Feeling nervous after fixing your bike?
mudcow007
PostPosted: 17:10 - 11 Feb 2016    Post subject: Feeling nervous after fixing your bike? Reply with quote
Anyone else feel a bit nervous after you have had you bike in bits an you take it out on a test ride?
I find my self checking the filler cap about 12 times after I have topped oil up etc
Maybe just me.....?
anthony_r6
PostPosted: 17:20 - 11 Feb 2016    Post subject: Reply with quote
Nope. I would be a little more apprehensive if I took it to a garage, but generally speaking I'm confident in my own repairs (or at least not stupid enough to ride it if I wasn't confident I had done it correctly)
Don't think I've had an incident due to a bodged repair yet.
I'm off for a 650 mile run this weekend on the Bullet.
Having: Changed the oil pumps, re-routed the crankcase breather, reset the points and timing, stripped and cleaned the carb, fabricated and fitted a new throttle cable, changed the oil, fitted a GPZ clutch lever in place of the standard front brake lever and fitted bar muffs.
What could possibly go wrong?
My bet is on the 5mm allen key I've misplaced turning up irretrievably jammed and in something essential.
Or it shitting out all its oil onto the back tyre then seizing the crank causing it to skid off the road, crash and catch fire.
Hahadumball
PostPosted: 18:08 - 11 Feb 2016    Post subject: Reply with quote
929 Fireblade wrote:
Not in the slightest.
welds are usually quite strong...
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
PostPosted: 18:09 - 11 Feb 2016    Post subject: Reply with quote
Not sure if I'm remembering this correctly but I'm sure I saw a story of you replacing a head gasket in a bus shelter... not 100% sure though Laughing
gorillaonabik...
PostPosted: 18:48 - 11 Feb 2016    Post subject: Reply with quote
Wow, didn't know bus shelters needed head gaskets...
FZR400 (blown engine), ZXR750 (blown engine), ZX6R (accident), CBR600 which had engine issues after which I learned to change gear..., CBR900, CBR924 (stolen), CB600, CB1300 (everything blew up), BMW K1300GT (written off, hit from rear while stationary), Bandit 1250 for a couple of months, Triumph Sprint ST 1050 (nicked) and somewhere in there, I wrote off a Ducati 748 at Cadwell.
Poseidon
PostPosted: 19:07 - 11 Feb 2016    Post subject: Reply with quote
Funny story...
Replaced the brake pads on my car and bungeed the main body of the calliper to the suspension spring. When refitting the calliper, I hung the bungee on the spring for safe keeping whilst I fiddled with the bolts. Took the car out for a test drive (6 miles round the block, I live in the country) and despite the brakes working as they should I kept hearing a clinking sound as I drove along. Stopped, checked all the relevant bolts and such, decided nothing was wrong and kept going. Still this noise persisted. Pulled over again as something was definitely up, but still couldn't find the problem. Decided to take it steady on the 3 miles back home just in case. Suddenly there was a loud clunk, something bounced off the underside of the car at various points before exiting the underneath at the rear of the vehicle. The noise stopped. Figured it must've been a branch or something. Got home, started packing the tools away, but couldn't find the bungee chord anywhere. Then it dawned on me where I'd left it.
Still, no damage done and it was only a cheap bungee anyway.
1977 Honda CG125
Old Git Racing
PostPosted: 19:20 - 11 Feb 2016    Post subject: Reply with quote
No, confident I've done it right. If you're a bit nervous after undoing bolts, taking things off etc get a paint pen and mark the bolts after you've tightened them. You'll be sure they are all done and be able to see if they undo.
OGR
pepperami
PostPosted: 20:33 - 11 Feb 2016    Post subject: Reply with quote
I`ve always been fairly confident in my own work, /I`m still here Smile
Although I did once work on a set of carbs and replaced them on the bike, only for the carbs to leak and the bike catch fire Shocked Laughing
Luckily I was near a jug of water and the kitchen tap.
