Dtr soooo slow
DevonDtr
PostPosted: 23:36 - 23 Feb 2016    Post subject: Dtr soooo slow Reply with quote
Hi, so recently bought an 04 dtre 125 and need some advice. Its very slow, tops out at 45 and 50cc peds will easily out accelerate it. Will refuse to hit powerband, it has no rev counter but I would say it's not hitting over 6k in gear. Neutral and it revs to redline Powervalve goes through cleaning process but barely responds to throttle. Has a big one end can fitted too. Every shop says different, carbs, powervalve clogged, cdi unit. hoping you guys can shed some light
Ariel Badger
PostPosted: 00:15 - 24 Feb 2016    Post subject: Reply with quote
You say it has no rev counter.......Then you say it red lines. Explain.
DevonDtr
PostPosted: 00:19 - 24 Feb 2016    Post subject: Reply with quote
In gear and travelling it's sluggish, doesn't like revving even if you pin the throttle back and won't rev high. In neutral it will rev freely, all the way to redline/limiter, can hear it climbing revs easily
Ariel Badger
PostPosted: 00:33 - 24 Feb 2016    Post subject: Reply with quote
Clean carb, new plug and then come back to us.
V2
PostPosted: 00:35 - 24 Feb 2016    Post subject: Reply with quote
Personally I would start with checking that :-
a) you have the correct carb on it and it isn't dirty or clogged
b) you have a good spark there
c) compression test
d) no air leaks between carb and engine
Those are the main things you need to make engines go!
DevonDtr
PostPosted: 00:39 - 24 Feb 2016    Post subject: Reply with quote
Completely forgot about those! I changed the plug day i bought it, it was completly black with carbon. my mechanical knowledge is shocking, how do i take carb off to clean it? On another note, i have been through all electrical connections and they are all spot on
RhynoCZ
PostPosted: 00:47 - 24 Feb 2016    Post subject: Re: Dtr soooo slow Reply with quote
Being what, actually? Thinking
Just from the top of my head: Check the choke is not sticking.
DevonDtr
PostPosted: 00:50 - 24 Feb 2016    Post subject: Reply with quote
Exhaust
RhynoCZ
PostPosted: 00:55 - 24 Feb 2016    Post subject: Reply with quote
Yes, I do know a can is a slang word for a exhaust system, what kind? The factory fitted stock one with which the engine was tuned or some crazy racing super magical stuff bought of fleabay? Smile
DevonDtr
PostPosted: 00:59 - 24 Feb 2016    Post subject: Reply with quote
Made by dep, its my first 2 stroke so not sure if thats great or not Shocked
RhynoCZ
PostPosted: 01:01 - 24 Feb 2016    Post subject: Reply with quote
I see, well normally we tend to put everything back as it was when the motorcycle left the factory and go from there. Thumbs Up
Can you tell the mixture by looking at the spark plug?
DevonDtr
PostPosted: 01:04 - 24 Feb 2016    Post subject: Reply with quote
The old plug was black with carbon, current plug is getting black. Can smell bikes running very rich though, just unsure of how to adjust
RhynoCZ
PostPosted: 01:12 - 24 Feb 2016    Post subject: Reply with quote
Start with the air filter. A clogged filter results in rich mixture. Also check the carburetor and choke functionality. If the choke stays shut, even slightly, it'll also make the mixture rich. Many problems with choke are caused by the wrong length of the choke cable and/or wrong adjustment. If there is not cable, then it might be stuck in the carburetor. (Noob question, you do know when the choke is ON and when OFF, right?)
Next, find the manual to your motorcycle (here on BCF), find carb setting. I'm not sure about your motorcycle particular, but I do believe there is a mixture screw you may adjust the mixture with. The manual will state to turn it full right and then a certain amount of degrees of turning it left (or vice versa).
If that fails, then it's time to taking the carb apart and checking there are the right jet size/s.
An open exhaust system would lead to lean mixture not rich. So I think the problem lies in the air filter and/or carburetor (choke).
