Struggle to start after top end rebuild
Astandane
PostPosted: 09:48 - 29 Feb 2016    Post subject: Struggle to start after top end rebuild Reply with quote
Ok guys, as I'm sure you can tell from the title, I'm struggling to start my GPZ400 (ZX400 1986) after a top end rebuild.
Here is a list of work done:
Piston rings replaced; no work done to bores as ok and budget restraint.
New valve springs, seals and lapped in.
All relevant gaskets and O-rings replaced.
New header pipes to replace rusty old ones.
I've done everything by the manual (Haynes) here; 1000x checked the timing to make sure it's correct and fitted everything as described. Valve clearance ok.
With a fresh battery, the engine will turn over just fine. But there's no 'go'. It's almost there but is just missing something which I can't pin down.
Before the work compression was 125, 125, 110 and 145. Admittedly all cylinders are now only at 90, though this is perfectly consistent across all four. It's been suggested that this is just because of the new rings/old bores, and should still start. I have adjusted the timing since then as it was slightly off by a chain pin but haven't been able to check compression since as it was a borrowed tool form work.
Sparks are nice and blue on crank; gap is correct.
Fuel is flowing to all carburettors which were totally stripped cleaned within the last year.
Ignition coils, leads and spark caps are new. Old plugs but new ones coming in post.
I'm totally out of options here; I've tried spraying other things into the inlet to try and kick start the bike (without flooding everything). It want's to go as I said, and when turning over just keeps getting there but not quite.
Seriously desperate for help!
Jon.
-Edit-
Video links for any interested parties:
https://youtu.be/Ud2JnBUOPGA
https://youtu.be/XNSG9XZVv8k
Kymco Pulsar 125 Suzuki GN 125 Kawasaki ZX400 Honda CBR400RR NC23
PostPosted: 11:42 - 29 Feb 2016    Post subject: Reply with quote
Why did you bother with half a rebuild with those compression results?
Suntan Sid
PostPosted: 11:46 - 29 Feb 2016    Post subject: Reply with quote
Those compression figures are low, an absolute bare minimum should be 100psi.
What does the manual say is a good compression reading?
PostPosted: 11:47 - 29 Feb 2016    Post subject: Reply with quote
That's after the rebuild, they were higher before!
Suntan Sid
PostPosted: 11:59 - 29 Feb 2016    Post subject: Reply with quote
A quick Google doesn't reveal much but one result I found suggests that for this model 110 psi would be a low reading!
PostPosted: 12:06 - 29 Feb 2016    Post subject: Reply with quote
low enough to attempt half a rebuild? If it still ran I can't see why the OP didn't wait save up and and do it properly.
Suntan Sid
PostPosted: 12:29 - 29 Feb 2016    Post subject: Reply with quote
OP, might be worth doing this test mentioned on this website:-
https://www.dansmc.com/compression_test.htm
OK, you have a cylinder that reads low. Is it valves or rings, leaking that compression? A quick, down and dirty test is this. Squirt some oil, maybe a teaspoon's worth, into the cylinder through the spark plug hole. Now run the test again. The oil will hold compression for several turns of the engine. If your retest with oil gives higher compression, you will know the rings are worn. If there is no change in compression, it's the valves that are leaking. If you think it's the valves, it's always a good idea to check the valve tappet clearance. If the valves are tight, they could be leaking compression. If the valves are tight, reset them to the proper clearance and test again. if your compression comes back don't thank your luck, thank Jesus! He just saved you an engine rebuild
VultureZ1300
PostPosted: 13:41 - 29 Feb 2016    Post subject: Reply with quote
Hi did you hone the bores before fitting the new rings? Might explain low readings as new rings won't work on smooth bores,probably smoke as well if you get it running.
Cheers. Vulture
Robby
Dirty Old Man
PostPosted: 14:13 - 29 Feb 2016    Post subject: Reply with quote
By the sound of the description the low compression test results were taken when the timing was out by a tooth.
Now to be honest, it sounds like your ambition exceeds your ability, so diagnosis will be a bit vague seeing as we have to make allowances for mistakes made during the rebuild.
You have fuel to the carbs, you have a spark. You probably have enough compression to fire. This would suggest that the failure to start is to do with timing or a big mixture problem.
So, things to check:
1. Timing. Is it really right? It could be out by a tooth, or by 180 degrees.
2. Ignition timing. Have you mixed up the HT leads (putting ignition timing out by 90 degrees).
3. Fuel. You know its getting to the carbs. Have you messed with them? Are the inlet rubbers in good condition and firmly fitted. If they are loose or split, the air leak will cause trouble. Maybe you removed the covers on the balancing ports during the rebuild and haven't refitted them.
.Chris.
PostPosted: 17:44 - 29 Feb 2016    Post subject: Reply with quote
Assuming yours is the ZX400C2 model, my Haynes manual says compression should be 109-171psi when the engine is hot, with no more than ~15psi difference between cylinders.
Check that you've got the plug leads back on in the right order. Given that 110psi is considered acceptable, I would have thought that the engine would at least run with 90psi compression, provided nothing else is amiss.
Or, sell the bike to me for pennies Razz
Chris
1985 Kawasaki Z550F
MaybeGuy
PostPosted: 12:19 - 01 Mar 2016    Post subject: Reply with quote
Idiots like this are the reason lots of bikes die.
