FZS 600 Won't start off the button.
PostPosted: 18:11 - 14 Mar 2016    Post subject: Reply with quote
Knackered spark plug.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:40 - 14 Mar 2016    Post subject: Reply with quote
Do you have a multimeter?
Triumph Sprint ST 1050
Quote Me Happy
PostPosted: 19:43 - 14 Mar 2016    Post subject: Reply with quote
Flat battery.
dansp1
PostPosted: 19:44 - 14 Mar 2016    Post subject: Reply with quote
he didn't an hour and a half ago
Nobby the Bastard
Harley Gaydar
PostPosted: 19:46 - 14 Mar 2016    Post subject: Reply with quote
Well, he best go out and get one then.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:18 - 14 Mar 2016    Post subject: Reply with quote
Battery looks fine.
Next, bypasss the solenoid with a suitably thick bit of metal between the two big thick wires on it. One will go from the battery and the other to the starter motor.
Nemo
What happens if you put a screwdriver across the terminals of the starter solenoid?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Nobby the Bastard
Harley Gaydar
PostPosted: 20:29 - 14 Mar 2016    Post subject: Reply with quote
Do I point out that 'tard better be careful not to ground the piece of metal whilst doing these sort of shinanegans, otherwise he'll learn how to weld a screwdriver to a bike frame?
Not on a par with sproket, but it will be a giggle to hear about it.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:52 - 14 Mar 2016    Post subject: Reply with quote
I don't know if the solenoid is fucked or not.
hence the diagnostic test.
Try and carry it out without welding the screwdriver to your bike.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:15 - 14 Mar 2016    Post subject: Reply with quote
Oh god (i), the tension is palpable here.
Will he successfully bypass the soleniod and start (or not start) the bike or will he weld a 3 foot stilson to his bike...
garth
PostPosted: 21:17 - 14 Mar 2016    Post subject: Reply with quote
If it's not the solenoid you could try tapping the starter motor to see if it's seized up.
Nemo
PostPosted: 21:35 - 14 Mar 2016    Post subject: Reply with quote
One of those fuses is a spare, incase you was wondering why there was 2
RhynoCZ
PostPosted: 23:08 - 14 Mar 2016    Post subject: Reply with quote
God.i wrote:
Must be the left one as it was totally dead when I tried with the right one removed. Informative none the less.
The problem is not the 30A main fuse. If the fuse blown, you'd get no electric power to the rest of the motorcycle, as this 30A fuse is the first thing on the plus wire from plus terminal of your battery. Thumbs Up
Bypass the solenoid as you were told. If you want to use an spanner from your toolbox, use one that you don't like much and/or have no sentimental value to, as the bypassing might deform the metal of the tool. If bypassing solves the problem, the relay is dead, sometimes a bit of gentle knocking on the relay casing helps. Even cleaning the contacts properly helps, as when you press the starter button, a lot of Amps flow through those.
EDIT: If you are scared of doing the bypass test (a lot of sparks, a serious electric shock...), just ask a mate to lend you his relay, just for the test. The same relay is on various motorcycles. FZS 600 should have a Relay p.n. 4YR819400200.
EDIT II: Take the relay off and clean every terminal (2) and contacts (the socket+ the white plug) properly (get rid of all the white/green stuff = oxidation, the key is to have only shiny clean metal contacts and terminals, no oxidation allowed) put it back and try it again. It could be as simple as that.
Use WD40 if you don't have anything better. A specialized cleaner would be the best, but I brought back to live electric stuff with the plain WD40 many times before, so it should do the trick for you as well. Clean the battery terminals, no filth there allowed.
EDIT III (the last one, I promise):
1) Clean everything I've just told you about, then try to start the engine.
2) If that won't help, do the bypass test.
3) If you are scared (and the engine runs if pushstarted) ask a mate for a relay.
4) If it was the relay, buy a new relay (part number: 4YR819400200)
RhynoCZ
PostPosted: 09:40 - 18 Mar 2016    Post subject: Reply with quote
So you did nothing at all and the problem didn't fix itself? Thinking
Buy a brand new part.
Did you at least try to do what I was talking about? Clean, bypass...
PostPosted: 09:47 - 18 Mar 2016    Post subject: Reply with quote
Take it off, give it a thorough clean up and a few light taps to make sure its not just sticky inside.
RhynoCZ
PostPosted: 09:57 - 18 Mar 2016    Post subject: Reply with quote
Are you sure you don't want to give it a 30 minutes, to clean it? Anyway, yes, it is a generic part (4YR819400200 - the internet says).
andyscooter
PostPosted: 10:13 - 18 Mar 2016    Post subject: Reply with quote
Rhynocz
Only prob with half your advice is its bodyguard
He hasn't got any mates to hep him(his own words)
The last post was made 10 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 127.91 Kb
