YBR 125 misfiring
Korlad
PostPosted: 14:43 - 07 Mar 2016    Post subject: YBR 125 misfiring Reply with quote
Just put new carb on my '05 YBR, new plug and battery. Misfires badly and fouls plug very fast. Using lots of gas too. I'm not much of a mechanic. Any suggestions for getting her running right? I'm on a remote island and parts are hard to come by.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:48 - 07 Mar 2016    Post subject: Reply with quote
Why did you put a new carb on it?
Triumph Sprint ST 1050
Korlad
PostPosted: 21:32 - 07 Mar 2016    Post subject: Reply with quote
Unexpected lengthy trip to the states and it got gunked up. New carb is half what a rebuild kit costs. Orings and such are always a problem. When I returned it had started, but the jet needle stuck and flooded the crankcase and air filter with gas on the very short trip around the block. (Yes, I changed the oil). When I saw how bad the 'rings were, I just ordered a new carb. Parts are a bitch in this country.
Fin
PostPosted: 22:02 - 07 Mar 2016    Post subject: Re: YBR 125 misfiring Reply with quote
Korlad wrote:
Any suggestions for getting her running right?.
Learn the basics of a carburettor and how the adjustments work. Do some research on, 'BRAND NEW CARB DONT WORK WTF, I REPLACED IT, IT SHUD WORKEST'.
Commuter_Tim
PostPosted: 22:53 - 07 Mar 2016    Post subject: Reply with quote
Korlad wrote:
...I just ordered a new carb. Parts are a bitch in this country.
Where did you source said carb? Thinking
I would be questioning if it has the correct jet sizing or if it is even the correct carb for starters.
If the only problem with the old carb was the rubber seals, clean it and switch the "new" seals over to your old carb?
Learning how to clean carbs is fundamental brah.
I ride a Bandit 600... badly.
Korlad
PostPosted: 23:15 - 07 Mar 2016    Post subject: Reply with quote
I CAN rebuild a carb. But getting the new jets, needle and seat, orings, and the basics that you replace during a proper rebuild costs TWICE what a new carb does.
This definitely sounds like a carb issue? I'm concerned that the gas in the oil may have created issues in the cylinder perhaps?
RhynoCZ
PostPosted: 23:28 - 07 Mar 2016    Post subject: Reply with quote
If you can rebuild the carb, then next time, just take it apart and clean it. You nearly never need brand new parts to clean the carb. Buy a carburetor cleaner and have some fun.
No, you have not damaged anything around by swapping the carb. The petrol in the oil issue must have been there earlier. Although, if the float was stuck and the fuel tap was set to ON, it could leaked though the carb into the engine.
Korlad
PostPosted: 23:33 - 07 Mar 2016    Post subject: Reply with quote
I live in the tropics and our gas sux. Combine tropical heat with that and orings don't last here. I've lived here for 17 years and know how rubber deteriorates. I DID take it apart before I ordered a new one. If anyone has any suggestions on what I might try to get the bike running better, as opposed to bashing my meager mechanical abilities, I'd be beholden. I've adjusted the idle stop screw down and the throttle cable is at the correct tension. Main jet adjusting screw next? Again, is this definitely a carb issue?
Ariel Badger
PostPosted: 23:42 - 07 Mar 2016    Post subject: Reply with quote
It is 100% carb. Are the jets correct? Is it the right carb?
Korlad
PostPosted: 23:44 - 07 Mar 2016    Post subject: Reply with quote
It's the right carb for this bike. Looks just like the one I took off. How it's jetted, dunno?
Commuter_Tim
PostPosted: 00:02 - 08 Mar 2016    Post subject: Reply with quote
Jets typically have their numbers engraved into them.
Only way to tell is crack that carb open again.
Nobby the Bastard This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Korlad
PostPosted: 17:53 - 08 Mar 2016    Post subject: Reply with quote
Can YOU reel off the numbers of YOUR carbs"s jet?
Nobby the Bastard
Harley Gaydar
PostPosted: 18:04 - 08 Mar 2016    Post subject: Reply with quote
No, but if I were to change all 4 of the carbs on my exup, I'd make sure that the replacements had exactly the same jetting.
Note that I said "if". I would probably clean out teh old ones first and only spend out for a new one when it became absolutely necessary.
Korlad
PostPosted: 18:08 - 08 Mar 2016    Post subject: Reply with quote
Did you not read the entire thread? Particularly in reference to the price of parts on a small island in the Bahamas? I'm just looking for some help...getting the carb I have tuned, if that's the problem. I'm not an ace mechanic and I had this idea that folks on the forum might share their knowledge and experience. If I WAS an ace mechanic, I wouldn't need any help.
sickpup
Old Timer
PostPosted: 18:16 - 08 Mar 2016    Post subject: Reply with quote
Well I was amused. Thumbs Up Wink
Korlad
PostPosted: 18:23 - 08 Mar 2016    Post subject: Reply with quote
So when you buy a new carb, you pull the jets and check the numbers against the one you removed???
Nobby the Bastard
Harley Gaydar
PostPosted: 18:26 - 08 Mar 2016    Post subject: Reply with quote
Yes, I did.
They did. They said clean the old one with carb cleaner
Korlad
PostPosted: 18:39 - 08 Mar 2016    Post subject: Reply with quote
And replace the bad orings with what?
Commuter_Tim
PostPosted: 19:21 - 08 Mar 2016    Post subject: Reply with quote
Commuter_Tim wrote:
...and switch the "new" seals over to your old carb?
Or alternatively take the jets out of the old carb and put in the new?
If nothing else, either of the above will help diagnostically.
Absolutely.
Korlad
PostPosted: 19:35 - 08 Mar 2016    Post subject: Reply with quote
When I have rebuilt other carburetors in the past, the rebuild kits usually include new jets, orings and gasket. To assume that the jets are fine after a few years in the tropics is not, IMHO, wise. This carb has a main jet adjustment screw. Think I'll try that before I build frankencarb.
Our gas here can be questionable as well. May drain the tank and refuel. We had a bad hurricane last fall and word is that some stations got water in their tanks.
I'm just not certain that such a simple carb could have arrived new with the wrong jets. Does that happen often?
RhynoCZ
PostPosted: 19:43 - 08 Mar 2016    Post subject: Reply with quote
It could, take off the carburetor that's on the motorcycle at the moment, take off the carb bowl and check for any slime in there. If you find slime, even slime balls, then you've got water in the fuel. Do you run a fuel filter?
EDIT: Water in fuel won't cause misfiring, it'll only create slimeballs in the bowl of the carburetor, that gets sucked into the jet under load, blocking it.
Fin
PostPosted: 19:44 - 08 Mar 2016    Post subject: Reply with quote
It's not definitely a carb issue, could be inlet, wrong air filter or battery/spark problems but from what you've said it sounds like a carb issue.
If you had some carb cleaner you could spray it on the intake/inlet manifold to check Laughing
Vincent 2
PostPosted: 19:55 - 08 Mar 2016    Post subject: Reply with quote
Hi, maybe your situation and weather might be some of the cause see below
and the site can be found at
https://www.iwt.com.au/mikunicarb.htm
Korlad
PostPosted: 20:07 - 08 Mar 2016    Post subject: Reply with quote
Although it says the correction factor for the current air temps is .98 (no change in jet sizes), that site has a ton of good info. Thank you very much!
The last post was made 10 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 125.49 Kb
