Stove fans.. gimmick or worth buying
jimspeed
PostPosted: 13:25 - 25 Feb 2016    Post subject: Stove fans.. gimmick or worth buying Reply with quote
OK guys I'm in the middle of buying myself an old cottage which has a decent size logburner in it, I've seen these heat powered fans in shops etc but has anyone used one and are they worth buying for around £50 ?
The place does have lpg heating too but I'd be looking to use the logburner as main heating as I have a good source of wood.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
jimspeed
PostPosted: 13:27 - 25 Feb 2016    Post subject: Reply with quote
https://www.galleonfires.co.uk/new-for-2015-4-blade-heat-powered-stove-fan-eco-friendly-wood-burning-stove-top-fan-our-smallest-fan-yet-185mm-tall/?gclid=Cj0KEQiA6bq2BRC6ppf0_83Z1YIBEiQAgPYNvbZDkzokbGvjh-cm3YqSDBM1yyR2HnFBzGPORgxXOsUaAn4U8P8HAQ
This kind of thing. Cheaper 2 bladed ones on eBay etc
doggone
PostPosted: 14:04 - 25 Feb 2016    Post subject: Reply with quote
We have two stoves and one on each.
The best one by far is a two bladed ecofan, it's a bit more expensive but can be on offer out of season.
The other is a four blade type and for whatever reason it seems to thrash away but not waft out as much warm air.
Are they worth it?
Hard to say - you don't get significantly more heat from the stove, however it does help circulate heat out into the room, especially if it's in a rather inset fireplace.
If you are wanting to move heat through to an area further away like a hallway or upstairs, it will probably have noticeable effect.
It's also ... well .. kind of fun, and does give an indication of when the heat is dropping and another log is needed.
https://s6.postimg.org/zcvpuw1a9/IMG_2579.jpg
J4mes
PostPosted: 14:10 - 25 Feb 2016    Post subject: Reply with quote
We have the ecofan on our burner. It doesn't stop you throwing more logs on, just makes the room even hotter.
Would buy again.
jimspeed
PostPosted: 15:10 - 25 Feb 2016    Post subject: Reply with quote
Sounds like it's worth getting then, and sounds like the ecofan is the one to get so I'll have a look around on the net and see what I can find.. cheers guys. Thumbs Up
grr666
PostPosted: 15:28 - 25 Feb 2016    Post subject: Reply with quote
I've got one, but it's my second.
Fried the first, they will only take heat up to about 350c.
Bought a flue thermometer with my second. Laughing
PostPosted: 15:47 - 25 Feb 2016    Post subject: Reply with quote
They will cause a net reduction of the heat output of your stove. Because thermodynamics.
That doesn't mean they aren't cool and that I don't want one.
If air circulation is an issue for you, it makes some sense. I personally think convection will do it's thing, fan or no.
My house is old enough that I spend all my time trying to REDUCE air circulation.
EDIT: If I was going to put a fan gadget on top of my stove, it would be a sterling engine rather than thermoelectric powered one. Just because.
DrDonnyBrago
PostPosted: 17:31 - 25 Feb 2016    Post subject: Reply with quote
In this scenario, all the energy becomes heat.
Heat > electric > heat+kinetic > heat.
Plus a greater temperature differential between combustion gases and stove body = less heat lost up chimney.
UncleFester
PostPosted: 18:12 - 25 Feb 2016    Post subject: Reply with quote
If you have the proper plate fitted at the base of the chimney around the stove pipe, you should not be losing anything up there other than what goes up the flue.
2017 Z1000SX
DrDonnyBrago
PostPosted: 18:31 - 25 Feb 2016    Post subject: Reply with quote
I meant the exhausted hot gases, so up the flue!
Can you tell I don't have a stove Laughing ?
The last post was made 10 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 65.82 Kb
