| rehmh05 |
 rehmh05 Nova Slayer
 Posted: 02:14 - 13 Feb 2016 Post subject: Binned bandit 650- k8 Help/Advice? |
Hi guys
Binned my bandit 2009 650 k8. Fairly low speed, but I lost front end and control and accelerated before hitting the bump (sideways-can't remember ) which enhanced the impact .....
There is a fair amount of cosmetic damage which I've listed at the end if you so wish to read, otherwise, need help with mechanical aspect of the damage
Main cause of concern
LHS generator cover has been half obliterated.... the coils on inside are slightly damaged. Stator's ring has one section protruding more than the rest....
Apart from the fairings and tank, i didnt think there was some serious damage... so my course of action went as follows;
I deserted the bike as I thought I could replace the generator cover, top engine oil up and ride it home ... Lo and behold; When i get the cover next day and top up the oil; It starts leaking at the bottom. Initially I thought it was the gasket, when I had a closer look, the engine block had a crack!!!! i dont know how serious this is or weather I should panic (its doesn't look big but as soon as i saw its the engine block, i just stood up and not looked at it again -one minute silence please)....
Then I thought; its not leaking much so decided to attempt starting it and it comes with error code: F1. I went into dealer mode and C12 (Crankshaft position sensor error) was on dash. The starter turns but nothing is kicking (firing) - Dont want to bump incase something else breaks
Back to the title: help / advice please. Is the engine block damage fixable and how. And what causing the error, Kind of asking the obvious but is it something inside inside or just the thing hanging with the stator or the stator itself?
Since I couldn't start it and decided to call local recovery van (off gumtree). Waited from 4:45 till 8:20 and the guy turns around and cant make it !!! so bike is not home so no pictures atm....
Here is the damage list to the bike;
Front faring scraped ...
Handle bar bent (RHS seriously bent)
Accelerator handle out of place (moving on handle bar aswell as cut out switch)
Left clutch lever snapped in half...
Exhaust has dents and scrapes but not major ...
RHS rear footpeg snapped out of place
Rear fairing has scraped.
Top box holder broken a bit (haven't had a good look yet)
Tank dented and scraped ____________________ - CBT 31/10/12 - CBR 125 bought 01/11/12
- Theory: 07/11/12 - Mod 1: 19/11/12 - Mod 2: 28/11/12
- 24/08/13 - Bandit 600 |
| talkToTheHat |
| Vincent |
 Vincent Banned
 Posted: 06:32 - 13 Feb 2016 Post subject: |
Need pics for accurate prognosis for crankcase damage. You can sometimes get them repaired for not too much £'s. 'Probably a good idea to check the crank if it looks like it's come into contact with the road and it sounds like you'll need to replace the stator and pick up. If the crank's bent, and/or the cases can't be repaired because the damage is somewhere structural..........the bike's probably more or less scrap, unless you can pick up a resonably priced used motor...sorry
No skin or bone damage then?
PS "engine blocks" are huge, heavy, usually cast iron things in cars, trucks etc  ____________________ Space Is Deep |
| Snowdonia Rider |
 Snowdonia Rider World Chat Champion
 Posted: 09:24 - 13 Feb 2016 Post subject: |
Unlucky mate, very unlucky. Need pics
Did you get any injuries? ____________________ I want your clothes, your boots and your motorcycle.
My YouTube channel: https://www.youtube.com/c/SnowdoniaRider |
| rehmh05 |
 rehmh05 Nova Slayer
| talkToTheHat |
| rehmh05 |
 rehmh05 Nova Slayer
| redeem ouzzer |
| rehmh05 |
 rehmh05 Nova Slayer
 Posted: 15:28 - 14 Feb 2016 Post subject: |
| rehmh05 |
 rehmh05 Nova Slayer
| CaNsA |
 CaNsA Super Spammer
| rehmh05 |
 rehmh05 Nova Slayer
| CaNsA |
 CaNsA Super Spammer
| Vincent |
 Vincent Banned
 Posted: 16:28 - 14 Feb 2016 Post subject: |
You sould be able to get that case repaired, just make sure whoever you get to do it knows what they are doing. Going by work I've had done in the past, I'd guess it'll cost about £100 to £150 with a professional firm, depending on what has to be taken off the engine to do it. The crack doesn't appear to be over any crank journal bolts....which is good
Stator will need replacing fer sure.......£20 second hand. ____________________ Space Is Deep |
| rehmh05 |
 rehmh05 Nova Slayer
| rehmh05 |
 rehmh05 Nova Slayer
| CaNsA |
 CaNsA Super Spammer
| Vincent |
 Vincent Banned
The last post was made 10 years, 18 days ago. Instead of replying here, would creating a new thread be more useful? |
