Volume of Kawasaki gpz500s airbox
A.FreeMan
PostPosted: 17:09 - 29 Feb 2016    Post subject: Volume of Kawasaki gpz500s airbox Reply with quote
just a quick question, does anyone know the volume of the kawasaki gpz500s airbox? i'm trying to measure it with water but the water keeps leaking everywhere there are so many gaps!
cheers
mrbox
Wonderwall
PostPosted: 17:41 - 29 Feb 2016    Post subject: Reply with quote
using jelly would be more suitable.
Current bikes: RE Himalayan, Bandit 12, MZ250ES
A.FreeMan
PostPosted: 20:38 - 29 Feb 2016    Post subject: Reply with quote
using jelly? as in the tasty desert? might try salt i guess would work better
PostPosted: 20:46 - 29 Feb 2016    Post subject: Reply with quote
Block up the main holes with gaffa tape. Fill a bucket with water to the brim and place it inside a bigger, empty bucket. Fully immerse the airbox in the water.
The volume of water that is now in the bigger bucket is literally the displacement of the airbox.
A.FreeMan
PostPosted: 20:59 - 29 Feb 2016    Post subject: Reply with quote
doesnt account for the thickness of the casing ^^
Nobby the Bastard
Harley Gaydar
PostPosted: 21:03 - 29 Feb 2016    Post subject: Reply with quote
Fill it with jelly. Take jelly out. Use Stinky's method using the jelly.
Edit: Sand or similar would be better because it would be less likely to leak. The fact that it's not in the shape of the airbox when you stick it in water is irrelevant as you are looking at the volume of sand, which wouldn't change.
Triumph Sprint ST 1050
PostPosted: 21:34 - 29 Feb 2016    Post subject: Reply with quote
Why do you need to measure one that accurtately anyway?
It's the shape, inlet trumpet lengths and baffle positions rather than the overall volume that's the important part. The volume is just to give everything space to happen in.
Evil Hans
PostPosted: 21:38 - 29 Feb 2016    Post subject: Reply with quote
It does if you repeat the exercise without the holes blocked up to find the volume of the casing alone.
Triumph Sprint ST 1050. And it's Red.
The last post was made 10 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 55.76 Kb
