Bandit won't start, need advice please
j1mster
PostPosted: 12:55 - 27 Feb 2016    Post subject: Bandit won't start, need advice please Reply with quote
G'day all,
looking for a bit of advice please. All of a sudden my SK5 Bandit won't start. Battery is good (have also tried jump start from car), checked fuse at battery block and ignition fuse, all look OK.
All lights, indicators, hazards, heated grips work. When I press the ignition switch, the only thing that happens is that the lights dim. No sound, click or spark/turn over.
Any advice would be appreciated. Cheers, Jim
GSF650S, XR125L-4, CG125
homo sapiens non urinat in ventum
Nobby the Bastard
Harley Gaydar
PostPosted: 13:13 - 27 Feb 2016    Post subject: Reply with quote
Seized engine....
Triumph Sprint ST 1050
j1mster
PostPosted: 13:36 - 27 Feb 2016    Post subject: Reply with quote
Nobby the Bastard wrote:
Seized engine....
Hope not. No previous signs of Engine issue, ran fine 3 weeks ago. Serviced/MOT'd October (I know that's not a guarantee). less than 19k on the clock
j1mster
PostPosted: 13:38 - 27 Feb 2016    Post subject: Reply with quote
Have just tried 'shorting' starter switch and clutch switch, no difference
Nobby the Bastard
Harley Gaydar
PostPosted: 14:02 - 27 Feb 2016    Post subject: Reply with quote
If the lights dim when you are pressing the switch, I would say that power is getting to the starter motor, but for whatever reason it's not actually turning.
andys675
PostPosted: 14:16 - 27 Feb 2016    Post subject: Reply with quote
voltage?
amps?
monkeybiker
PostPosted: 15:16 - 27 Feb 2016    Post subject: Reply with quote
Could be a fooked stater motor.
Can you push start it?
CaNsA
PostPosted: 15:25 - 27 Feb 2016    Post subject: Reply with quote
FireFaggot wrote:
Try to jump start and report back to me.
E
N
I
U
S
Nobby the Bastard
Harley Gaydar
PostPosted: 16:17 - 27 Feb 2016    Post subject: Reply with quote
Report: 'tard is a fucktard
Robby
Dirty Old Man
PostPosted: 16:37 - 27 Feb 2016    Post subject: Reply with quote
Did you short out the switch or the starter relay?
If you haven't tried shorting the starter relay and the battery is healthy, that is your next job. Peel back the rubber covers on the two poles and short them with a good size screwdriver. Expect lots of sparks and the engine to turn over nicely.
Then try the button again. Sometimes shorting out the relay persuades it to start playing ball. Otherwise replace the relay.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:03 - 27 Feb 2016    Post subject: Reply with quote
I wouldn't have thought that a fucked solenoid would result in dimmed lights. The dimmed lights indicate that the starter motor is drawing power.
j1mster
PostPosted: 17:34 - 27 Feb 2016    Post subject: Reply with quote
andys675 wrote:
voltage?
amps?
don't know, battery in multimeter has gone south so gotta get a new one tomorrow. Would it matter though if trying to start when wired up to running car?
j1mster
PostPosted: 17:37 - 27 Feb 2016    Post subject: Reply with quote
Not tried, not confident/fit enough to run with it. Got a hill close by but be frigged trying to get it back up Confused
Somebody has suggested just giving the starter motor a light tap or two with a hammer to see if it's stuck. Will give that a go first
j1mster
PostPosted: 17:38 - 27 Feb 2016    Post subject: Reply with quote
Cheers Robby, i'll give that a go tomorrow Thumbs Up
Diggs
PostPosted: 18:26 - 27 Feb 2016    Post subject: Reply with quote
If it is the solenoid you'd usually get a clicking noise when you push the starter. Sounds like the starter motor has seized for some reason. If it were me I'd take a couple of mates and bump it down that hill. Sit on the bike, ignition on, second gear with the clutch in, get mates to push you until you have a bit of speed up then let the clutch out. If it doesn't start, get said mates to help you push the bike home again, then take the starter motor out...
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
PostPosted: 18:47 - 27 Feb 2016    Post subject: Reply with quote
Since 2003 most bikes turn the lights off when cranking.
j1mster
PostPosted: 19:03 - 27 Feb 2016    Post subject: Reply with quote
Lights usually dim a bit when starting normally, but not like they are now, almost (but not quite) turning off. When I release the ignition switch they come back bright
j1mster
PostPosted: 19:04 - 27 Feb 2016    Post subject: Reply with quote
time to get on the phone............ Very Happy
bugeye_bob
PostPosted: 19:12 - 27 Feb 2016    Post subject: Reply with quote
clutch switch or side stand switch, clutch switches are very common.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:15 - 27 Feb 2016    Post subject: Reply with quote
Areyou really that stupid or are you just pretending.
You did read the bit about the lights going dim?
A bit like you, obviously...
PostPosted: 23:29 - 27 Feb 2016    Post subject: Reply with quote
Remove the starter feed from the solenoid then press the start button. If the lights don't dim your starter needs a service.
andys675
PostPosted: 13:14 - 28 Feb 2016    Post subject: Reply with quote
sounds like the battery
you say it's ok but have no multimeter
you need to drop test it
my triple's battery was the same, showed good voltage but had no amps due to poor conditioning when new, tried to jump it and nothing
battery with good voltage can still have no amps, no cranking power
Matt B
PostPosted: 17:16 - 28 Feb 2016    Post subject: Reply with quote
But
talkToTheHat
PostPosted: 18:03 - 28 Feb 2016    Post subject: Reply with quote
Try a +ve jump lead directly to the starter motor side of the starter relay, connect the negative to a good earth somewhere in the bike. If all spins, starter relay at fault.
Give the starter motor some percussive maintenance in case it is a stuck brush.
Remove starter motor, place in vice or otherwise hold securely. Attempt to operate with bike/car batteries and jump leads.
If starter motor spins outside of bike but not in bike, it's engine trouble.
If the starter motor wont spin outside bike, you have your culprit.
Bandit. does. everything.
The last post was made 9 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 128.11 Kb
