| Piercee100 |
 Piercee100 Trackday Trickster
| Copycat73 |
 Copycat73 World Chat Champion
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:05 - 04 Mar 2016 Post subject: |
Clean thoroughly, wiggle it with a couple of pairs of pliers to free it up while continuing to brush and flush out any crud that's in there. Lube. Ride then check it again. ____________________ Biking is 1/20th as dangerous as horse riding.
| Matt B |
 Matt B World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:21 - 04 Mar 2016 Post subject: |
So you're telling me that I haven't been riding with a seized, freed-up and then regularly lubed link on an X-ring chain for over 5,000 miles?
Sorry, my mistake. I should have listened to internets wisdom and binned it. ____________________ Biking is 1/20th as dangerous as horse riding.
| Piercee100 |
| Matt B |
| Vincent |
 Vincent Banned
| Rogerborg |
 Rogerborg nimbA
| mauzo |
 mauzo Nova Slayer
| Matt B |
 Posted: 11:07 - 08 Mar 2016 Post subject: |
| Rogerborg wrote: | See, if I listened to advice to not try something then I'd have binned a perfectly good chain and replaced a bunch of fork seals that just needed cleaning or reseating. |
You miss the point. Exactly how much oil leaked out of that fork before you sorted it, how has that affected the damping? Exactly how much crap did you push inside the seal and into the fork internals when you re-seated it? How do you know your chain is perfectly good, did you check all the O/X rings are still in place, have you measured it against the manufacturers wear criteria?
I'm sure that kind of maintenance and puttering into town on the commute that you are doing is fine for you, but that doesn't make it right for everybody. We don't all use our bikes that way and the quick fix is not always the answer.
3000 mile trips through Europe, track days, Santa Pod RWYB and just normal hard riding put massive stress on components, especially when you are pushing high bhp and torque through them. If a chain looks to be breaking down in any way then I'm going to replace it. Quick scrub and a bit of extra lube isn't going to cut it for some people.
Last year we went away to Europe. Two bikes with chains starting to show wear in the form of a stiff link or two when we left. In the matter of a few days both those chains had worn past the limit of the adjusters and one was flapping so much it chewed through the side wall of the rear tyre. No amount of extra lube made a difference, the long fast Autobahn runs and the stresses of the Alpine roads killed them. That's not internet hearsay and opinion, it's fact. A stiff link in a chain can often be an indicator that it needs replacing.
I'm obviously wrong though, how dare I challenge the opinion of Roger, based as it is upon decades of experience riding and maintaining bikes?  ____________________ stinkwheel: He had an animated .gif of a cat performing fellatio. It's not socially acceptable. It can have real life adverse effects on other people. |
| chris-red |
 Posted: 11:08 - 08 Mar 2016 Post subject: |
| Matt B wrote: | | Rogerborg wrote: | See, if I listened to advice to not try something then I'd have binned a perfectly good chain and replaced a bunch of fork seals that just needed cleaning or reseating. |
I'm obviously wrong though, how dare I challenge the opinion of Roger, based as it is upon decades of experience riding and maintaining bikes?  |
OH KNOWS ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| stinkwheel |
 Posted: 11:49 - 08 Mar 2016 Post subject: |
But, but. Racers use non o-ring chains oiled with gear oil. Often very thin ones.
Got a couple of mates running post modern classics in club racing. They are quite happy to put a non o-ring 520 chain on a GSXR1100 and utterly horse the arse off it .
OPs list of bikes suggests an over-abundance of horsepower isn't going to be a major issue.
I like using a mix of ATF and paraffin to free up stick stuff. Works wonders on a chain with stiff links. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Matt B |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:18 - 08 Mar 2016 Post subject: |
| Matt B wrote: | Exactly how much oil leaked out of that fork before you sorted it, |
Not enough to run down the leg. Maybe a teaspoon? How accurately are forks generally refilled after changing seals? To within a teaspoon of the perfect amount?
| Matt B wrote: | how has that affected the damping? |
I died three times.
| Matt B wrote: | How do you know your chain is perfectly good |
It's done over 5,000 miles since unstiffening and at 18,000 has now reached the end of its adjustment and the sprockets are hooking. Oh allah, I'm going to have to... spend money.
| Matt B wrote: | If a chain looks to be breaking down in any way then I'm going to replace it. |
But, I refused you permission to do so.
