Trouble with oil/ oil level glass
perfect_dooh
PostPosted: 17:07 - 12 Feb 2016    Post subject: Trouble with oil/ oil level glass Reply with quote
Hi everyone.
I am owner of Kawasaki Eliminator 125 ( 2007) , just couple of months in bikes, and lovin it, until trouble has arrived.
I recently checked my oil level, and it was not showing in glass window at all. So I bought new oil to add some, I ended up to add 1 L of oil to it. Level of oil still did not show ( bike was in vertical, also tilting bike on my self, there was no result). As glass is quite white decided maybe ts dirty, foged and oil just not showing through, so I have overfilled it. I spilled all oil out, and it came out only 1.3 L of it.
When I bought bike 3-4 moths back, Oil was between min/max. I have droven now for 600 miles, nearly 1000km, is it actualy posible that bike has "ate" more than 1L oil during 3-4 months, 600 miles? ( Did not found any leakage of oil anywere)
As I still dont know, if oil glass window is ok, I want to clean inside ( any sugustions what best for that?) and change oil, oil filter and see if it helps.
Plus any idea how big a damage I have done for engine, with driving nearly without oil? Lately I have used it only for short 20-30 min rides to work and back.
p.s. as I am new to bikes, and hope I have not created too big damage, as till this everything has worked fine and still does, but for now wont use it until figure out/ solve the problem.
p.s.s. later Ill ad picture with oil window.
Please advice, Martins
iooi
PostPosted: 17:53 - 12 Feb 2016    Post subject: Reply with quote
So short trips on a bike and a white oil window..
Emulsification...
Drain the oil out and fill with fresh. The amount you need to put in is usually stamped on the crankcase.
Might be as well to change filter as well at the same time.
Ariel Badger
PostPosted: 19:24 - 12 Feb 2016    Post subject: Reply with quote
If your bike is drinking oil it could be....
A leak, but you notice leaks.
Piston rings worn
Barrel scored
Valve guides gone potato.
If there is not a pool of oil it will be one of the last three and you will need to do a top end strip to determine what has gone wrong.
perfect_dooh
PostPosted: 19:53 - 12 Feb 2016    Post subject: Reply with quote
Thanks for advice,
here is picture of glass
https://s21.postimg.org/tl9r7fhs3/IMG_20160212_153210.jpg
Lower brown line is not oil level, it stays like that no matter of how bike stands.
Before I forgot to mention, its got only 7.7k on clock.
I will change oil / oil filter, on side it shows 1.4 L, but is that just to reach min/max, or together with oil in system?
Also should window clear, if Ill take it for longer drive?
Piston rings worn
Barrel scored
Is it still safe to take it for a ride, as now I know there is problem with oil, and can follow, how fast oil is leaveing.
And leave striping for couple weeks later?
UrbanRacer
PostPosted: 20:03 - 12 Feb 2016    Post subject: Reply with quote
Offft Shocked
I'd say the head gasket has gone.
Sometimes the window can get a bit misty if you do a lot of short trips but that photo tells me you have oil and coolant mixing. A head gasket failure is the most common cause.
Stop using it
iooi
PostPosted: 20:21 - 12 Feb 2016    Post subject: Reply with quote
Liam_ wrote:
Offft Shocked
Stop using it
Kawasaki Eliminator 125 ( 2007) pic seem to show a air cooled bike Thumbs Up
UrbanRacer
PostPosted: 20:26 - 12 Feb 2016    Post subject: Reply with quote
iooi wrote:
Liam_ wrote:
Offft Shocked
Stop using it
lol cool Laughing Thumbs Up i just seen the oil viewing glass and thought "that's fucked"
just as well others are pay attention
PostPosted: 20:29 - 12 Feb 2016    Post subject: Re: Trouble with oil/ oil level glass Reply with quote
Depends how long. Low enough to affect oil pressure then you are probably going to need to be lucky to avoid wrecking the engine. Plenty of plain bearings in most bike engines and they need a constant supply of pressurised oil to work.
Katy
perfect_dooh
PostPosted: 21:14 - 12 Feb 2016    Post subject: Reply with quote
iooi wrote:
Liam_ wrote:
Offft Shocked
Stop using it
It is air cooled, so is it still bad or it should clear after oil change?
Also is it still alright to drive for a while if I have one of this problems:
Piston rings worn
Barrel scored
Valve guides gone potato?
Do I lose just more oil, or I actualy damageing something by rideing it in this condition?
P.S. Its just, I would better strip bike at my friends place, as I do not have garage, but he lives ~ 70 miles away..
PostPosted: 21:28 - 12 Feb 2016    Post subject: Reply with quote
Seems to have a roller crank so if it's not making nasty noises or the noise hasn't changed suddenly there should be no damage.
You can clean out that window easily enough. Buy a new gasket before you start. Drain the oil out and un-do all the bolts around that cover. Remove the cover and you'll see the oil window from the inside. Get a can of brake cleaner and blast all the creamy emulsion out with the straw that comes in the can.
