97 Thundercat diagnosis help. again
pompousporcup...
PostPosted: 15:27 - 18 Mar 2016    Post subject: 97 Thundercat diagnosis help. again Reply with quote
the thundercat i've been riding has a very whiny noise which is in pretty much all gears. this makes me think a bearing has/is on its way out somewhere..but without opening things up, which is a fking ball ache, maybe someone can help who has had this before
the noise goes away pretty much entirely when i pull the clutch in. it is also less apparent under half/full throttle and when i let off it comes back again.
Chain tension has recently been set and alignment is correct and checked by mr MOT man. It rides fine. I've not noticed any issues at all, second gear (apparently known to be an issue) is not an issue. doesnt pop out/false neutral in any gear and otherwise i can't fault it.. its just the noise is making me worry
quick vid to show you the noise i mean:
https://youtu.be/YJSLobwDj_c
r32 skyline <3
Jmh600
PostPosted: 15:58 - 18 Mar 2016    Post subject: Reply with quote
When did you last charge the oil? My old monster made a similar Noise that completely went away when I changed it
Joe
Jmhmotorcycles
pompousporcup...
PostPosted: 16:09 - 18 Mar 2016    Post subject: Reply with quote
a few hundred miles or so ago. i used Vision Synthetic 10W/40 iirc
It made the noise before i changed the oil which i think the previous owner had done not long before i got it
RhynoCZ
PostPosted: 16:29 - 18 Mar 2016    Post subject: Reply with quote
I think it is one of the bearings in the gearbox (output shaft is my guess), or the way the gears are machined. Thumbs Up
I'd wait for other Thundercat owners, this might be just a feature. Re-name the thread so people know, we are talking about Thundercats.
By the way, what does this sign tell you?: https://youtu.be/YJSLobwDj_c?t=39s naughty, naughty OP. Razz
Jmh600
PostPosted: 16:31 - 18 Mar 2016    Post subject: Reply with quote
My gsxr is a little whiney, never really worried. Just the straight cut gears Smile
Jmhmotorcycles
pompousporcup...
PostPosted: 16:52 - 18 Mar 2016    Post subject: Reply with quote
Laughing Laughing if i was feeling a little more impatient i'd cut through the car wash on the left of those lights. I'd follow the rules but i suck at u-turns
im hoping its a bearing i can get to without having to split the entire engine apart Sad
weasley
PostPosted: 17:20 - 18 Mar 2016    Post subject: Reply with quote
Is this a new noise or just something you have decided to tackle? TBH it sounds pretty much like mine always has ('cept your exhaust is fruitier than mine Wink ).
Next time I ride mine I'll give it a go without earplugs and see if it's that loud. Some time around May OK for you? Cool
pompousporcup...
PostPosted: 17:22 - 18 Mar 2016    Post subject: Reply with quote
its done it as long as i've had it weasley, although i've only really started riding it properly this month as i sorted the discs and MOT.
its works.. its just noisy. so im not going to do anything unless it actually is a problem and will get worserer with more miles
you not riding yours atm or is it a fairweather thing? Laughing
Aceslock
PostPosted: 13:04 - 21 Mar 2016    Post subject: Reply with quote
Yep, mines the same as well.
Can only hear it in lower gears though (probably cause high gears = fast = wind noise) Laughing
Previous Bike: Skyjet SJ27
Sold: Yamaha YZF 600 R Thundercat. Sold: ZX636R
Current bike: R1 14B (Beast)
weasley
PostPosted: 13:24 - 21 Mar 2016    Post subject: Reply with quote
Well... urrrmm... it's, y'know.... bad timing... and.... ummmm.... a weather balloon was trapped in a thermal pocket and reflected the light from Venus.
Yeah, mostly it's the fair weather thing.
pompousporcup...
PostPosted: 11:46 - 22 Mar 2016    Post subject: Reply with quote
thats good to know, thanks Aceslock Thumbs Up
@weasley Laughing Laughing if it suits your sir
The last post was made 10 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 69.3 Kb
