False neutral and solid shift lever, advice?
NJD
PostPosted: 23:26 - 08 Mar 2016    Post subject: False neutral and solid shift lever, advice? Reply with quote
Hey ho its off to work we.. oh wait no its not.. and we're back on our way.
So my bike has a few irritating habits recently;
(1) Its becoming more common that I'll end up getting a false neutral (mainly between 1st and 2nd) at least once every ride (and mainly from a dead stop).
(2) Between any given gears and at random times the bike wont always engage (upon first attempt, has always done on the second) the next gear up when attempting to upshift and instead will just jolt forward and rev higher.
(3) The gear lever feels solid, like literally wont move. Happens at random and not all the time though you know about it when its happening. Requires a good boot upwards and on occasion when attempting to downshift the gear lever will not budge when pressed on.
(4) Struggles to find neutral.
(5) A few seconds after shifting up and increasing speed the bike will pull back on itself (in terms of power) for a moment and then carry on as normal. This ones more rare but is worth mentioning.
So what have I done and checked;
> Chain tension - found the tightest spot in the chain and visually inspected the amount of free play, seems normal with no abnormalities throughout the chain. Also worth as a side note condition of sprockets and chain wear overall is fine.
> Clutch freeplay - Has sufficient but not excessive freeplay on the clutch lever. The clutch arm is returning upon release of the clutch lever.
There's two things that I think it could be. (1) Something internal with the gearbox as the clutch shift lever is becoming (at times) solid and unmovable (momentarily, not permanently) or (2) The engine oil needs replacing.
Suggestions?
PostPosted: 23:35 - 08 Mar 2016    Post subject: Re: False neutral and solid shift lever, advice? Reply with quote
NJD wrote:
Suggestions?
Stop booting your gear lever and tell us what bike we're diagnosing.
Forget the clutch, and the oil really though bad oil can exaserbate a condition. You have a problem with your gearshift.
Now if you're lucky it'll be the shift pawl, loose/damaged detent wheel or perhaps a spring. Might even just be a sticky shift rod. These are usually easy to access and on most jap bikes it's behind the clutch cover. That would be my first port of call.
If you're not so lucky you may have bent a fork or have a worn selector drum or other internal part. usually that means a strip-down.
RhynoCZ
PostPosted: 23:35 - 08 Mar 2016    Post subject: Reply with quote
What motorcycle are we talking about? It sounds like there's no oil in the gearbox or there is enough, but it's way too filthy and/or of the wrong viscosity.
NJD
PostPosted: 23:45 - 08 Mar 2016    Post subject: Reply with quote
Would help, my apologies, Lexmoto Arrow.
There's sufficient engine oil and was last changed aprox 2000km ago next recommended change is in 1000km aprox.
I'd personally say that its internal but wanted to ask before booking it in.
PostPosted: 23:58 - 08 Mar 2016    Post subject: Reply with quote
Check the gearshift action is not sticky from winter grime. If it moves freely enough you need to get inside the engine.
RhynoCZ
PostPosted: 23:59 - 08 Mar 2016    Post subject: Reply with quote
Any chance you got new boots any recently?
NJD
PostPosted: 00:16 - 09 Mar 2016    Post subject: Reply with quote
I'd say I do, well not me but I'll leave it to my trusted independent, getting inside the engine that is. I've fiddled with the gear shift lever by hand and it shows no resistance when being pushed upwards or downwards. Also for periods of any given ride I can change gears up and down at will without any issues at all and as smooth as you like and then the above issues turn up at random.
No, had the same ones for a while. As above suspect internal.
One thing the above issues has taught me is that riding with my left foot on the peg pointing outwards (ready to spring into action when a shift up or down is needed) or just resting on the peg makes for far smoother gear shifts that riding with the foot under the shift lever risking pre loading the shifter and creating issues.
talkToTheHat
PostPosted: 00:54 - 09 Mar 2016    Post subject: Reply with quote
Don't ride all splay footed, bring your foot backwards so the ball of your foot is on the peg, well away from shifter. Move foot forwards to shift. If you're lucky Tef won't explain why.
