No spark and starter does not turn over when pushing start..
Dam99
PostPosted: 18:53 - 09 Feb 2016    Post subject: No spark and starter does not turn over when pushing start.. Reply with quote
Hi Guys, Im new to this forum so I'm still learning, I recently bought a 1993 XJ600 Diversion. I bought it for a bargain. Ive started to slowly clean it little by little.Ive changed the starter solenoid because the old one was not working. After this I'm facing two big problems , one of which, being that when I push the start button nothing happens apart form oil light, but when I use a screw driver and touch the both bolts on the solenoid, there is some sparks and the starter turns and tries to fire the engine up with no result.The next big problem is that when the starter turns over I get fuel and air but no spark at the plugs... Any advice would be appreciated.
Thank you
PostPosted: 19:22 - 09 Feb 2016    Post subject: Reply with quote
One of the cut out switches.
Either Killswitch, Clutch or Side Stand. Is the bike in gear?
Dam99
PostPosted: 19:32 - 09 Feb 2016    Post subject: Done the lot. Reply with quote
The bike is in neutral and all the stands are up, I don't think it a kill switch problem to be honest. Thanks for the advice.
PostPosted: 19:35 - 09 Feb 2016    Post subject: Re: Done the lot. Reply with quote
Suit yourself, I'd put money it is though. Thumbs Up
iooi
PostPosted: 19:50 - 09 Feb 2016    Post subject: Reply with quote
Pull clutch in when cranking over Thumbs Up
Dam99
PostPosted: 19:59 - 09 Feb 2016    Post subject: Tried pretty much everything... Reply with quote
Ive done all the kill switches, tried holding in the clutch while cranking over but no spark what so ever.
iooi
PostPosted: 20:11 - 09 Feb 2016    Post subject: Reply with quote
What Volts do you get at the battery?
Standing & when cranking?
When you say no spark. Is that holding a plug against the engine casing? or a guess because its not firing up.
Dam99
PostPosted: 20:17 - 09 Feb 2016    Post subject: When holding the spark Reply with quote
Yeah I get no spark what so over when I touch the spark plug to a metal part of the engine.
Ariel Badger
PostPosted: 20:26 - 09 Feb 2016    Post subject: Reply with quote
Kill switch? Start to bypass all the switches to eliminate a faulty one.
PostPosted: 20:31 - 09 Feb 2016    Post subject: Reply with quote
One of your fuses is blown. The neutral light, horn, brake lights etc are on a different fuse to the ignition.
The oil light is an oil LEVEL light not oil pressure. It will light when cranking to prove the bulb works. If it lights any other time check your oil level.
Wiring diagram attached. The coils and the RUN switch are fed power by the red/white wire. That's the fuse which is blown.
Dam99
PostPosted: 21:26 - 09 Feb 2016    Post subject: Thanks guys... Reply with quote
Thanks guys for the advice, I will try these methods tomorrow, by the way I've checked all the fuses and they seem to be in good order.
Dam99
PostPosted: 21:28 - 09 Feb 2016    Post subject: Reply with quote
Are there any other fuses apart from the one's behind the battery?
PostPosted: 21:29 - 09 Feb 2016    Post subject: Re: Thanks guys... Reply with quote
Check them with a meter, or try swapping two about. Check also the fuse holder to make sure the contacts aren't corroded.
If you have an alarm and the above checks out, suspect the alarm/immobiliser.
Dam99
PostPosted: 21:43 - 09 Feb 2016    Post subject: Thanks Reply with quote
I wil try all the things you mentioned tomorrow and I will let you know tomorrow.
Thanks
Dam99
PostPosted: 13:08 - 10 Feb 2016    Post subject: No luck with the fuses... Reply with quote
Tested every single fuse and they are all in working order.
Dam99
PostPosted: 14:05 - 10 Feb 2016    Post subject: Reply with quote
I have some pictures to show but I don't know how to upload them. Can anybody help please?
PostPosted: 14:41 - 10 Feb 2016    Post subject: Reply with quote
When you go to make a reply, scroll down a bit and click 'add an attachment' button.
Anyway, take your meter and check the voltage at the red/white wires at the coil with the ignition and run switch on.
Dam99
PostPosted: 15:12 - 10 Feb 2016    Post subject: Reply with quote
The picture is too big apparently,where could I find the coil switch?
Dam99
PostPosted: 17:49 - 10 Feb 2016    Post subject: No luck with Coil... Reply with quote
I just tested the Coil for continuity and It has continuity,I really need to get this bike to start ASAP...
PostPosted: 18:29 - 10 Feb 2016    Post subject: Re: No luck with Coil... Reply with quote
Who said continuity? Check the voltage at the red and white wire.
Dam99
PostPosted: 19:37 - 10 Feb 2016    Post subject: No luck with either Reply with quote
I just tried to see, i put my multimeter on 20v and probed the switch, I got 0. I may have done something wrong bearing in mind I'm not that good with electrics.
iooi
PostPosted: 20:01 - 10 Feb 2016    Post subject: Re: No luck with either Reply with quote
What do you get from the battery.
Set on 20V
Red to red, Black to black.
Engine off & then cranking over?
Dam99
PostPosted: 20:01 - 10 Feb 2016    Post subject: No luck with either Reply with quote
Dam99
PostPosted: 20:03 - 10 Feb 2016    Post subject: Battery is brand new Reply with quote
The battery is brand new, i had to purchase one because the bike didn't have one. But I will test tomorrow and let you know.
PostPosted: 21:20 - 10 Feb 2016    Post subject: Re: No luck with either Reply with quote
Probed what switch?
What I'm asking you to do is this:
Find the coils
Remove the red & white wire from a coil.
Turn on ignition
Turn on stop switch
Turn your meter on and put the black probe on the battery minus and the red probe on plug. Make sure it reads 12v or thereabouts.
Now use the red probe to check BOTH sides of ALL of the fuses if you can get at them. They should all read 12v-ish on both sides with the fuse in. If any don't read 12 on both sides the fuse is blown.
Now use the red probe to measure the voltage at the red and white wire you took off the coil. It should be the same as the battery voltage, or a few tenths less. If it reads zero or very low you have no power coming from the red switch on the bars.
The last post was made 10 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 126.47 Kb
