Hornet Service
deanoet
PostPosted: 18:53 - 18 Mar 2016    Post subject: Hornet Service Reply with quote
Bike is due a service, 32k miles so it is the valve clearance ones.
Honda have quoted £400... plus a further £50 if any adjustment is needed
Don't fancy paying that for a service as it is likely to need at least a new back tyre as well
Anyone recommend any good independent bike service places on or around the Wirral?
If that is the going rate for a valve clearance service check then so be it, I am hopeful it can be got a fair bit cheaper though
Thanks
Hahadumball
PostPosted: 19:28 - 18 Mar 2016    Post subject: Reply with quote
spend 2 hours check em yourself, its not hard.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Baffler186
PostPosted: 19:30 - 18 Mar 2016    Post subject: Reply with quote
If its any help, I was quoted £150 all in, from a private garage I trust. This was for the fazer so probably not much different to the Hornet in terms of valve clearance checks and adjustment. Shop around?
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
PostPosted: 20:30 - 18 Mar 2016    Post subject: Re: Hornet Service Reply with quote
deanoet wrote:
32k miles [...] Honda have quoted
Main dealer, out of warranty? Not a chance.
Workmate got a CBR600RR (same basic engine) with 40K+ miles, took it to an ex-Honda mechanic working as an independent and the guy wouldn't even take his money for a valve check because they so rarely go out. He agreed to do a compression test while changing the plugs and have a listen to it, all clear.
Tdibs
PostPosted: 20:50 - 18 Mar 2016    Post subject: Reply with quote
God.i wrote:
Seems fine.
Well thats the reason you check them at the service intervals. As it might "seem fine" right until its not because your vavles have slowly just got more and more out of spec.
Personally I get them done so I know, not take some bloke's mates uncle on his dads friends forum who did 100k on a engine and never checked them. Your bike, your choice though.
Last check I had on the SV at I think 38k the rear was out by a bit.
PostPosted: 21:06 - 18 Mar 2016    Post subject: Reply with quote
How long did it take you to do them?
whitedevil
PostPosted: 22:56 - 18 Mar 2016    Post subject: Reply with quote
Both my cbr and my zx6rs clearances were tight when I did them.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
PostPosted: 01:01 - 19 Mar 2016    Post subject: Reply with quote
10 miles? 10,000 miles? 100,000 miles?
Copycat73
PostPosted: 09:10 - 19 Mar 2016    Post subject: Reply with quote
24 000 miles and ten shims needed replacin or moved around.
i did mine over about 4 days ( 20 hours) .. but not all together as other commitments precluded this ... much time was spent checkin what i had already done...
a trained mechanic would take 5 hours or so ;but he wont be pissin about re-checkin his work as will have done the job many times ;hence the high price for such a service.... the parts were something like £40+
caveat emptor
PostPosted: 09:17 - 19 Mar 2016    Post subject: Re: Hornet Service Reply with quote
Depends on the year Hornet the OP has.07 onwards uses the 03-06 600RR engine. Pre 07 uses a CBR600F engine from about the stone age.
Personally I wouldn't main dealer it, but I would get them looked at for piece of mind. Yes they rarely go out of adjustment, but I'd still get them looked at.
Copycat73
PostPosted: 09:24 - 19 Mar 2016    Post subject: Re: Hornet Service Reply with quote
i did my `92 and most of the exhaust valves had settled in tight.
caveat emptor
PostPosted: 10:39 - 19 Mar 2016    Post subject: Reply with quote
All those burned out valves. Sad
bikertomm
PostPosted: 10:54 - 19 Mar 2016    Post subject: Re: Hornet Service Reply with quote
Same story here. My 07' hornet hit 32k last year, took it to my local legendary independents asking if I should get them looked over for peace of mind, they both looked at each other and laughed. They know the engines well and said you don't need to worry at this interval. (Going on experience).
Done! Mr. Green Thumbs Up
Copycat73
PostPosted: 11:15 - 19 Mar 2016    Post subject: Reply with quote
as maybe .. but i`ve got the coin to fix it...
...because more importantly .... time is the crucible in which we burn ...
caveat emptor
Enduro Numpty
PostPosted: 11:50 - 19 Mar 2016    Post subject: Reply with quote
Tdibs wrote:
God.i wrote:
Seems fine.
As above.
Honda or whoever specify service intervals for a reason. Of course we can ignore and take the advice of forum "experts".
Your engine, Your Decision Wink
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
Fizzer Thou
PostPosted: 18:56 - 19 Mar 2016    Post subject: Reply with quote
If the shim is 'under bucket' and needs replacing because the clearance is too tight,then the cam would need displacing in order to remove the bucket and shim,like on this R1 engine
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture366.jpg
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture360.jpg
Then,if the shims cannot be swapped around,then replacements would need to be sourced
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture358.jpg
If I did not have a stock of the common sizes for the Exup and R1 then I would buy them from Wemoto,who sell them at a reasonable price.Genuine shims are not cheap Confused
Just to get to measure the clearances takes quite a bit of time,which is all chargeable.So every minute removing the tank/seat/fairing panels/airbox/coils etc soon adds up Shocked
Always have a 'Plan B'
PostPosted: 21:54 - 19 Mar 2016    Post subject: Reply with quote
So, OP should do...?
The last post was made 10 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 108.01 Kb