There should be a neutral between 1 and 2, but you should be able to shift through it smoothly.
Have you lubed the rose joints at each end of the shift linkage?
Have you got the gearshift set at somewhere near the factory angle or is it set high? I note you ride with foot resting under it, which would indicate a high lever or a degree of contortionism.
How old and how many miles has your engine oil done?
Bandit. does. everything.
NJD
PostPosted: 10:16 - 09 Mar 2016    Post subject: Reply with quote
I'd opted for heel against the frame and ball pointing outwards next to the shifter ready to go either up or down, just the way I was taught during training. Call riding with my foot under the shifter a bad habit that had stuck or I'd gotten used to and never thought anything of.
As above symptoms come and go and aren't permanent for the worse or better. Some times I'd be able to shift smoothly between all gears and ride as I like and then I'd be getting rough gear shifts with all the above symptoms. It is a false neutral I'm encountering though, I've had plenty on this bike in my time and they're always as bloody annoying as the last.
I haven't and is probable that winter grime, wet roads etc has washed any lube from last service off completely as the parts exposed near the road and all. Since the gear shift lever is becoming solid I'd say that it would be smarter to book it in rather than try this a fix?
The factory setting was useless and had to be adjusted due to my feet not fitting under the shifter smoothly. It has been adjusted more than once in its time but once I'd found its current setting it hasn't been adjusted since and the bike has been ridden with it like that countless times without any issues.
Somewhere between 3790 - 3852 miles (6100km - 6200km).
I recall that at some point last winter I booked the bike in under warranty because the arm on top of the engine case had become stuck and all I got told was that it had corroded due to road salt and was cleaned up and fixed and all I got charged for was the engine oil.
This time the issue is the gear shift lever and on the opposite side of the engine but is it possible that the above is playing a part or this could be a reoccurring issue in a different form?
Edit: Bikes booked in, shall update once the bank has been drained.
PostPosted: 11:29 - 09 Mar 2016    Post subject: Reply with quote
= CG125 copy-engine.
I'm hope you're not contemplating paying for workshop time.
NJD
PostPosted: 13:44 - 09 Mar 2016    Post subject: J Reply with quote
Maybe. I already have. Well booked it in that is not paid.
I'd rather pay to have something I have zero knowledge about done by someone who does even on an engine as someone in design as they come. I'll get there.. one day.
PostPosted: 14:18 - 09 Mar 2016    Post subject: Reply with quote
If it's an easy fix, you can fix it yourself.
If it's not, then you're setting yourself up to pay a significant proportion of the value of the bike, and that's money you'll never see back again.
I'd suggest at least changing the litre of oil, lubing the gearshift connectors, checking that the clamp bolt on the input shaft spline is secure, and cleaning and lubing the clutch actuator arm on the clutch housing and check that it's travelling fully and freely with no significant slack once the level on the bars is pulled.
It does sound like an actual gearbox problem, but if it is then I'd suggest the alternative solution of just riding it into the ground then leaving it in a ditch selling it as "mint, wants for nothing" on Gumtree. These bikes have a reputation for being disposable for a reason.
Robby
Dirty Old Man
PostPosted: 16:02 - 09 Mar 2016    Post subject: Reply with quote
Get a can of WD40.
Spray it on anything that looks like a moving part on or near the gearchange lever. Wiggle it around, spray some more.
Then see if it starts behaving.
NJD
PostPosted: 18:09 - 09 Mar 2016    Post subject: Vuo Reply with quote
Ill see how bad it is or isn't when I take it in tomorrow. Guy on the phone said he'd see if he could look at it there and then and go from there. I'll just ensure that I get it looked at and priced up before any work is done.
Family member (not a biker) said the same thing yesterday in that it wouldn't be suprising for a bike that's cheap as chips to have shat itself. I'd call a year and a few months poor if that's the case since it's been dealer serviced and had money pumped into it but that's what I get for making cheap transport into trying to make it last.
See what happens when it gets looked at.
PostPosted: 18:37 - 09 Mar 2016    Post subject: Re: Vuo Reply with quote
This might be good money after bad though.
Bear in mind that complete 156FMI engines are going for ~£175 (or best offer) on eBay.
