Stiff chain link
Piercee100
PostPosted: 09:19 - 04 Mar 2016    Post subject: Stiff chain link Reply with quote
I noticed when lubing my chain this morning that one of the links on my chain was stiff and coming off the rear sprocket at a strange angle. I always keep my chain clean and well lubed and is in no way rusty so was surprised to find a duff link.
Will this free up with more grease and use or is it time for a new chain? More importantly, is this a change now or am I good until next weekend and 300 miles in between?
Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition).
Copycat73
PostPosted: 09:24 - 04 Mar 2016    Post subject: Reply with quote
rust inside is not always visible .. lube up .. keep an eye on it and save for a chain & sprocket kit as these things usualy get worse with time.
caveat emptor
PostPosted: 10:05 - 04 Mar 2016    Post subject: Reply with quote
Clean thoroughly, wiggle it with a couple of pairs of pliers to free it up while continuing to brush and flush out any crud that's in there. Lube. Ride then check it again.
Matt B
PostPosted: 10:29 - 04 Mar 2016    Post subject: Reply with quote
Ghetto quick fix methods aside, if you have a stiff link then it is most likely because an O ring has broken down and you have crud/rust building up on the internal roller where the lubrication has escaped.
If that's the case it will only get worse. 300 miles may be OK if you keep it lubed but look at getting it replaced soon as you can. No matter how much you try and lube the chain it's not going to penetrate and stay in there once an O ring has gone.
PostPosted: 11:21 - 04 Mar 2016    Post subject: Reply with quote
So you're telling me that I haven't been riding with a seized, freed-up and then regularly lubed link on an X-ring chain for over 5,000 miles?
Sorry, my mistake. I should have listened to internets wisdom and binned it.
Piercee100
PostPosted: 17:07 - 04 Mar 2016    Post subject: Reply with quote
I've given it a good clean out with some handy carb cleaner and then packed with grease to free it up but still doesn't seem right. I'll free it off the sprockets over the weekend and see if its anything easily fixed. Thanks peeps.
Matt B
PostPosted: 19:17 - 04 Mar 2016    Post subject: Reply with quote
I'm not telling you anything Roger, because you obviously know better and often refuse to listen to advice unless it fits with your own view.
It's an opinion, take it or leave it.
PostPosted: 22:02 - 04 Mar 2016    Post subject: Reply with quote
See, if I listened to advice to not try something then I'd have binned a perfectly good chain and replaced a bunch of fork seals that just needed cleaning or reseating.
What an idiot I must feel.
mauzo
PostPosted: 22:13 - 04 Mar 2016    Post subject: Reply with quote
If you go at it with a knife it should be possible to get the O-ring out one or both sides. At that point you've just got an unsealed chain; if you oil it when it the chain's hot the oil will find its way inside.
'04 CG125, '07 CBF500
Matt B
PostPosted: 11:07 - 08 Mar 2016    Post subject: Reply with quote
You miss the point. Exactly how much oil leaked out of that fork before you sorted it, how has that affected the damping? Exactly how much crap did you push inside the seal and into the fork internals when you re-seated it? How do you know your chain is perfectly good, did you check all the O/X rings are still in place, have you measured it against the manufacturers wear criteria?
I'm sure that kind of maintenance and puttering into town on the commute that you are doing is fine for you, but that doesn't make it right for everybody. We don't all use our bikes that way and the quick fix is not always the answer.
3000 mile trips through Europe, track days, Santa Pod RWYB and just normal hard riding put massive stress on components, especially when you are pushing high bhp and torque through them. If a chain looks to be breaking down in any way then I'm going to replace it. Quick scrub and a bit of extra lube isn't going to cut it for some people.
Last year we went away to Europe. Two bikes with chains starting to show wear in the form of a stiff link or two when we left. In the matter of a few days both those chains had worn past the limit of the adjusters and one was flapping so much it chewed through the side wall of the rear tyre. No amount of extra lube made a difference, the long fast Autobahn runs and the stresses of the Alpine roads killed them. That's not internet hearsay and opinion, it's fact. A stiff link in a chain can often be an indicator that it needs replacing.
I'm obviously wrong though, how dare I challenge the opinion of Roger, based as it is upon decades of experience riding and maintaining bikes? Rolling Eyes
PostPosted: 11:08 - 08 Mar 2016    Post subject: Reply with quote
OH KNOWS
PostPosted: 11:49 - 08 Mar 2016    Post subject: Reply with quote
But, but. Racers use non o-ring chains oiled with gear oil. Often very thin ones.
Got a couple of mates running post modern classics in club racing. They are quite happy to put a non o-ring 520 chain on a GSXR1100 and utterly horse the arse off it .
OPs list of bikes suggests an over-abundance of horsepower isn't going to be a major issue.
I like using a mix of ATF and paraffin to free up stick stuff. Works wonders on a chain with stiff links.
