| DevonDtr |
 DevonDtr Derestricted Danger
| Ariel Badger |
 Ariel Badger Super Spammer
| DevonDtr |
| Ariel Badger |
| V2 |
 V2 Nearly there...
| DevonDtr |
| RhynoCZ |
 RhynoCZ Super Spammer
| DevonDtr |
| RhynoCZ |
 Posted: 00:55 - 24 Feb 2016 Post subject: |
Yes, I do know a can is a slang word for a exhaust system, what kind? The factory fitted stock one with which the engine was tuned or some crazy racing super magical stuff bought of fleabay?  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| DevonDtr |
 Posted: 00:59 - 24 Feb 2016 Post subject: |
Made by dep, its my first 2 stroke so not sure if thats great or not  |
| RhynoCZ |
 Posted: 01:01 - 24 Feb 2016 Post subject: |
I see, well normally we tend to put everything back as it was when the motorcycle left the factory and go from there.
Can you tell the mixture by looking at the spark plug? ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| DevonDtr |
| RhynoCZ |
 Posted: 01:12 - 24 Feb 2016 Post subject: |
Start with the air filter. A clogged filter results in rich mixture. Also check the carburetor and choke functionality. If the choke stays shut, even slightly, it'll also make the mixture rich. Many problems with choke are caused by the wrong length of the choke cable and/or wrong adjustment. If there is not cable, then it might be stuck in the carburetor. (Noob question, you do know when the choke is ON and when OFF, right?)
Next, find the manual to your motorcycle (here on BCF), find carb setting. I'm not sure about your motorcycle particular, but I do believe there is a mixture screw you may adjust the mixture with. The manual will state to turn it full right and then a certain amount of degrees of turning it left (or vice versa).
If that fails, then it's time to taking the carb apart and checking there are the right jet size/s.
An open exhaust system would lead to lean mixture not rich. So I think the problem lies in the air filter and/or carburetor (choke). ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| DevonDtr |
| mudcow007 |
 mudcow007 World Chat Champion
 Posted: 09:57 - 24 Feb 2016 Post subject: |
Chances are, if its been fitted with a "big one" by the previous owner, they also tried to fuck about with the carb
might be worth speaking to the people over at
https://www.dt125r.co.uk/
| DevonDtr |
| Hahadumball |
 Hahadumball World Chat Champion
| RhynoCZ |
 Posted: 11:48 - 24 Feb 2016 Post subject: |
Good, that is another thing ruled out. Time to find the mixture screw, if there is any. At this point I'd be taking the carburetor off and taking it apart. I think the previous owner was a brainiac and tried to put there bigger jet/s thinking more fuel would me more power.
I googled: ''2004 yamaha DTR 125 carburetor mixture screw'' and got this picture:
https://i.fixya.net/uploads/images/797ccb7.jpg ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| DevonDtr |
 Posted: 17:48 - 24 Feb 2016 Post subject: |
This is going to sound so stupid, bike would access higher revs whilst off road and wheels spinning so I took cover off powervalve, removed cables and the valve itself didn't want to turn by hand. phoned local shop to take for a look, on the way I went off road, pinned throttle back and valve freed itself, completely transforming the bike. She has gone from only doing 40mph to topping 90 thanks for all the advice guys |
| Paris2 |
 Paris2 Nearly there...
| DevonDtr |
| Copycat73 |
 Copycat73 World Chat Champion
| Irn-Bru |
 Irn-Bru World Chat Champion
 Posted: 19:13 - 24 Feb 2016 Post subject: |
Mine used to do 85 indicated so wouldn't surprise me, I weigh quite a lot more than the OP When I first got mine (07 reg) it used to top out at 65 but I did the powervalve mod thing (earthed a wire behind the headlight) and it turned into a proper beast.
Really miss my DTR(E), was properly clean and unmolested which is unheard of for a DTR. ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
| stevo as b4 |
| DevonDtr |
 Posted: 20:11 - 24 Feb 2016 Post subject: |
No, didn't want mad power/red line, just to be able to do 60 on a 60 limit road... plan is to get everything working as it should and get bike back to original. In the 3 weeks of owning it I have learnt many things in regards to brakes, electronics, not so much engine side: / P's. I don't rag it everywhere, and the idea of asking peoples advice is to learn, like today I learnt how to dismantle a power valve, clean a Carb, etc.. as far as Im aware the bike is restricted, and will stay that way. Judging by other dt's condition this one is tidy, no rust or scratches[/img] |
The last post was made 10 years, 227 days ago. Instead of replying here, would creating a new thread be more useful? |