Best of luck.
NJD
PostPosted: 22:04 - 09 Mar 2016    Post subject: Re: Vuo Reply with quote
Would be the easy route, that's easy as in cost effective rather than as you say running up a bill to the value of god only knows what percentage of the bikes retail price of which becomes uneconomical and not worth it.
Once they've looked inside and priced it up it's either to pay the repair bill and what needs replacing or do the above and fit another second hand engine and keep the original for spares and to play around with. If the original engine ends up getting replaced then I might as well take home and take it it apart in my own time and do whatever I want with it, there's nothing to loose since it all be buggered anyway.
The above is worse case scenario, see what happens and go form there.
<InsertDramaticThemeMusic.mp3>
spottedtango
PostPosted: 23:32 - 09 Mar 2016    Post subject: Reply with quote
I agree, the money spent on labour splitting the cases reassambly and replacement parts you could have sourced a good second hand engine and avoided time wasted on diagnosing the problem
supZ
PostPosted: 23:42 - 09 Mar 2016    Post subject: Reply with quote
I did that when I first passed until shortly after said passing I went round a roundabout and caught my toe on the floor nearly binning the bike and/or snapping my ankle. (in reality it just pulled my foot off the peg but could have been much worse)
learnt my lesson after that and my feet are always tucked well away (balls on pegs as mentioned above)
It's not as bigger deal on a little road bike as it is on a sports bike but still, its a good habit to get into.
There should be no reason for you to 'have your foot next to/on/under/near' the gear shift and/or rear brake unless you're actually using them. If you feel you don't have the 0.3seconds it takes to move your foot into position then you're obviously not planning ahead enough. same could be said regarding your fingers too. shouldn't need to cover the clutch or brake (you'd be forgiven covering the clutch if you ride a 2st Smile)
As said, its a good habit to get into and can keep you out of trouble (i.e. if someone did hit you and you go down with the bike there's little chance of your foot being caught if your feet are high on the pegs)
Just some friendly advice Smile
CBR954RR - Daily toy
CBR600RR - Trackbike
NJD
PostPosted: 23:55 - 09 Mar 2016    Post subject: Reply with quote
spottedtango wrote:
I agree, the money spent on labour splitting, the cases reassambly and replacement parts you could have sourced a good second hand engine and avoided time wasted on diagnosis
As above for now all I'm doing is taking it in for them to look at and price up a list of things that need replacing and then once I've been given a cost I can then either buy the replacement parts or just get a second hand engine of ebay if it works out cheaper than all the parts. I'll happily take £175 aprox to keep the bike running and give me a spare engine to work on if it comes to that.
One thing this situation does make apparent is that the 125 isn't going to go on forever (as great as that would be) and therefore might be a good idea to find a cheap 500 / restricted 600 and keep it SORN'd until renewal and then swap them over rather than just owning a 125 and relying on it.
NJD
PostPosted: 16:36 - 10 Mar 2016    Post subject: Reply with quote
Ah, yes I see the problem mr shop owner and mr mechanic. I can't believe I've missed it all this time how very silly of me. It's my reflection. Ey? Yup the problem here is the owner and not the bike.
Two test rides latter and the report was that they couldn't find anything wrong with the gearbox or the bike on the whole. Two rides just to be sure and the second one after they'd lubed and adjusted all the joints and chain, clutch etc for me as a good gesture.
Funny story actually, well lets be honest its not funny because this bike loves to hate me and make me look like a potato. Spent some time talking with the mechanic and co-owner outside the workshop and they both said how smooth and well it rode (just the mechanic on this part) and was a better example than most that passes through of a similar model. Seemed to be surprised how well I'd maintained it and kept it clean (I assume rust free). Mechanic showed me how to do a couple of adjustments and answered a few questions and then got back to work as I set off.
£27 in total. I'm sure they could have charged me more (labour) but I wasn't complaining. All in all was just the adjustment of the clutch, gear shift lever position and then adjusting / lubing a few parts.
I'll be doing nothing but riding the thing for the foreseeable future... if I can even manage that. Rolling Eyes
The last post was made 9 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 118.75 Kb
