| catgate |
 catgate Two Stroke Sniffer
 Posted: 17:33 - 14 Feb 2005 Post subject: |
Only ones I can think of are quite old. Moto Guzzi Convert (large V twin) and the automatic version of the Honda 400 Superdream (they also did an automatic version of the CB750 in the USA). However the newest one would be close to 25 years old.
I would suspect that your best solution might be a more modern engine and then fit it with a race style push button gearbox, but this is likely to provide a fairly harsh gear change and also shorten the gearbox life (although if you used the clutch these problems would be reduced).
| catgate |
| Dom_ |
 Dom_ Points Mean Prizes
 Posted: 00:18 - 15 Feb 2005 Post subject: |
There was a 700cc V Twin Kawasaki quad in the other day at work. It had a grip on the left hand bar with a button on it, press the button and then select what you want either D, N or R. Seemed pretty nippy too, wheelied as soon as you touched the throttle!! It was also brand new.
Hope this helps
heres a link: https://www.kawasaki.co.uk/product.asp?Id=B63FF39331&Sub=4 |
| Robin |
 Robin Scooby Slapper
 Posted: 10:44 - 15 Feb 2005 Post subject: |
If the ankle is a big problem I'd suggest going for one of the more powerful bike engines from a shaft drive model and fitting a Klicktronic gear change. Smaller bike engines in trikes don't work too well as they will be hauling more weight about and power can be lost in the different gearing you might use and driving a diff and axle.
You might even be able to get help with the conversion from NABD if you qualify, worth giving them a ring as they have a wealth of experience in this sort of thing.
www.nabd.org.uk |
| Tarmacsurfer |
| catgate |
| Big Pete |
 Big Pete Spanner Monkey
 Posted: 13:53 - 15 Feb 2005 Post subject: |
It sounds like you need a jockey shift, one variant of which has the a lever that sticks up beside the tank with a normal clutch lever at the top. To shift you grab the lever, squeezing the clutch as you do so, lever forward to go down the box, lever back to go up the box (depending upon how the linkages are set.) release the clutch lever when shifted. If you go down this route make sure the trike doesnt have a huge rake angle because the low speed cornering will be very hard to control with one hand. If you stick with fairly conservative front end geometry you should be fine, its deff worth talking to NABD and also woth looking at 100% biker site (they have a lot of trike riders) and Trikes R us. I would avoid the auto bikes, they are rae (for a reason) and hard to get parts for, you would be better served with something like a GT 750 kwak motor (shaftie) or similar. I would also stick to a shaft drive donor bike, You can use a chain, but its a considerable extra amount of work and the differential ends up being exposed to crap and the weather. ____________________ Trust me, I`m an engineer
GarageOfPower.co.uk |
| catgate |
The last post was made 21 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
