Wheel bearing - spacer 'held' between inner races
smegballs
PostPosted: 15:43 - 22 Feb 2016    Post subject: Wheel bearing - spacer 'held' between inner races Reply with quote
So I've just been changing my wheel bearings.
Old ones came out a treat, took them apart to use as drivers. New bearings seated nicely with the hot/cold treatment.....
Now the centre spacer tube is held between the two inner races rather than being semi-loose, to the degree where you turn one inner race and the other one turns too....
Not sure how this has happened, replacement bearings are good NTN ones and surely tube would have also touched old OE bearings too??
Is is likely to be safe to run like this? The whole point of the spacer tube is to lock the whole lot up solid one the spindle nut is tight anyway.
ssray
PostPosted: 16:41 - 22 Feb 2016    Post subject: Reply with quote
Its ok, usually happens
Evil Hans
PostPosted: 16:44 - 22 Feb 2016    Post subject: Reply with quote
Should be fine, I've had this on car hubs before.
Having the spacer held tight makes it easier to slide the axle through, too Wink
Matt B
PostPosted: 17:18 - 22 Feb 2016    Post subject: Reply with quote
Could have been movement of the spacer before due to wear on the bearings.
smegballs
PostPosted: 17:35 - 22 Feb 2016    Post subject: Reply with quote
Well the wheel spins nicely in the bike and seems to be ok.
It would be a really retarded design to make the spacer too long for the flanges, to the point where you didn't bottom out each bearing on the flange in the hub.
Shop manual seems to show both bearings being wound down on the flanges.
https://i.imgur.com/Sbdjt7G.png
PostPosted: 17:37 - 22 Feb 2016    Post subject: Reply with quote
This is normal. If it didn't happen you would be pre-loading the bearings when you tightened the axle.
FlightRisk
PostPosted: 18:30 - 22 Feb 2016    Post subject: Reply with quote
Exactly. Sounds like it's all in just right. Thumbs Up
Honda CB500S
smegballs
PostPosted: 18:46 - 22 Feb 2016    Post subject: Reply with quote
Yeah it does make sense, it seems to spin fine and no problem with braking etc.
I've only done wheel bearings before years ago when I was 17 so not too experienced (obviously).
Here were the oldies - single side shield so quite likely the original ones that shipped with the bike. Just clocked over to 20k so not too bad really. I thought I better check them on sunday as was going over the bike before going to france this weekend and had heard a intermittent squeal from the front.
They both felt quite gritty, one with noticeable play, which also had very pitted races when I took them apart to make driver to put the new ones in with.
The last post was made 10 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 56.02 Kb
