| Astandane |
 Astandane Nova Slayer
 Posted: 09:48 - 29 Feb 2016 Post subject: Struggle to start after top end rebuild |
Ok guys, as I'm sure you can tell from the title, I'm struggling to start my GPZ400 (ZX400 1986) after a top end rebuild.
Here is a list of work done:
Piston rings replaced; no work done to bores as ok and budget restraint.
New valve springs, seals and lapped in.
All relevant gaskets and O-rings replaced.
New header pipes to replace rusty old ones.
I've done everything by the manual (Haynes) here; 1000x checked the timing to make sure it's correct and fitted everything as described. Valve clearance ok.
With a fresh battery, the engine will turn over just fine. But there's no 'go'. It's almost there but is just missing something which I can't pin down.
Before the work compression was 125, 125, 110 and 145. Admittedly all cylinders are now only at 90, though this is perfectly consistent across all four. It's been suggested that this is just because of the new rings/old bores, and should still start. I have adjusted the timing since then as it was slightly off by a chain pin but haven't been able to check compression since as it was a borrowed tool form work.
Sparks are nice and blue on crank; gap is correct.
Fuel is flowing to all carburettors which were totally stripped cleaned within the last year.
Ignition coils, leads and spark caps are new. Old plugs but new ones coming in post.
I'm totally out of options here; I've tried spraying other things into the inlet to try and kick start the bike (without flooding everything). It want's to go as I said, and when turning over just keeps getting there but not quite.
Seriously desperate for help!
Jon.
-Edit-
Video links for any interested parties:
https://youtu.be/Ud2JnBUOPGA
https://youtu.be/XNSG9XZVv8k ____________________
Kymco Pulsar 125 Suzuki GN 125 Kawasaki ZX400 Honda CBR400RR NC23 |
| chris-red |
| Suntan Sid |
 Posted: 11:46 - 29 Feb 2016 Post subject: |
Those compression figures are low, an absolute bare minimum should be 100psi.
What does the manual say is a good compression reading? ____________________ "Everybody needs money, that's why they call it money!"  |
| chris-red |
| Suntan Sid |
| chris-red |
| Suntan Sid |
 Posted: 12:29 - 29 Feb 2016 Post subject: |
OP, might be worth doing this test mentioned on this website:-
https://www.dansmc.com/compression_test.htm
| Quote: | OK, you have a cylinder that reads low. Is it valves or rings, leaking that compression? A quick, down and dirty test is this. Squirt some oil, maybe a teaspoon's worth, into the cylinder through the spark plug hole. Now run the test again. The oil will hold compression for several turns of the engine. If your retest with oil gives higher compression, you will know the rings are worn. If there is no change in compression, it's the valves that are leaking. If you think it's the valves, it's always a good idea to check the valve tappet clearance. If the valves are tight, they could be leaking compression. If the valves are tight, reset them to the proper clearance and test again. if your compression comes back don't thank your luck, thank Jesus! He just saved you an engine rebuild |
| VultureZ1300 |
 VultureZ1300 Derestricted Danger
| Robby |
 Robby Dirty Old Man
| .Chris. |
 .Chris. World Chat Champion
 Posted: 17:44 - 29 Feb 2016 Post subject: |
Assuming yours is the ZX400C2 model, my Haynes manual says compression should be 109-171psi when the engine is hot, with no more than ~15psi difference between cylinders.
Check that you've got the plug leads back on in the right order. Given that 110psi is considered acceptable, I would have thought that the engine would at least run with 90psi compression, provided nothing else is amiss.
Or, sell the bike to me for pennies  ____________________ Chris
1985 Kawasaki Z550F |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 12:19 - 01 Mar 2016 Post subject: |
Idiots like this are the reason lots of bikes die.
Lots of stuff can be done to confirm shitty rings that don't involve taking the engine apart. You can't just assume "rings" when there are so many variables, but as you've already done it:
Ring gaps? You probably don't know.
compression test with oil? probably not tried.
Piston to bore clearance?
Did you measure the bores before buying the rings? or did you just buy a "ring kit bruv, make ur bike fully sik & hektik".
My prediction is you've bought the wrong rings, and have a massive ring gap. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| .Chris. |
| Ariel Badger |
 Ariel Badger Super Spammer
| Vincent |
 Vincent Banned
| Astandane |
 Posted: 20:22 - 03 Mar 2016 Post subject: |
Ok well to clarify a few raised eyebrows; the reason for the rebuild was due to a total lack of top end power. The bike would struggle to get past 70 on a windy day.
Upon examination this was probably due to the valve springs which were way out of their service limit. However, the cylinder base gasket was also leaking and this was seen as an opportunity to replace the rings anyway.
Bump starting hasn't worked after repeated attempts, and oil down the bores has not affected the compression.
The fuel is definitely reaching carbs and cylinders.
The rings are not incorrect.
Everything is connected properly as I took both photos and have the manual with relevant wiring diagrams. I am however dubious about it's description of setting the cam timing:
Reason being is that, despite following it's instruction in counting chain pins, I cannot get the cam timing marks to line up as described. The difference is not massive, but the inlet is not parallel to the cylinder head. It's been suggested that moving the cam one tooth forward would resolve this, however this obviously goes against the described procedure. Yet, again, the timing marks are not exact as they should be. Advice?
I admit that this is generally new to me but I've followed everything as described in the manual, and I know the bike well enough to replace things such as pipes and what not in the correct place.
Main concern at the moment is getting the timing marks lined up. As I said, I just can't seem to achieve this by following the manual. It described setting the exhaust mark to be between two LINKS, using the pin immediately above it as '1', and then counting back to 43 and 44. IN mark should be between these, but does not lie parallel.
Sorry for the late reply by the way! ____________________
| Ariel Badger |
| Polarbear |
 Polarbear Super Spammer
| Piercee100 |
 Piercee100 Trackday Trickster
| iooi |
 iooi Super Spammer
| bladerunner |
| Astandane |
 Posted: 23:14 - 04 Mar 2016 Post subject: |
Hi guys and thanks again for all the replies.
I'm not going to post pictures as I've managed to sort the timing out, but of course I will detail how this was done.
When taking the engine apart the manual says to turn the crank so that that the '1.4 T' mark is aligned with the crank index mark; this puts the cam shafts in a position so that their alignment marks face outwards with pistons 1&4 at TDC. If you were to rotate the crank again to this position, the alignment marks would point inwards.
It was suggested here and at work that the timing was 180 degrees out. I rotated the crank to the timing mark so that the cam markers pointed inwards, and then removed and reinstalled so that they pointed outwards as is necessary.
The timing marks lined up properly first time, as opposed to before when it seemed impossible.
I'm letting the gasket sealant set overnight before I do any more so I will update tomorrow  ____________________
| A100man |
 A100man World Chat Champion
 Posted: 17:32 - 05 Mar 2016 Post subject: |
It's now tomorrow - what you got ?!  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Astandane |
| Ariel Badger |
| Astandane |
 Posted: 17:03 - 06 Mar 2016 Post subject: |
Bike has always been hard to bump, not something I need from a daily ride.
https://youtu.be/BBsIZ89sUrY
I need to know if this is the starter clutch; last thing I need but engine won't turn over via the starter now. ____________________
The last post was made 10 years, 214 days ago. Instead of replying here, would creating a new thread be more useful? |
