good suspension set up garage South East
Val
PostPosted: 11:21 - 17 Feb 2016    Post subject: good suspension set up garage South East Reply with quote
Hi All,
can you recommend to me good suspension set up garage South East, Reading, Bracknell, Camberley area?
I need somebody to change my Fazer fzs 600 rear schock and do good set up as well.
thanks
Matt B
PostPosted: 12:11 - 17 Feb 2016    Post subject: Reply with quote
It really is a simple job to do yourself. Your Fazer has a centre stand I think so even easier.
What shock are you putting on that needs setting up? If you are just replacing with standard all you can do is set the preload and again, that is very simple.
PostPosted: 12:29 - 17 Feb 2016    Post subject: Re: good suspension set up garage South East Reply with quote
Val wrote:
Hi All,
thanks
I recommend GP performance
https://www.gpperformance.co.uk/ It's in Oxfordshire but it's probably the closest place to the area you mention.
Quote Me Happy
PostPosted: 14:57 - 17 Feb 2016    Post subject: Reply with quote
https://www.stevejordanmotorcycles.co.uk
.Bishbash.
PostPosted: 17:07 - 17 Feb 2016    Post subject: Reply with quote
929 Fireblade wrote:
Cowboy outfit.
You're kidding? They used to have an awesome reputation. What's happened to them?
Also, a rear shock, definately do it yourself, it's like 4 or 5 bolts or something rediculous.
If you are really stuck, go to Honda dealership in Crowethorne(nr Cambo), they have always helped me in the past. You don't need anytone specialised to change the rear shock.
Current bike - GSX-R1000 k8
Quote Me Happy
PostPosted: 17:25 - 17 Feb 2016    Post subject: Reply with quote
Bishbash II wrote:
You're kidding?
Since Bodyguard learned to clean his chain he has become an expert on all things technical.
Val
PostPosted: 19:16 - 17 Feb 2016    Post subject: Reply with quote
I am going for Nitron R1 the cheapest version.
The problem is I am lazy and if it is not so much expensive I was thinking garage can do that faster than me. And to grease swingarm pivot bolt and bearings too in the process.
I guess I need to man up and do it myself. I do have changed the chain on my own some tome ago including riveting Very Happy
evoboy
PostPosted: 21:23 - 17 Feb 2016    Post subject: Reply with quote
The shock will most likely come pretty well preset out of the box if you give Nitron your riding weight and the type of riding you do.
APT Motorcycles
PostPosted: 09:46 - 18 Feb 2016    Post subject: Reply with quote
This.
There are also people nearby who will be able to assist you in fitting it if need be. I'm in Basingstoke for example....
inline4
PostPosted: 11:29 - 18 Feb 2016    Post subject: Reply with quote
If you're happy to get your hands dirty then perhaps check out Oval Motorcycle Centre.
My Bandit and Blackbird have been serviced there several times... been going there for 2 years now.
You will know that the job carried out on your motorcycle has been to the correct standard you'll learn to fix your motorcycle too.
Pigeon
PostPosted: 19:29 - 18 Feb 2016    Post subject: Reply with quote
I was going to use them recently, they came back quickly with a good quote. Internets seem very positive and they've been around for a long time.
Harris Performance are north of the M25 and Nitron are Oxfordshire.
Quote Me Happy
PostPosted: 19:32 - 18 Feb 2016    Post subject: Reply with quote
Many moons ago I had my bike set up by them. I'm not sure whether it was placebo or not but it definitely felt better afterwards and had far fewer serious head shakes from the front.
supZ
PostPosted: 20:37 - 18 Feb 2016    Post subject: Reply with quote
surprised https://pdq1.com/ PDQ haven't been mentioned.
I would rate them along side MCT regarding suspension.
Used them to redo my blade settings when I was having some issues with it and, although unrelated, I got them to dynojet my old CBR600F as it had a massive flat spot around 7k and they transformed the bike!! Was smooth as silk after that.
Great guys, more than willing to have a chat and get the work done right
CBR954RR - Daily toy
CBR600RR - Trackbike
TheDonUK
PostPosted: 21:56 - 18 Feb 2016    Post subject: Reply with quote
https://briannicholson.wordpress.com/
Brian of BN Race Science - Twickenham (Good ride in from Camberley)
He races himself and is fairly rapid, nice guy, good attention to detail etc.
Kris
PostPosted: 08:32 - 19 Feb 2016    Post subject: Reply with quote
I had the suspenders and a (basic) fuel remap done at Steve Jordan motorcycles. They had a load of race bikes being prepped when I was there.
Suspension made a difference Thumbs Up Friendly service and free tea.
www.prisonplanet.com
weasley
PostPosted: 09:38 - 19 Feb 2016    Post subject: Re: good suspension set up garage South East Reply with quote
MarJay wrote:
Val wrote:
Hi All,
thanks
I second this recommendation.
Fizzer Thou
PostPosted: 10:10 - 19 Feb 2016    Post subject: Reply with quote
As Marjay has suggested,there are lots of BCF forumites about that would be willing to help Thumbs Up
When I changed the shock on the R1 for the Ohlins I had the swing arm out and regreased everything,which was a good thing that I did as I found one item in particular that looked as though it had been assembled without any grease Shocked
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/BikesBikesBikes348.jpg
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/BikesBikesBikes346.jpg
The shock as it arrived was miles out and after setting up the SAG I tried riding it with the clickers as it came and it was in need of more time before I felt comfortable with it.So I looked at the settings that were suggested in the owners handbook and went along with those,which were different to how I installed it.After adjusting the rebound and high/low speed compression clickers,the handling was transformed.With a few adjustments here and there I was much happier pushing it into and out of corners.But this showed up that the front end was now in need of uprating,so I bought some Ohlins fork springs and fork oil.
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/BikesBikesBikes347.jpg
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture470.jpg
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture483.jpg
Always have a 'Plan B'
The last post was made 10 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 106.08 Kb
