| t121anf |
 t121anf World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 22:18 - 17 Mar 2016 Post subject: |
Well, yes and no. K&N filters are actually not that good at filtering, so if your K&N filter gets dirty, worse stuff already got through your engine.
But on the serious note, visual check should tell you if it's in need of cleaning. They say 50k (miles?), that is a lot. 5k would be expected, but 50k? I'd just toss it into bin and buy a OEM filter as the K&N gives you no benefit.
EDIT: As you talk about cleaning, I get it it's a foam filter. You should lube the filter, after the cleaning. But you might already know that. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| t121anf |
| RhynoCZ |
 Posted: 22:28 - 17 Mar 2016 Post subject: |
I wouldn't bother, if you don't ride it offroad.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Hahadumball |
 Hahadumball World Chat Champion
| chris-red |
| Jmh600 |
 Jmh600 Nova Slayer
 Posted: 11:58 - 18 Mar 2016 Post subject: |
I clean mine yearly as a part of the service. It's not a labour intensive job, so you might as well. Spray the power clean on, leave 10 mins, rinse with hot hot water, leave dry in airing cupboard, re oil, refit. Easy . Don't use too much oil though.
Every time I clean mine it shocks me the amount of crap that comes out, and how good they look once re oiled, hence the yearly clean
Joe ____________________ Jmhmotorcycles |
| haroman666 |
 haroman666 World Chat Champion
| Fizzer Thou |
| RhynoCZ |
 Posted: 13:28 - 18 Mar 2016 Post subject: |
I'm not telling you the K&N filters don't work, I'm just telling you, that the hype is stronger than the performance. And the only task of a air filter is to filter air.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Matt B |
 Matt B World Chat Champion
| t121anf |
| Pigeon |
 Pigeon World Chat Champion
 Posted: 17:38 - 18 Mar 2016 Post subject: |
Interesting article. Initially I thought it was bad for K&N, but I'm actually quite pleased to see those results.
The stats are maybe not too surprising. K&N is marketed as a "high air flow" filter.
Filters must surely be a compromise / balance. Very fine material that blocks dirt but limits air-flow or you have a material that lets more air and bad stuff through.
Dust efficiency, it was only 3% off the best. Although it's capacity to collect dirt before coming clogged was 50% of the top performer.
So the idea that it should be left 50k miles between cleaning seems a bad idea.
The K&N had 50% less resistance to air-flow than the "top performer" and was the least resistant to air flow of all the filters.
Which kinda confirms that it's doing what it claims, it lets more air through.
But it clogged quicker and let more dirt through. So probably not the best filter if you live in the Sahara. But here in Blighty, I'm happy with that. I'll just remember to clean it every couple of years (10k miles for me).
Perhaps unsurprisingly, K&N's own IS0 5011 test came out a little different at 99.11% instead of 96.8% and a dirt capacity of 366g instead of 212 g
Although in my eyes, the Wix looked the best in terms of balance between air flow and dust caught. But I can't see they are available in the UK.
As a side, I noticed that BMC filters look similar to K&N in terms of materials used, but they don't have anywhere near the amount of solid plastic blocking around the edge. But I don't know much about them and they don't seem to promote ISO test data on their website.
Anyone used them? |
| chris-red |
 Posted: 18:11 - 18 Mar 2016 Post subject: |
The whole point graphs is to display information graphically for easier understanding, those intentionally skew the visual by moving the the low Y axis value to right below whatever K&N score. I wouldn't trust it with a barge pole. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| Pigeon |
| Matt B |
| yen_powell |
| stevo as b4 |
| Pigeon |
 Posted: 19:46 - 20 Mar 2016 Post subject: |
I replaced the standard filter in my SV with a K&N. It's not a panel, but the box type that sits in the top of the airbox, with air coming in from above the fuel tank.
Noticed nothing in terms of power, or rev fluidity (zero flat spots before or after, gotta love a carb). But I did notice the noise. Damn it sounded lovely from under the fuel tank.
Then I stuck a louder can on and can't hear anything from the airbox now
Replaced the Striples OEM with K&N and noticed a nice jump in performance. But I did so many other little things at the same time, it was a culmination of little tweaks rather than just a filter.
The key difference, is the Striples airbox intake is situated below the front headlights. So when following other vehicles in the rain, they blast the front of the bike with water and mud. Some of which clearly ends up in the airbox because I found it in there when taking it apart.
But the paper filter I took out really didn't have much crud on it after 27 months. What it did do is have half a dozen large flys, which hopefully the K&N would also be able to stop
So yeah, its maybe not the best at filtration. But it was fed 9.8 grams of dust a minute for 44 minutes at 350CFM (unlikely to see above 180CFM in normal circumstances) and let in 7 grams.
So unless I'm doing 200mph in the Sahara desert, not too worried.
On the flip side, it lets in loads of air, cost me £45 and should last the life of the bike. An OEM paper filter is £25 and is replaced every 2 years.
Happy with that. |
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| Pigeon |
| Triton Thrasher |
| RhynoCZ |
 Posted: 23:21 - 20 Mar 2016 Post subject: |
K&N sure does like to talk about the ''Air Flow'', and not enough about the essential function of a air filter, the filtration abilities.
Well, there are these kinds of tests as well: https://youtu.be/yFTPSRxisJI?t=1m8s You can even see the lid doesn't seal the box when the OEM filter is in.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
The last post was made 10 years, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
