xj 600s Gear problem
rob_rob999
PostPosted: 17:48 - 09 Feb 2016    Post subject: xj 600s Gear problem Reply with quote
Hi All
I have a xj 600s L reg 1993 and just recently it is very hard to get into gear sometimes I have to let the clutch out a bit and it will go into gear then but I have trouble shifting up and down.
I know they suffer with clutch rattle which mine has
I have also noticed when on its stand and I put it into gear and let the clutch out it is ok but when I pull it in the back wheel stops as though the back brake has been applied
Also there is a squealing noise when I operate the clutch coming from the clutch side of the bike could it be the clutch plates are worn ????
Or something more serious
HELP
Thanks Rob
rob_rob999
PostPosted: 19:14 - 09 Feb 2016    Post subject: Reply with quote
Anyone help please
Hahadumball
PostPosted: 21:11 - 09 Feb 2016    Post subject: Reply with quote
it stops the drive to the rear wheel when you pull the clutch in?
thats deffo not right
Rolling Eyes Rolling Eyes
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Stalk
PostPosted: 21:28 - 09 Feb 2016    Post subject: Reply with quote
https://diversionclub.proboards.com
You need this site
Good luck
davebike
PostPosted: 08:19 - 10 Feb 2016    Post subject: Reply with quote
Simple bits
Adjust clutch cable
Is oil clean and at the upper level mark?
Is the gear leaver and linkage moving freely?
Has the bike been standing unused fro more than a week ?
Dave
NC750Xdct + others at work !
davebike1@gmail.com
A100man
PostPosted: 18:50 - 11 Feb 2016    Post subject: Reply with quote
If it stops abruptly (on the stand) when the clutch is pulled in then it sounds like one of your problems is a binding rear brake.
The last post was made 10 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 51.93 Kb
