| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| chris-red |
| Beehive Bedlam |
| Nobby the Bastard |
 ..... Quote Me Happy
| dansp1 |
 dansp1 Nitrous Nuisance
| Nobby the Bastard |
| Beehive Bedlam |
| Nobby the Bastard |
| Nemo |
 Nemo Could Be A Chat Bot
| Nobby the Bastard |
| Beehive Bedlam |
| Nobby the Bastard |
| Nobby the Bastard |
| garth |
 garth World Chat Champion
| Beehive Bedlam |
 Posted: 21:21 - 14 Mar 2016 Post subject: |
https://i.imgur.com/Z46E8vv.jpg
Gave the wires a good wiggle removed the two 30A fuses which were in tact put them back and as if by magic.
https://sendvid.com/aiak1pce
I'm going to clean all the connectors with WD40 is this the likely cause of the problem here corroded shit? Or is this simply a polite warning to tell me I should purchase replacement solenoid because it's going to shit its self any day now? |
| Nemo |
| Beehive Bedlam |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 23:08 - 14 Mar 2016 Post subject: |
| God.i wrote: | | Nemo wrote: | One of those fuses is a spare, incase you was wondering why there was 2 |
Must be the left one as it was totally dead when I tried with the right one removed. Informative none the less. |
The problem is not the 30A main fuse. If the fuse blown, you'd get no electric power to the rest of the motorcycle, as this 30A fuse is the first thing on the plus wire from plus terminal of your battery.
Bypass the solenoid as you were told. If you want to use an spanner from your toolbox, use one that you don't like much and/or have no sentimental value to, as the bypassing might deform the metal of the tool. If bypassing solves the problem, the relay is dead, sometimes a bit of gentle knocking on the relay casing helps. Even cleaning the contacts properly helps, as when you press the starter button, a lot of Amps flow through those.
EDIT: If you are scared of doing the bypass test (a lot of sparks, a serious electric shock...), just ask a mate to lend you his relay, just for the test. The same relay is on various motorcycles. FZS 600 should have a Relay p.n. 4YR819400200.
EDIT II: Take the relay off and clean every terminal (2) and contacts (the socket+ the white plug) properly (get rid of all the white/green stuff = oxidation, the key is to have only shiny clean metal contacts and terminals, no oxidation allowed) put it back and try it again. It could be as simple as that.
Use WD40 if you don't have anything better. A specialized cleaner would be the best, but I brought back to live electric stuff with the plain WD40 many times before, so it should do the trick for you as well. Clean the battery terminals, no filth there allowed.
EDIT III (the last one, I promise):
1) Clean everything I've just told you about, then try to start the engine.
2) If that won't help, do the bypass test.
3) If you are scared (and the engine runs if pushstarted) ask a mate for a relay.
4) If it was the relay, buy a new relay (part number: 4YR819400200) ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Beehive Bedlam |
| RhynoCZ |
 Posted: 09:40 - 18 Mar 2016 Post subject: |
So you did nothing at all and the problem didn't fix itself?
Buy a brand new part.
Did you at least try to do what I was talking about? Clean, bypass... ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| P.addy |
 P.addy Red Rocket
| Beehive Bedlam |
| RhynoCZ |
| andyscooter |
 andyscooter World Chat Champion
The last post was made 10 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
