| Dam99 |
 Dam99 Two Stroke Sniffer
| chris-red |
| Dam99 |
| chris-red |
| iooi |
 iooi Super Spammer
 Posted: 19:50 - 09 Feb 2016 Post subject: |
Pull clutch in when cranking over  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Dam99 |
| iooi |
 iooi Super Spammer
 Posted: 20:11 - 09 Feb 2016 Post subject: |
What Volts do you get at the battery?
Standing & when cranking?
When you say no spark. Is that holding a plug against the engine casing? or a guess because its not firing up. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Dam99 |
| Ariel Badger |
 Ariel Badger Super Spammer
 Posted: 20:31 - 09 Feb 2016 Post subject: |
One of your fuses is blown. The neutral light, horn, brake lights etc are on a different fuse to the ignition.
The oil light is an oil LEVEL light not oil pressure. It will light when cranking to prove the bulb works. If it lights any other time check your oil level.
Wiring diagram attached. The coils and the RUN switch are fed power by the red/white wire. That's the fuse which is blown. ____________________ a.k.a 'Geri'
| Dam99 |
| Dam99 |
| Dam99 |
| Dam99 |
| Dam99 |
 Posted: 14:41 - 10 Feb 2016 Post subject: |
When you go to make a reply, scroll down a bit and click 'add an attachment' button.
Anyway, take your meter and check the voltage at the red/white wires at the coil with the ignition and run switch on. ____________________ a.k.a 'Geri'
| Dam99 |
| Dam99 |
| Dam99 |
| iooi |
 iooi Super Spammer
| Dam99 |
| Dam99 |
The last post was made 10 years, 249 days ago. Instead of replying here, would creating a new thread be more useful? |
