Anyone with a xj600 in Hampshire that can help?
R1stu
Shrek!
PostPosted: 23:48 - 27 Feb 2016    Post subject: Anyone with a xj600 in Hampshire that can help? Reply with quote
Ok still can't get firing right. So far I have done the follwing
new fuel lines
new carbs striped us cleaned, rebuilt with new jets, gaskets and balanced
new engine
new coils
new caps
new ignition
new fuel tap
the only thing I have not replaced is the fuel pump and cdi. All 4 cylinders are now hot, but only runs on choke and won't go past 4K. Plugs are all sparking, they were black. I can't believe it's the engine.
is there anyone in Hampshire if Dorset that can pop down, and maybe let me try their carbs on my bike? I am going to try and by pass the fuel pump tomorrow see if helps, if not what next?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
temeluchus
PostPosted: 23:56 - 27 Feb 2016    Post subject: Reply with quote
did you replace all of the float valve needles?
Float heights correct? Do the floats float?
R1stu
Shrek!
PostPosted: 00:19 - 28 Feb 2016    Post subject: Reply with quote
Don't think the needles been replaced, I assume the guy rebuilding them, done the float heights. Just want to try another set of carbs from a working bike.n Confused
temeluchus
PostPosted: 00:52 - 28 Feb 2016    Post subject: Reply with quote
https://www.triumphrat.net/photogallery/d/99219-2/abr.jpg
Have a look yourself. Carbs are easy to work on. Pic above is of a worn out needle. Those go and the thing will flood like crazy and refuse to run properly.
R1stu
Shrek!
PostPosted: 01:08 - 28 Feb 2016    Post subject: Reply with quote
I'll take them off again tomorrow, and get the macro lense on it.
Quote Me Happy
PostPosted: 09:43 - 28 Feb 2016    Post subject: Reply with quote
You could just look at them.
R1stu
Shrek!
PostPosted: 19:25 - 28 Feb 2016    Post subject: Reply with quote
right looks like its the carbs again. here is a vid I made 1st thing.
https://www.youtube.com/watch?v=NAoQX2gGGT8&feature=youtube_gdata
then I took the carbs off, jus to check,
https://www.youtube.com/watch?v=_Tfc-ezWyuY&feature=youtube_gdata
after an hour of cleaning out she runs a lot better, dose this knock sound like the clutch rattle? its coming from the back of the engine I am assuming it is the little pin that the xj600 suffers from.
Now to get this thing on the road, just need to order a repair kit for the fuel tap, then insure for a month and then get mot'd
Ive just brought a pan european, so this will be a spare, or will sale off.
a tank of fuel and redex should sort the rest out.
Hahadumball
PostPosted: 19:40 - 28 Feb 2016    Post subject: Reply with quote
they all rattle, if it doesnt rattle walk away its clearly broken
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
temeluchus
PostPosted: 19:51 - 28 Feb 2016    Post subject: Reply with quote
Yup they are pretty rattly even when in fine fettle.
R1stu
Shrek!
PostPosted: 20:13 - 28 Feb 2016    Post subject: Reply with quote
https://www.youtube.com/watch?v=WaImOCh1G6I&feature=youtube_gdata
Robby
Dirty Old Man
PostPosted: 20:17 - 28 Feb 2016    Post subject: Reply with quote
So did all of that shit on the jets accumulate in a short period of time?
If so, your tank must be filthy. Clean it out.
Hahadumball
PostPosted: 20:24 - 28 Feb 2016    Post subject: Reply with quote
thats not a rattle!! thats a damn clunk!
R1stu
Shrek!
PostPosted: 23:00 - 28 Feb 2016    Post subject: Reply with quote
There's been no fuel in the tank in fact the tanks not been on the bike. I just filed the carbs with fuel. It's clunky lol but revs fine now insured both bikes now, so will get it together to get to garage to balance and mot
Tdibs
PostPosted: 19:34 - 29 Feb 2016    Post subject: Reply with quote
That sounds way more violent than the clutch rattle imo, you can quite distinctly tell what the clutch rattle is by putting it in first, listen, then back into neutral and you will hear it rattle unless it has the dowel replaced to kill the rattle.
Something lose or valves possibly (?)
Carvel
PostPosted: 20:16 - 29 Feb 2016    Post subject: Reply with quote
That sounds fucked.
The last post was made 10 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 87.87 Kb
