400cc+ auto
catgate
PostPosted: 17:06 - 14 Feb 2005    Post subject: 400cc+ auto Reply with quote
I am seriously considering building a trike scooter suitable for touring, two up, and was wondering about a suitable engine/gearbox. The present scooter/moped system of using the engine/transmission unit as the swinging arm is extremely poor since it totally ignores all conventional wisdom about unsprung weight. I am therefore looking for an engine/gearbox from a conventional m/c but one where the gearbox is auto (I have a funny intermittent ankle problem). It should be a minimum of 400cc but not a great monstrous multicylinder mammoth. I am afraid that my knowledge of power unit availability is limited and so I was hoping that some of the wise BCF members might have some suggestions as to what was "out there" and what sort of price a chap might have to pay.
Any information gladly received.
"Always remember you're unique, just like everyone else."
PostPosted: 17:33 - 14 Feb 2005    Post subject: Reply with quote
Only ones I can think of are quite old. Moto Guzzi Convert (large V twin) and the automatic version of the Honda 400 Superdream (they also did an automatic version of the CB750 in the USA). However the newest one would be close to 25 years old.
I would suspect that your best solution might be a more modern engine and then fit it with a race style push button gearbox, but this is likely to provide a fairly harsh gear change and also shorten the gearbox life (although if you used the clutch these problems would be reduced).
catgate
PostPosted: 23:45 - 14 Feb 2005    Post subject: Reply with quote
To one of my advanced years that is not all that old. I have just given my nephew my "old" T reg (first time round) R100RT that I was using until last spring.
Have you any idea of how thin/thick on the ground these Hondas are? I had an aquaintance who had one in the late 70s? early 80s?, but they seemed fairly rare at that time.
Dom_
Points Mean Prizes
PostPosted: 00:18 - 15 Feb 2005    Post subject: Reply with quote
There was a 700cc V Twin Kawasaki quad in the other day at work. It had a grip on the left hand bar with a button on it, press the button and then select what you want either D, N or R. Seemed pretty nippy too, wheelied as soon as you touched the throttle!! It was also brand new.
Hope this helps Thumbs Up
heres a link: https://www.kawasaki.co.uk/product.asp?Id=B63FF39331&Sub=4
PostPosted: 01:09 - 15 Feb 2005    Post subject: Reply with quote
Not seen one advertised for ages. They were not the quickest thing around, and the Guzzi would probably be a better bet.
Robin
PostPosted: 10:44 - 15 Feb 2005    Post subject: Reply with quote
If the ankle is a big problem I'd suggest going for one of the more powerful bike engines from a shaft drive model and fitting a Klicktronic gear change. Smaller bike engines in trikes don't work too well as they will be hauling more weight about and power can be lost in the different gearing you might use and driving a diff and axle.
You might even be able to get help with the conversion from NABD if you qualify, worth giving them a ring as they have a wealth of experience in this sort of thing.
www.nabd.org.uk
Tarmacsurfer
PostPosted: 11:05 - 15 Feb 2005    Post subject: Reply with quote
Cat, I'm sure you've already tried various methods to cope with the ankle issue, but just in case...
My left ankle is somewhat weak, most of the smaller bones in that foot are fused. This basically means any repetetive flexion starts to tear the ligaments and seriously irritate the joint, I get around this by using a decent pair of bike boots with built up armour on the heel (Sidi Vert 2 at the moment). When changing traditionally gets too painful I just start using the heel to hook the gearbox up.
Other than that, if you're looking at triking (particularly building your own) then surely a hand based gear shift mod is an option and so avoid the issue all together?
I'm immortal. Well, so far.
catgate
PostPosted: 11:52 - 15 Feb 2005    Post subject: Reply with quote
My problem is intermittent ulcers (6" buggers) on both/either ankles. (A present from my dear old mum, bless her)
This is an option I had pondered. From my recollection the first Vespas and Lambrettas had a combined clutch lever and gearchange twistgrip. Are these things still in use on anything? I had thought about the old Triumph slikshift abomination, but they were very iffy, to the point of derision really. My aim was to try to leave my feet free of "duty", with front brake and throttle on the right bar and rear brake on the left.
If I had a prehensile penis it would be quite simple!!! Rolling Eyes
Big Pete
PostPosted: 13:53 - 15 Feb 2005    Post subject: Reply with quote
It sounds like you need a jockey shift, one variant of which has the a lever that sticks up beside the tank with a normal clutch lever at the top. To shift you grab the lever, squeezing the clutch as you do so, lever forward to go down the box, lever back to go up the box (depending upon how the linkages are set.) release the clutch lever when shifted. If you go down this route make sure the trike doesnt have a huge rake angle because the low speed cornering will be very hard to control with one hand. If you stick with fairly conservative front end geometry you should be fine, its deff worth talking to NABD and also woth looking at 100% biker site (they have a lot of trike riders) and Trikes R us. I would avoid the auto bikes, they are rae (for a reason) and hard to get parts for, you would be better served with something like a GT 750 kwak motor (shaftie) or similar. I would also stick to a shaft drive donor bike, You can use a chain, but its a considerable extra amount of work and the differential ends up being exposed to crap and the weather.
Trust me, I`m an engineer
GarageOfPower.co.uk
catgate
PostPosted: 18:24 - 15 Feb 2005    Post subject: Reply with quote
In my youth there were one or two examples of the OEC Duplex steering running about in our area, and I had thought of trying to utilise this principle, but using upsidedown teles. mounted in swivel housings at the points where they are normally clamped into the yolks. (Hopefully a picture of the OEC will accompany this message). The joy of this principle is that the "contact patch" always stays on the line of travel, which can not be said for conventional steering geometry.
All that having been said, unless I find a suitable lump, the project may go with me to the grave. I am aiming at something that is to the old VW trike what the modern scooter is to my late departed R100RT.
The last post was made 21 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 71.65 Kb