Now clean up the gasket faces, replace the cover and re-fill with oil.
Definitely, change the oil and filter. Keep an eye on the level every week at least.
Ariel Badger
PostPosted: 23:31 - 12 Feb 2016    Post subject: Reply with quote
It will not do any real damage provided you keep it topped up. if it starts smoking a lot it is time to do a top end rebuild.
jimspeed
PostPosted: 00:26 - 14 Feb 2016    Post subject: Reply with quote
My el 250 used to do this on short runs. Once it had a good run over 10 miles at decent speed it would clear again as the oil got hot enough to vaporise the condensation.
I'd just stick enough oil in now and take it for a good run.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
iooi
PostPosted: 10:22 - 14 Feb 2016    Post subject: Reply with quote
A lot of the condensation is due to oil getting hot and then bike left out in the cold.
So metal engine cools faster than the oil. Thus causing condensation on the internal cases. Which then mixes back into the oil.
Need to keep bike in a warm garage Cool
But other than draining and refilling. A long run is the only way to remove the moisture from the oil.
PostPosted: 10:25 - 14 Feb 2016    Post subject: Reply with quote
My oil-cooled bike doesn't suffer this and it's outside 24/7 in all weathers.
iooi
PostPosted: 10:31 - 14 Feb 2016    Post subject: Reply with quote
Maybe because you do long enough runs everyday to burn the moisture off.
PostPosted: 10:43 - 14 Feb 2016    Post subject: Reply with quote
Possibly, but my point was it's not a problem caused by not keeping a bike in the garage. In fact, the air in a typical garage will be as moist as the air outside.
iooi
PostPosted: 13:32 - 14 Feb 2016    Post subject: Reply with quote
Agree. The only advantage of the garage is that it helps retain the heat from the engine, thus causing less of a temp difference between oil & casings.
All I was doing was pointing out how it happens Thumbs Up
Mine used to do this, despite a 20 mile run each way, when used for work as stored outside there.
But when not used for work. Was never a issue as stored in garage.
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
perfect_dooh
PostPosted: 21:48 - 16 Feb 2016    Post subject: Reply with quote
Thank you for advice and help to everyone, sadly my trouble have not finished..
I today finally received oil/ oil filter by mail. I have drained oil, removed oil filter, to notice that O ring on oil filter cover is severely damaged and not of use.
On internet for different model motorcycles oil filters come together with new O ring + new O ring for oil filler plug , but not mine (Kawasaki eliminator bn 125, 2007). I can’t find any replacements on internet. Is it possible to replace with random same size rubber O ring?
Also I just find out that my oil filler plug is without O ring, is it possible, that is the reason of large lose of oil is because of that(~ 1L on nearly 1000 km?)?
As I mentioned before, I never noticed any pool of oil, but is it possible that leakage was small enough that oil did not drop, but stayed on under parts of motorcycle?
Martins
PostPosted: 21:57 - 16 Feb 2016    Post subject: Reply with quote
The right O ring will work, but needs to be one that is oil proof and can take the heat. Not all can.
The sump plug will normally have a copper (or sometimes aluminium) washer. Check it isn't stuck to the engine or crushed hard on the sump plug. But they will be cheap, and should be easy to get.
Katy
Ariel Badger
PostPosted: 22:08 - 16 Feb 2016    Post subject: Reply with quote
I have never heard of having to reuse an oil filter O ring. Have you contacted whoever it was you got it from?
perfect_dooh
PostPosted: 22:09 - 16 Feb 2016    Post subject: Reply with quote
Thank you, I got one like this , but shouldnt it have also rubber O ring?
p.s. it is not actualy right plug in picture, but same idea, washer is melted together with screw.
PostPosted: 22:27 - 16 Feb 2016    Post subject: Reply with quote
There should be a washer as well (and I really hope it isn't a self tapping sump bolt!)
Katy
perfect_dooh
PostPosted: 23:04 - 16 Feb 2016    Post subject: Reply with quote
I still wait for reply from seller , but honestly I cant find any filter sold with new O rings for my model bike. Also cant find O rings for oil filters sold anywhere seperatly :/
It was not Very Happy , but still missing that separate washer..
Fizzer Thou
PostPosted: 02:17 - 17 Feb 2016    Post subject: Reply with quote
It does look as though there should be a washer on the sump bolt p/n 92065
https://www.fowlersparts.co.uk/parts/4640865/bn125a7f-kmtgalaxy-silver-x1/crankcase
As for the 'O' ring for the oil filter cover,p/n 92055 is a 52.6 x 2.4mm, so may well be a size utilised by other Kawasakis
https://www.fowlersparts.co.uk/parts/4640877/bn125a7f-kmtgalaxy-silver-x1/oil-pump
Always have a 'Plan B'
The last post was made 10 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 136.08 Kb