Pigeon
PostPosted: 20:59 - 11 Feb 2016    Post subject: Reply with quote
I used to be worried, until I had the front brake calliper fall off at 40mph 1.5 miles from home a few days after I fitted new pads. Had forgotten to tighten bolts holding it to the forks.
After that, I bought a torque wrench and now make sure know I've done everything up. Smile
Tamsin
PostPosted: 21:13 - 11 Feb 2016    Post subject: Reply with quote
If I wasn't confident that I'd done it correctly then I wouldn't ride it. I do however have a set test route that I ride after doing anything involving the brakes
craigs23
Mr Muscle
PostPosted: 21:35 - 11 Feb 2016    Post subject: Reply with quote
I must admit to getting a tad wary riding my NC30 after spending a little time working on the thing.
techathy
PostPosted: 21:37 - 11 Feb 2016    Post subject: Reply with quote
You are Phil480 & ICMFP
notbike
PostPosted: 22:34 - 11 Feb 2016    Post subject: Reply with quote
I don't feel weary unless it's something I'm not comfortable with doing or am doing for the first time, then I'll take it for a spin and if it rides okay I don't think much more of it. Most of the time I'm glad knowing I did it properly rather than paid someone to do a half arsed job because it's not their bike.
M.C
PostPosted: 22:54 - 11 Feb 2016    Post subject: Reply with quote
Nope. More alert maybe to see if I've fixed the thing. With brakes obviously I give them a go before hooning off into the distance.
CaNsA
PostPosted: 22:56 - 11 Feb 2016    Post subject: Re: Feeling nervous after fixing your bike? Reply with quote
Not nervous, but more aware of how the bike feels and paying more attention to what area I have worked on.
If I have just done the pads, I'd be paying more attention to how the brakes feel than what I would usually.
RhynoCZ
PostPosted: 23:00 - 11 Feb 2016    Post subject: Reply with quote
The filler cap? Come on OP, I was expecting to read stuff about brakes, wheels, engine rebuilds, etc. Razz
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
Going
PostPosted: 23:56 - 11 Feb 2016    Post subject: Reply with quote
I'm more cautious when I first go for a ride and usually feel like something is wrong or sounds wrong. Doesn't help that the engine sounds like its running on nuts and bolts, or maybe it is Thinking
Nobby the Bastard
Harley Gaydar
PostPosted: 00:04 - 12 Feb 2016    Post subject: Reply with quote
No
I used to assist teaching mechanics to wayward children when I did voluntary work. The first time I drove my car down a hill after using it to teach how disc brakes work (and have them strip and rebuild them) was squeaky bum time though....
Fizzer Thou
PostPosted: 00:15 - 12 Feb 2016    Post subject: Reply with quote
I did have my concerns 40 years ago when I first started to ride a bike and taking a spanner to my 125 for the first time.But now I have absolutely no qualms about having an engine apart and doing big ends and main bearings.So brakes and suspension servicing is an easy job in my eyes
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/2013-04-16173658_zps6dc46b75.jpg
Always have a 'Plan B'
FlightRisk
PostPosted: 00:16 - 12 Feb 2016    Post subject: Reply with quote
No, because now I check the brake pistons are all the way back out before I go for a ride. Shocked Laughing
Honestly I'd be more nervous about handing it over to a mechanic.
Honda CB500S
whitedevil
PostPosted: 00:27 - 12 Feb 2016    Post subject: Reply with quote
I never feel more alive than when im pressing the starter for the first time after a valve adjustment Shocked
I took a bike for a new front tyre fitting, not long after id fitted new pads, we found out one of my calipers bolts were only in finger tight oops Laughing
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
Pigeon
PostPosted: 00:57 - 12 Feb 2016    Post subject: Reply with quote
I'm not Phil480. Smile
I live about 40mins from Whiteways, but along with a slight forgetfulness and now owning a torque wrench, hopefully the similarities end there Wink
The last post was made 10 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 128.18 Kb