Lots of stuff can be done to confirm shitty rings that don't involve taking the engine apart. You can't just assume "rings" when there are so many variables, but as you've already done it:
Ring gaps? You probably don't know.
compression test with oil? probably not tried.
Piston to bore clearance?
Did you measure the bores before buying the rings? or did you just buy a "ring kit bruv, make ur bike fully sik & hektik".
My prediction is you've bought the wrong rings, and have a massive ring gap.
.Chris.
PostPosted: 17:17 - 01 Mar 2016    Post subject: Reply with quote
Just a thought - you have turned the fuel tap to the 'prime' position, haven't you? The vacuum tap won't supply fuel in the 'on' position unless the engine is running.
What was the reason for the engine work? Was the bike not running properly before?
Chris
1985 Kawasaki Z550F
Ariel Badger
PostPosted: 19:32 - 01 Mar 2016    Post subject: Reply with quote
A squirt of oil down each plug hole will raise your CR.
Astandane
PostPosted: 20:22 - 03 Mar 2016    Post subject: Reply with quote
Ok well to clarify a few raised eyebrows; the reason for the rebuild was due to a total lack of top end power. The bike would struggle to get past 70 on a windy day.
Upon examination this was probably due to the valve springs which were way out of their service limit. However, the cylinder base gasket was also leaking and this was seen as an opportunity to replace the rings anyway.
Bump starting hasn't worked after repeated attempts, and oil down the bores has not affected the compression.
The fuel is definitely reaching carbs and cylinders.
The rings are not incorrect.
Everything is connected properly as I took both photos and have the manual with relevant wiring diagrams. I am however dubious about it's description of setting the cam timing:
Reason being is that, despite following it's instruction in counting chain pins, I cannot get the cam timing marks to line up as described. The difference is not massive, but the inlet is not parallel to the cylinder head. It's been suggested that moving the cam one tooth forward would resolve this, however this obviously goes against the described procedure. Yet, again, the timing marks are not exact as they should be. Advice?
I admit that this is generally new to me but I've followed everything as described in the manual, and I know the bike well enough to replace things such as pipes and what not in the correct place.
Main concern at the moment is getting the timing marks lined up. As I said, I just can't seem to achieve this by following the manual. It described setting the exhaust mark to be between two LINKS, using the pin immediately above it as '1', and then counting back to 43 and 44. IN mark should be between these, but does not lie parallel.
Sorry for the late reply by the way!
Ariel Badger
PostPosted: 21:54 - 03 Mar 2016    Post subject: Reply with quote
You have sparks but are they in the right place? my betting is your ignition timing is way out for some reason.
PostPosted: 22:11 - 03 Mar 2016    Post subject: Reply with quote
Photos of timing marks when in the lined up position please.
Piercee100
PostPosted: 09:58 - 04 Mar 2016    Post subject: Reply with quote
I had the same symptoms on an engine where I failed to spot a tiny nick on an exhaust valve stem. It was a single cylinder scooter though. Have you checked all the valves have been installed correctly?
Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition).
iooi
PostPosted: 10:19 - 04 Mar 2016    Post subject: Reply with quote
Reason being is that, despite following it's instruction in counting chain pins, I cannot get the cam timing marks to line up as described. The difference is not massive, but the inlet is not parallel to the cylinder head.!
So oil has not helped compression. So that means valves or timing is out.
Are you sure you are not 180 out?
bladerunner
PostPosted: 15:28 - 04 Mar 2016    Post subject: Reply with quote
Was wondering if 180 degrees out after he said oil in the bores made no difference to the low CR. I had a Haynes book of lies that did that if you were daft enough to follow the pic's. Or your valve clearances are to tight
Astandane
PostPosted: 23:14 - 04 Mar 2016    Post subject: Reply with quote
Hi guys and thanks again for all the replies.
I'm not going to post pictures as I've managed to sort the timing out, but of course I will detail how this was done.
When taking the engine apart the manual says to turn the crank so that that the '1.4 T' mark is aligned with the crank index mark; this puts the cam shafts in a position so that their alignment marks face outwards with pistons 1&4 at TDC. If you were to rotate the crank again to this position, the alignment marks would point inwards.
It was suggested here and at work that the timing was 180 degrees out. I rotated the crank to the timing mark so that the cam markers pointed inwards, and then removed and reinstalled so that they pointed outwards as is necessary.
The timing marks lined up properly first time, as opposed to before when it seemed impossible.
I'm letting the gasket sealant set overnight before I do any more so I will update tomorrow Smile
A100man
PostPosted: 17:32 - 05 Mar 2016    Post subject: Reply with quote
It's now tomorrow - what you got ?! Smile
Astandane
PostPosted: 20:13 - 05 Mar 2016    Post subject: Reply with quote
Unfortunately just a minor set back; the starter motor clutch has gone. Every time it gets load from the engine it slips. But eBay to the rescue! I guess after 30 years and the recent hard starting, it was about time.
Ariel Badger
PostPosted: 01:31 - 06 Mar 2016    Post subject: Reply with quote
Bump it.
Astandane
PostPosted: 17:03 - 06 Mar 2016    Post subject: Reply with quote
Bike has always been hard to bump, not something I need from a daily ride.
https://youtu.be/BBsIZ89sUrY
I need to know if this is the starter clutch; last thing I need but engine won't turn over via the starter now.
The last post was made 10 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 132.63 Kb
