Long delay between triggering indicator and light coming on
Andy9934
PostPosted: 12:17 - 28 Feb 2016    Post subject: Long delay between triggering indicator and light coming on Reply with quote
I have a Varadero XL 125 which I've had for 6 months.
It's always had a delay between pushing the indicator switch and the light coming on, but recently it's getting to the point where they will often not come on at all even when holding the switch sideways.
Can anyone suggest if this might be the switch itself (WD-40 used to provide a temporary slight improvement) or the relay?
Thanks in advance Smile
Surrey
Honda Varadero XL125
Andy_Pagin
PostPosted: 12:23 - 28 Feb 2016    Post subject: Reply with quote
I would suspect the relay. However if the switch casing comes apart easily it's worth a clean up inside and check for any broken bits.
Taught2BCauti...
PostPosted: 12:27 - 28 Feb 2016    Post subject: Reply with quote
Check that you have the correct wattage for the front and rear bulbs, although if they were wrong, I would expect the lamps to come on as soon as you hit the switch and not flash at all!
A faulty switch would usually cause intermittent faults, so if all the connector and bulb contacts are good and clean, you probably have a duff flasher relay.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Matt B
PostPosted: 17:55 - 28 Feb 2016    Post subject: Reply with quote
I could just be a build up of crud inside the switch. Blast a bit of wd40 in there and work the switch from one side to the other a few times, see if that sorts it.
Itchy
PostPosted: 18:02 - 28 Feb 2016    Post subject: Reply with quote
Mine did this. It would work fine for a bit... then the problem would return...
Andy9934
PostPosted: 18:55 - 28 Feb 2016    Post subject: Reply with quote
Yup, same here. It helped but it doesn't last long at all. When it went in for MOT the mechanic apparently dismantled it and lubricated and it was fixed but it didn't take long at all to regress to being worse than before.
I'll get a new relay and see if it helps.
Thanks, I'll be sure to check back with an answer or more questions Smile
Surrey
Hahadumball
PostPosted: 19:44 - 28 Feb 2016    Post subject: Reply with quote
my vtr does this, most of them do, usually contact cleaner sorts it but it returns so just indicate early.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Andy9934
PostPosted: 16:23 - 13 Mar 2016    Post subject: Reply with quote
Right so I got a new relay and it didn't help at all. Bummer.
So I took the switch apart, and prodded about a bit and the issue was that the spring which resets the switch when you cancel had become weak, and because everything was a bit stiff, it meant that it wasn't pushing the contacts against the switch when triggering the indicator, but going over a bump or sometimes pulling the switch control towards me would.
After removing all crud and giving everything a wiggle it now appears to be working perfectly. Anyone want a varadero relay for a fiver?
Thanks for your help as always BCF Smile
Surrey
Hahadumball
PostPosted: 11:15 - 14 Mar 2016    Post subject: Reply with quote
contact cleaner fixes all Very Happy
with the vtr the cold weather does it Very Happy
The last post was made 10 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 67.93 Kb
