| ragamuffin |
 ragamuffin Borekit Bruiser
| Snod Blatter |
 Snod Blatter Crazy Courier
| ragamuffin |
| Snod Blatter |
| stinkwheel |
 Posted: 16:17 - 28 Feb 2016 Post subject: |
If all the lights work as they should do, it'll pass the MOT.
I have a mate who had a small fire on his bike which took out the centre portion of his loom.
Not to be daunted, he cut the middle 2 feet out of the main loom and scotchlocked individual wires between the two cut ends to join them together again. Because he's a lazy sod, he did it round the outside of the tank.
So imagine a bike with a total birds-nest of random wires of varying thickneses, lengths and colours, not bound together in a loom, running across the outside of the petrol tank with no fewer than 100 scotchlocks joining the whole mess together. That passed an MOT.
That said, you should use proper crimp-on terminals or connector blocks to join your wires together. or solder splice and shrink-tube if both ends are mobile (don't solder a joint where one side is fixed). Use the correct crimping tool. Twisting and taping is a bad bodge and it will fail eventually, leaving you at the side of the road trying to find which bit of the mess of corroded, rotting wiring and slimy PVC tape is the faulty part (the answer is, all of it). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Pjay |
 Pjay World Chat Champion
| chris-red |
| Pjay |
 Posted: 13:23 - 01 Mar 2016 Post subject: |
Crimping is fine, but the connections are prone to water damage over time. I much prefer sealing with heatshrink for this reason, as well as it looking much tidier. Also the Cost is virtually nothing per connection if you already have a soldering iron and solder, as you can buy a loads of the stuff for a few pounds.
https://blog.hellermanntyton.com/wp-content/uploads/2015/04/SA47_DE_02_kleiner1077x669.jpg |
| chris-red |
| stinkwheel |
 Posted: 13:36 - 01 Mar 2016 Post subject: |
Solder joints are fine in theory but you need to be picky where you use them. If they are used in a high movement area, the copper wire either end of the solder can flex, work-harden and break. It's ok if you want to splice a new piece of wire into an older one.
On the whole, crimps are much more reliable
You should always use the type of crimp which also seals the insulation on vehicle wiring. Two crimps per terminal. You can but pre-insulated ones or ones that come with a little silicone sleeve that fits over them (all the big japanese motorcycle manufacturers use these). Using the correct crimping tool is essential to roll the ends into he wire, pliers are NOT a crimping tool.
If I read corrctly what the OP has done, he's cut back the standard loom and joined it back together again.
The best way to have done this would be to cut back each wire in turn to the correct length and fit a new terminal on the end matching the old one.
If you've cut a lump out of the middle. I'd suggest multi-connector spade terminal blocks are now your friend.
I'm going to be doing a bit of wiring soon. Re-doing the rear sub-loom on the enfield. I'll take pictures. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Pjay |
 Posted: 13:49 - 01 Mar 2016 Post subject: |
Oh, I'm not saying that heatshrinking is the best method or the defacto method, I'm just saying that if youre lazy and a tight arse, it offers a water tight seal and will last forever, for next to no cost. Solder cracking isn't an issue as you would twist the wires together and seal with the solder, so its not like the solder is making a weld joint, it is binding and filling any space.
The best and most secure way is to crimp on proper connectors and then heatshrink over the top of these, but it's not something that is needed, as I have had wiring last for over a decade and still go strong with a twist/solder/heatshrink joint.
Also there are some places where a bunch of connectors wont fit back into their routing, due to the sheer size of them in one place, this is never an issue with a heatshrunk wire, as it doesnt grow in size by any noticeable amount. I suppose it's all personal preference, but I just like the cleanliness of my method. |
| ragamuffin |
| stinkwheel |
| Pjay |
| stinkwheel |
| Pjay |
| Bridgehouse |
 Bridgehouse Renault 5 Driver
| Vincent |
 Vincent Banned
| Pjay |
 Posted: 10:01 - 02 Mar 2016 Post subject: |
| Vincent wrote: |
How long would a twisted joint last if it was wrapped in decent heat-shrink? |
I buy my heatshrink from RS, which like the picture posted above has an inner that liquidises and creates a very waterproof seal. Like I said, I have had them last for over a decade on moving equipment without a single fail, so I can vouch for it as a low cost and solid connection.
The main problem, as with anything is doing it right in the first place, making a good twist of wires, then soldering so the solder floods well and then I sheath each individual wire and then where possible, a few together. This makes for very clean and stable connections.
I of course am not saying my way is better than another way that will last the course, I am just saying my way looks nicer and is cheaper and easier to do (for me at least) as crimping has always caused me issues with over crimping and with rerouting of cables once you have a bunch with crimps on. I am today changing my old indicators with LED ones and will be cutting off the supplied bullet connectors and will be soldering and shrinking the connections. This is just for continuity, as the bullets have a decent seal on them, but just dont look as spangly as some shrink wrap. |
| Vincent |
 Vincent Banned
| Pjay |
 Posted: 11:15 - 02 Mar 2016 Post subject: |
Yes that's the stuff. the 3:1 is indeed the shrinkage.
Flexible, flame-retarded heat shrinkable tubing with an integrally bonded adhesive inner lining, designed to provide a permanent encapsulation for protection against moisture. The heat shrink can be used in a wide variety of applications such as electrical wire splices, cable jackets, wire breakouts, strain relief and protection boots for electrical components. Manufactured from an irradiated polyolefin material, the sleeving has a specially formulated adhesive inner wall which melts when heated and is forced into component interstices by the shrinking action of the outer wall. When cooled the sleeving becomes a semi-flexible, tough homogeneous encapsulate with a controlled wall thickness. |
| sickpup |
 sickpup Old Timer
| chris-red |
| bladerunner |
 bladerunner World Chat Champion
 Posted: 13:08 - 03 Mar 2016 Post subject: |
My advice would be solder and heat shrink as well and strap the loom so it cant bounce about. DO NOT use those crappy blue scotch blocks OR the crappy cheap bullet connectors that you get in most hardware/automotive shops OR those bloody horrible choc block connectors if you want your fix to last more than a month or 2 and fall apart when you next come to work on it!!!!
you can get a rather nifty solution thats heatshrink and pre soldered both ends and just requires a hot air gun to use......they use them at the local military jet base but are about 45p a shot
https://www.amazon.co.uk/Waterproof-Solder-Shrink-Connectors-Soldering/dp/B00ESXX74G
quick and easy as well as tidy if you cant solder just make sure your wire is clean ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| stinkwheel |
The last post was made 10 years, 218 days ago. Instead of replying here, would creating a new thread be more useful? |