DevonDtr
PostPosted: 01:15 - 24 Feb 2016    Post subject: Reply with quote
Have cleaned filter previously. It wont start without choke, but i shall check cable in morning
mudcow007
PostPosted: 09:57 - 24 Feb 2016    Post subject: Reply with quote
Chances are, if its been fitted with a "big one" by the previous owner, they also tried to fuck about with the carb
might be worth speaking to the people over at
https://www.dt125r.co.uk/
DevonDtr
PostPosted: 11:41 - 24 Feb 2016    Post subject: Reply with quote
So there is no cable for carb, the lever just raises a small pipe up and down
Hahadumball
PostPosted: 11:48 - 24 Feb 2016    Post subject: Re: Dtr soooo slow Reply with quote
the brand is called "big one"
i used to have one, theyre shit.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
RhynoCZ
PostPosted: 11:48 - 24 Feb 2016    Post subject: Reply with quote
Good, that is another thing ruled out. Time to find the mixture screw, if there is any. At this point I'd be taking the carburetor off and taking it apart. I think the previous owner was a brainiac and tried to put there bigger jet/s thinking more fuel would me more power. Thumbs Down
I googled: ''2004 yamaha DTR 125 carburetor mixture screw'' and got this picture:
https://i.fixya.net/uploads/images/797ccb7.jpg
DevonDtr
PostPosted: 17:48 - 24 Feb 2016    Post subject: Reply with quote
This is going to sound so stupid, bike would access higher revs whilst off road and wheels spinning so I took cover off powervalve, removed cables and the valve itself didn't want to turn by hand. phoned local shop to take for a look, on the way I went off road, pinned throttle back and valve freed itself, completely transforming the bike. She has gone from only doing 40mph to topping 90 Smile thanks for all the advice guys
Paris2
PostPosted: 17:57 - 24 Feb 2016    Post subject: Reply with quote
Glad its all working, but this...
DevonDtr wrote:
to topping 90 Smile
is unlikely.
Current Ride: Daytona 600
DevonDtr
PostPosted: 18:01 - 24 Feb 2016    Post subject: Reply with quote
Bearing in mind I'm only 11 stone, as I say topping 90, more likely in late 80's but I was too busy looking where I was going
Copycat73
PostPosted: 18:57 - 24 Feb 2016    Post subject: Reply with quote
DevonDtr wrote:
to topping 90 Smile
is unlikely.
mine did ... well an indicated any way ... the problem with the Big one (DEP) system was it pushed the powerband too far up the rev. range to be of 100% practical use ... to get the top speed you needed an uninterupted & unimpeded long run at it... seldom did this happen...
i suspect its been re-jetted and its too big ...
caveat emptor
Irn-Bru
PostPosted: 19:13 - 24 Feb 2016    Post subject: Reply with quote
Mine used to do 85 indicated so wouldn't surprise me, I weigh quite a lot more than the OP Very Happy When I first got mine (07 reg) it used to top out at 65 but I did the powervalve mod thing (earthed a wire behind the headlight) and it turned into a proper beast.
Really miss my DTR(E), was properly clean and unmolested which is unheard of for a DTR.
stevo as b4
PostPosted: 19:21 - 24 Feb 2016    Post subject: Reply with quote
65mph for 10-15'000miles with a restricted 15bhp is better than 85mph for a couple of thousand miles though.
I love how this is OP's first 2stroke, he has been asking lots of mechanics to look/mess with it and all he wants is for the bike to red line with some mad power band in all the gears?
I'd be learning how to strip and re-build engines and buying tools personally before de-restricting and tuning fragile 2stroke engines.
If he cries in a few months after an engine blow up, will the bike even get fixed or will it be eBay'd spares or repairs, or scrapped instead?
DevonDtr
PostPosted: 20:11 - 24 Feb 2016    Post subject: Reply with quote
No, didn't want mad power/red line, just to be able to do 60 on a 60 limit road... plan is to get everything working as it should and get bike back to original. In the 3 weeks of owning it I have learnt many things in regards to brakes, electronics, not so much engine side: / P's. I don't rag it everywhere, and the idea of asking peoples advice is to learn, like today I learnt how to dismantle a power valve, clean a Carb, etc.. as far as Im aware the bike is restricted, and will stay that way. Judging by other dt's condition this one is tidy, no rust or scratches[/img]
The last post was made 10 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 125.25 Kb
