honda cbr 125 2007 idles but will not rev
jpsl
PostPosted: 14:29 - 22 Feb 2016    Post subject: honda cbr 125 2007 idles but will not rev Reply with quote
hi all im hoping some one can help i have a cbr 125 2007 now it will start perfect and idle but as soon as you touch the throttle it just sputters and dies,
ive cleaned the carb checked all the pipes for blockages etc
fuel pump pushes fuel through when turning ignition on,
new plug sparks really well checked the reg with multi all is fine
so what on earth is causing this to die any ideas please?
Evil Hans
PostPosted: 15:18 - 22 Feb 2016    Post subject: Reply with quote
Had you changed anything before it stopped working?
Some easy things to try:
Air leak somewhere - check the rubbers around the airbox and carb
Blocked fuel tank vent - try running with the filler cap open.
jpsl
PostPosted: 19:10 - 22 Feb 2016    Post subject: Reply with quote
thanks for reply i just tried the petrol cap off but no difference checked for vacuum leaks = none, even if i open the air box and cover it with my hand it makes no difference just stalls, so im buying a used throttle body with injector and the 2 black boxes on the side as my black boxes are seized on and one of the bolts i managed to get out is really rusty so im hoping one of the black boxes is the issue, will update in couple days when it comes through,
arry
PostPosted: 19:13 - 22 Feb 2016    Post subject: Reply with quote
Did it work fine before you fiddled with it? Genuine question - because it does sound carb set up related
jpsl
PostPosted: 19:56 - 22 Feb 2016    Post subject: Reply with quote
no every thing is standard and not been played with, it just started happening out of the blue :o( it has less then 10k miles on it if it helps ;o)
CBRMAN94
PostPosted: 21:23 - 23 Feb 2016    Post subject: Reply with quote
Something isn't right here.
Carb model CBR125s don't have a fuel pump, it's gravity fed with a vacuum tap. The newer Injection models have pumps but obviously not carbed
Which model do you have?
Honda CBR-RW6 (Sold) - Kawasaki GPZ500s (Sold) - Honda CG125 (Project) - Honda CB750 Cafe racer (Project) - Yamaha FZR400RR
PostPosted: 22:05 - 23 Feb 2016    Post subject: Re: honda cbr 125 2007 idles but will not rev Reply with quote
From threads passim.
Rogerborg wrote:
Fuel injection?
Cuts out at low revs?
#1 Throttle position sensor electronic bullshit.
#2 Lambda probe electronic bullshit.
#3 Leak between the airbox and inlet.
#4 Your plug is fouled or fucked. Let's see it.
Although are you sure there are no leaks? Have you sprayed WD-40 around the throttle body and verified that there's no rise in revs?
Absent that, and if your battery is fully charged (I assume so, if you've gone in with a multimeter) then I would assume "electronic bullshit" in the oxygen or throttle position sensor, and hopefully that's one of the "black boxes" that you're about to replace.
jpsl
PostPosted: 11:09 - 24 Feb 2016    Post subject: Reply with quote
its a 2008 cbr with jc50 throttle body, any way changed the throttle body but now it starts but at like 7000rpms any ideas lol as im not sure how to adjust any thing on this model
jpsl
PostPosted: 11:20 - 24 Feb 2016    Post subject: Reply with quote
never mind my throttle cable holder was a different on the new throttle body, changed it over with my old one and fits perfect and now starts normally and seems to be running perfect, fingers crossed it has solved my issue, thanks people and keep up your good work ;o)
The last post was made 10 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 59.09 Kb