No, one of us must be wrong. I can't conceive of a world in which different people in different circumstances have different experiences. How would it be possible to make any sweeping generalisations or assert absolute truth?  ____________________ Biking is 1/20th as dangerous as horse riding.
| Matt B |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:41 - 08 Mar 2016 Post subject: |
Look, just because I took something overly personally and posted an unnecessarily belligerent and non-constructive retort, there's no need to get...
Hang on, I had something prepared for this. It'll be a real zinger when I remember it. ____________________ Biking is 1/20th as dangerous as horse riding.
| stinkwheel |
 Posted: 13:57 - 08 Mar 2016 Post subject: |
I've always wondered, see if anybody knows.
If o-ring chains have grease sealed inside them with o-rings. Why do you have to lube them?
If you have to lube them, how do the o-rings klnow they are supposed to let the lube in but not out?
Not calling you out in any way Mark B. But does anyone actually KNOW that a well lubed (for sake of argument, constantly lubed with an automatic oiler) non o-ring chain actually does wear more quickly than on o-ring one? The chart you posted is a fabrication drawn up by an x-ring chain salesman, nothing gives you a clean curve like that, it's not showing actual data.
I once tried to do some empirical research myself but ran into a brick wall after accidentally letting slip what bike the chain was for to the M&P sales guy. He then took it upon himself to send an o-ring chain anyway because "It isn't our policy to supply non o-ring chains for that model of bike." Had to fit it because the old one was broken. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Vincent |
 Vincent Banned
 Posted: 15:28 - 08 Mar 2016 Post subject: |
My take on it is that the idea of the O ring isn't just to keep the lube inside the link pins but also to keep grit and crud out. For that reason they should last longer....but only if you let grit stay on a non- oring chain by not cleaning it. When you lube an o ring chain, you're not lubing the whole link, just the outside plates.
Non O ring chains certainly took a dive when Oring ones came out, bit daft really because O-ring chains aren't that much better IMO, by the time the lube's escaped the link pins, the chain is probebly stretched or worn and ready for replacement anyway. It's all about wether or not you want to have to maintain the chain. O rings are definitely easier to lube and clean as you don't have to get the grit from the link pin rollers when doing so.
Best thing to get the most out of your chain...and by far the easiest...is an enclosed chain guard. They may look naf but are very efficient at looking after the chain. IMO, it's usually grit that kills chains prematurely.......and wheelies of course  ____________________ Space Is Deep |
| mauzo |
 mauzo Nova Slayer
 Posted: 15:57 - 08 Mar 2016 Post subject: |
| Vincent wrote: | When you lube an o ring chain, you're not lubing the whole link, just the outside plates. |
But... the sideplates aren't touching, there's an oring between them.
IM (somewhat limited) E, oiling an oring chain does make the wheel go round a bit smoother; but I can't see why either. I certainly hope the oil isn't finding its way past the oring: it will dissolve and thin the grease.
Also, on a bushed chain, there are two bearing surfaces: between the pin and the bush, behind the orings, and between the roller and the bush. If you follow the normal instructions and only oil between the sideplates I don't see how the roller/bush bearing gets lubricated at all. With an unsealed chain and proper boil-in-the-bag grease, the grease gets under the rollers as well as in around the pins.
| Vincent wrote: | Non O ring chains certainly took a dive when Oring ones came out, bit daft really because O-ring chains aren't that much better IMO, by the time the lube's escaped the link pins, the chain is probebly stretched or worn and ready for replacement anyway. |
I don't know about that... having to replace the whole chain just because one little bit of rubber has failed seems unnecessary. Certainly with the unsealed chain on my CG, most of the 'stretch' is not metal wear but just the grease escaping; if I boil it in grease I can get about half the length of the adjusters back. I would expect the same to be true of a sealed chain with some failed orings.
Of course, once the grease has escaped, the metal will start to wear quite fast. This is the real disadvantage of orings: you can't replace the grease, even if you wanted to, and while feeding in oil might work for a while it's not going to be as effective as heavy graphite grease.
| Vincent wrote: | Best thing to get the most out of your chain...and by far the easiest...is an enclosed chain guard. They may look naf but are very efficient at looking after the chain. IMO, it's usually grit that kills chains prematurely.......and wheelies of course  |
Grit and rain.
Are they generally available for bikes that don't come with them as standard? ____________________ '04 CG125, '07 CBF500 |
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
| Robby |
 Robby Dirty Old Man
| Vincent |
 Vincent Banned
The last post was made 9 years, 334 days ago. Instead of replying here, would creating a new thread be more useful? |
