject: Reply with quote
You sure it isn't an M8 and a spacer?
Suntan Sid
PostPosted: 15:44 - 08 Feb 2016    Post subject: Reply with quote
Or an 8mm bolt and bush!
bladeblaster
PostPosted: 16:00 - 08 Feb 2016    Post subject: Reply with quote
No one makes anything with an M11 fitting, surely?
PostPosted: 16:16 - 08 Feb 2016    Post subject: Reply with quote
In 2006 only, Royal Enfield made a batch of fuel tanks with an M11 fine stub and a collar to fit a 1/4 BSP fuel tap to it. Quite a weak collar.
They must have been laughing into their chipattis when they came up with that one.
pompousporcup...
PostPosted: 16:42 - 08 Feb 2016    Post subject: Reply with quote
its the front engine mount bolt (normally around 320mm) that sits in a rubber bush either side of the frame..
https://www.rg-racing.com/images/Products/large/img360_1.jpg
i have checked with vernier calipers and im sure its 11mm (making it m11 no?) i could be mistaken and it m12.. fuck knows
I'm sure an m10 would fit fine but i'd be worries about play.. spose an m12 could squeeze in the bush fine but might not through the harder rubber of the crash bung
closest thing i found was an old honda head bolt.. which was m11 (well done honda) however i got rid of them when the engine went and for some reason had one in the box 'o bolts.
pompousporcup...
PostPosted: 16:46 - 08 Feb 2016    Post subject: Reply with quote
also, i'd need bolts around 160mm long iirc.. 7/16 anywhere up to 4" are fairly easy to find but anything longer are proving difficult.
whitedevil
PostPosted: 16:55 - 08 Feb 2016    Post subject: Reply with quote
if im looking at the right fiche this suggests they're M10's
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
bladeblaster
PostPosted: 17:08 - 08 Feb 2016    Post subject: Reply with quote
Did you measure the thread or the plain portion?
pompousporcup...
PostPosted: 17:36 - 08 Feb 2016    Post subject: Reply with quote
whitedevil wrote:
fml.
thank you
mines a 92.. the parts page for that doesnt show any info but iirc the frames are the same and the nut for that bolt on the 92 is the same ref number/size.
m10 steels bolts/nuts have been ordered.
Thanks all for the help
The last post was made 10 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 81.6 Kb