Matt B
PostPosted: 13:15 - 08 Mar 2016    Post subject: Reply with quote
Due to the reduced friction (caused by the o-rings) and weight. They still wear at an increased rate compared to an O/X ring of the same pitch. The chain can't keep lubrication internally as well without the seals and that leads to increased heat. They maintain and replace chains more frequently.
https://www.did-coltd.com/english/products/images/wr/g001.gif
Running a non o-ring chain, or a chain with damaged/missing o-rings will lead to increased wear.
PostPosted: 13:18 - 08 Mar 2016    Post subject: Reply with quote
Not enough to run down the leg. Maybe a teaspoon? How accurately are forks generally refilled after changing seals? To within a teaspoon of the perfect amount?
I died three times. Crying or Very sad
It's done over 5,000 miles since unstiffening and at 18,000 has now reached the end of its adjustment and the sprockets are hooking. Oh allah, I'm going to have to... spend money. Pale
But, I refused you permission to do so.
Matt B wrote:
[Anecdote]
No, one of us must be wrong. I can't conceive of a world in which different people in different circumstances have different experiences. How would it be possible to make any sweeping generalisations or assert absolute truth? Eh?
Matt B
PostPosted: 13:24 - 08 Mar 2016    Post subject: Reply with quote
Nobody is wrong but there should be balanced advice given.
PostPosted: 13:41 - 08 Mar 2016    Post subject: Reply with quote
Look, just because I took something overly personally and posted an unnecessarily belligerent and non-constructive retort, there's no need to get...
Hang on, I had something prepared for this. It'll be a real zinger when I remember it.
PostPosted: 13:57 - 08 Mar 2016    Post subject: Reply with quote
I've always wondered, see if anybody knows.
If o-ring chains have grease sealed inside them with o-rings. Why do you have to lube them?
If you have to lube them, how do the o-rings klnow they are supposed to let the lube in but not out?
Not calling you out in any way Mark B. But does anyone actually KNOW that a well lubed (for sake of argument, constantly lubed with an automatic oiler) non o-ring chain actually does wear more quickly than on o-ring one? The chart you posted is a fabrication drawn up by an x-ring chain salesman, nothing gives you a clean curve like that, it's not showing actual data.
I once tried to do some empirical research myself but ran into a brick wall after accidentally letting slip what bike the chain was for to the M&P sales guy. He then took it upon himself to send an o-ring chain anyway because "It isn't our policy to supply non o-ring chains for that model of bike." Had to fit it because the old one was broken.
mauzo
PostPosted: 15:57 - 08 Mar 2016    Post subject: Reply with quote
Vincent wrote:
When you lube an o ring chain, you're not lubing the whole link, just the outside plates.
But... the sideplates aren't touching, there's an oring between them.
IM (somewhat limited) E, oiling an oring chain does make the wheel go round a bit smoother; but I can't see why either. I certainly hope the oil isn't finding its way past the oring: it will dissolve and thin the grease.
Also, on a bushed chain, there are two bearing surfaces: between the pin and the bush, behind the orings, and between the roller and the bush. If you follow the normal instructions and only oil between the sideplates I don't see how the roller/bush bearing gets lubricated at all. With an unsealed chain and proper boil-in-the-bag grease, the grease gets under the rollers as well as in around the pins.
Vincent wrote:
Non O ring chains certainly took a dive when Oring ones came out, bit daft really because O-ring chains aren't that much better IMO, by the time the lube's escaped the link pins, the chain is probebly stretched or worn and ready for replacement anyway.
I don't know about that... having to replace the whole chain just because one little bit of rubber has failed seems unnecessary. Certainly with the unsealed chain on my CG, most of the 'stretch' is not metal wear but just the grease escaping; if I boil it in grease I can get about half the length of the adjusters back. I would expect the same to be true of a sealed chain with some failed orings.
Of course, once the grease has escaped, the metal will start to wear quite fast. This is the real disadvantage of orings: you can't replace the grease, even if you wanted to, and while feeding in oil might work for a while it's not going to be as effective as heavy graphite grease.
Vincent wrote:
Best thing to get the most out of your chain...and by far the easiest...is an enclosed chain guard. They may look naf but are very efficient at looking after the chain. IMO, it's usually grit that kills chains prematurely.......and wheelies of course Twisted Evil
Grit and rain.
Are they generally available for bikes that don't come with them as standard?
Robby
Dirty Old Man
PostPosted: 16:34 - 08 Mar 2016    Post subject: Reply with quote
My take on it is that chain lube from a can is a bit like penetrating oil for the first few seconds. It's a mixture of lube and solvent, and the solvent flashes off very quickly, leaving lube behind.
Now that mix of lube and solvent may be thin enough to get past the O rings. We always say not to clean an O ring chain with petrol because it will get past the O rings and rinse out the grease, so by the same reckoning chain lube could past the O rings and lubricate in there.
That line of thought does fall over when I think about automatic chain oilers, unless the chain is getting hot enough to thin the oil and let it penetrate.
The last post was made 9 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 145.53 Kb
