what did i do wrong?
Ariel Badger
PostPosted: 23:59 - 16 Feb 2016    Post subject: what did i do wrong? Reply with quote
I had to take the exhaust manifold off a Bultaco Sherpa 350 today. It was held on by nuts on four 5mm studs. I used the correct sized socket and applied steady pressure and undid all four nuts without snapping off a stud, rounding a nut or pulling a thread out of the head. Is this a first?
CaNsA
PostPosted: 00:02 - 17 Feb 2016    Post subject: Reply with quote
You have just won BCF.
This forum is now closed.
Itchy
PostPosted: 00:03 - 17 Feb 2016    Post subject: Reply with quote
You've cursed yourself now...
Ariel Badger
PostPosted: 00:09 - 17 Feb 2016    Post subject: Reply with quote
I am not happy with the oil I drained from the gearbox, very little of it and it seems to be contaminated with .....Gearbox.
Islander
PostPosted: 00:55 - 17 Feb 2016    Post subject: Reply with quote
Balance is restored. Razz
TbirdX
PostPosted: 16:08 - 17 Feb 2016    Post subject: Reply with quote
And somewhere a little kitten is spared.
PostPosted: 17:26 - 17 Feb 2016    Post subject: Re: what did i do wrong? Reply with quote
Should have used a cheap shifter, that would have rounded the nuts off nicely.
Ariel Badger
PostPosted: 00:39 - 18 Feb 2016    Post subject: Reply with quote
Rusty as an old horse shoe, I fully expected them to give me grief and I was at the edge of applying pressure before I went plan B when they yealded. I will of course clean up the threads, use new nuts and apply copper grease when I rebuild.
PostPosted: 10:03 - 18 Feb 2016    Post subject: Reply with quote
Does Sir prefer his nuts brassed?
J.M.
PostPosted: 12:22 - 18 Feb 2016    Post subject: Reply with quote
I remember trying to take the exhaust off of my GS500. After much struggling, my dad and I looked at each other and said that it shouldn't be so difficult.
We took an alan key to the bolts for the exhaust on his garage-bound XS750 that hasn't been started for at least 15 years. They moved effortlessly!
2004 R1 & 2018 XSR900
Hahadumball
PostPosted: 12:24 - 18 Feb 2016    Post subject: Reply with quote
apocalypse!!!
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
pepperami
PostPosted: 19:13 - 18 Feb 2016    Post subject: Re: what did i do wrong? Reply with quote
Both my 250 Sherpa and my 250 Pursang gave me no issues in that department, so much so that it didn`t even occur to me that it should of been a possible problem.
Could it be to do with all that two-stroke oil around these areas?
Nobby the Bastard
Harley Gaydar
PostPosted: 20:34 - 18 Feb 2016    Post subject: Reply with quote
yes, so long as they are nicely buffed.
Triumph Sprint ST 1050
Commuter_Tim
PostPosted: 20:49 - 18 Feb 2016    Post subject: Reply with quote
Slightly on topic: I've seen yourself and others mention the brass nut alternative a few times.
With brass being softer than the original metal, would that also mean that any torque settings would also need to be reduced in kind?
(Yes I am too Gorilla handed to operate sans Torque Wrench)
I ride a Bandit 600... badly.
Ariel Badger
PostPosted: 21:59 - 18 Feb 2016    Post subject: Reply with quote
No as the real load is on the stud not the nut.
The last post was made 10 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 95.31 Kb
