Gummy carb cleaning recommendations
craigs23
Mr Muscle
PostPosted: 11:25 - 14 Mar 2016    Post subject: Gummy carb cleaning recommendations Reply with quote
Hi all,
Has anyone got personal recommendations for a decent carb cleaner spray?
Are all the brands pretty much the same stuff, or are some better than others?
Or has anyone had any experience with another non-specific solution?
Or, are ultra-sonic baths the proper way to go?
Moochas grassy arse.
mudcow007
PostPosted: 11:45 - 14 Mar 2016    Post subject: Reply with quote
pure acetone is great for cleaning them, but will damage rubber bits
ultrasonic cleaners are supposedly the best thing for carbs - never used one my self
RhynoCZ
PostPosted: 12:21 - 14 Mar 2016    Post subject: Reply with quote
When I ran out of carburetor cleaner, I used a brake cleaner, as the inscription on the can suggested it won't harm rubber seals nor hoses of the braking system. Now I use a chain cleaner, the same idea. An degreaser that is not harmful to the rubber/plastic bits of the carburetor and gets all the dirt deposits off. Thumbs Up
Silver_Fox
PostPosted: 13:20 - 14 Mar 2016    Post subject: Reply with quote
I used Seafoam, available on Ebay. I left it to sit for a day (full can) before I went for a good razz. It definitely helped, but not to the ridiculous extent some claim on the internetz. It didn't save my marriage, make the dinner or enlarge my penis
CBR600 F3 FV
CG125
PostPosted: 13:51 - 14 Mar 2016    Post subject: Reply with quote
For removing varnish, soaking in acetone for a couple of hours then plunging into boiling water has done a good job for me in the past.
As above, take any plastic and rubber bits off/out before using acetone.
A run through the dishwasher does a surprisingly good job. As does a clean in hot, soapy water.
These days I usually put them through an ultrasonic clean with hot soapy water, followed by a rinse in hot water, followed by WD40, followed by spray solvent cleaner.
c_dug
PostPosted: 14:18 - 14 Mar 2016    Post subject: Reply with quote
On a really gummed up carb I tend to use a piece of soft copper wire or something like that to physically poke through the jets - assuming the fancy chemicals have failed.
craigs23
Mr Muscle
PostPosted: 18:09 - 14 Mar 2016    Post subject: Reply with quote
Many thanks for all the recommendations Thumbs Up
I've managed to source a second set of carbs, so can work on them off the bike. Brake cleaner is a suggestion I hadn't thought of...
The last post was made 10 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 52.48 Kb
