Bus Lanes
TbirdX
PostPosted: 22:40 - 18 Mar 2016    Post subject: Bus Lanes Reply with quote
Time to check the BCF knowledge base.
A few times now I've been bowling along the bus lane when it merges into the normal traffic via a set of lights. Presumably when a bus approaches these lights change to let the bus pass. However, when I get there they've always stayed red (at least for as long as I waited for them which was precisely zero seconds)
I just filtered around them into normal traffic and continued on my merry way.
Right, wrong, does anyone give a shit?
ScaredyCat
PostPosted: 22:44 - 18 Mar 2016    Post subject: Reply with quote
Busses will have a doofer in them to trigger the lights. If you had sat at them waiting, you'd be there a long time. The only thing to do is go round.
The fact that there were lights there though, suggests that perhaps you shouldn't have been using that lane. Did you check it was ok?
inb4 got a fine...
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Fin
PostPosted: 22:58 - 18 Mar 2016    Post subject: Reply with quote
The lights at the bus lane I usually use is triggered by sensors in the ground, I have to ride over the right part of the road at the right speed for them to pickup, found braking on the right parts of the road would help.
If they don't change after 30 seconds and there are no police behind you then go through or do what you did, probably not right but I'm sure coppers would understand.
edit: I tend to exit the bus lane and join the normal lane now to avoid stopping all the other traffic and having to wait at lights (is a bit of a gamble). bus lane solid line is faded away so no one cares.
TbirdX
PostPosted: 22:59 - 18 Mar 2016    Post subject: Reply with quote
Cheers for that.
The signs said buses, taxis, pushbike and motorcycles, so all good there.
-Matt-
PostPosted: 23:08 - 18 Mar 2016    Post subject: Reply with quote
https://cdn.meme.am/instances/500x/37735341.jpg
Mudshark
PostPosted: 23:17 - 18 Mar 2016    Post subject: Reply with quote
Laughing mega Laughing
R1250RS
XT660X
Ben90
PostPosted: 23:18 - 18 Mar 2016    Post subject: Reply with quote
On a bus lane near me there's a traffic light at the end before the merge, but the solid white line is only on the 'normal' lane. Therefore blazing through the 'red' in a bus lane is fine in this case since there is no white line to otherwise illegally cross.
Is this the same case as yours? or are there a set of lights for both the bus lane and normal traffic?
It could be that the lights changed red to stop the normal traffic to let you pass Laughing
Yamaha FZ6 S2
TbirdX
PostPosted: 23:25 - 18 Mar 2016    Post subject: Reply with quote
I think, that there are two sets of lights, when the bus lights are red the normal traffic lights are green and vice versa.
Commuter_Tim
PostPosted: 00:06 - 19 Mar 2016    Post subject: Reply with quote
Whilst I agree with the sentiment...
If I remember my riding lessons/highway code correctly, if a set of traffic lights appears to not be functioning correctly, you continue and proceed with caution.
Even G-man can't be stupid enough to expect people to sit and wait because a light is stuck on red or completely out.
I ride a Bandit 600... badly.
mauzo
PostPosted: 01:49 - 19 Mar 2016    Post subject: Reply with quote
AIUI you are allowed to do a normal lane change out of a bus lane whenever you have reason to? In which case as long as you don't pass a red light, but change lanes (correctly) to avoid it, the police have no grounds to complain. (If you decide the lights aren't going to change and deliberately jump them staying in the same lane, you're on much more dodgy ground.)
The 'bus lane' line is big and solid and scary to try to keep cars out, but AFAIK if you are allowed to use that lane it's just an ordinary lane divider.
'04 CG125, '07 CBF500
Ribenapigeon
PostPosted: 02:17 - 19 Mar 2016    Post subject: Reply with quote
Give up on bikes, get a jetpack, problems fucking solved.
Commuter_Tim
PostPosted: 18:27 - 19 Mar 2016    Post subject: Reply with quote
Don't be an idiot, Jet Packs aren't allowed in bus lanes. Rolling Eyes
PostPosted: 18:43 - 19 Mar 2016    Post subject: Reply with quote
Of course you are. Double lines you keep to the right if the closest one to you is solid, a single solid line you can cross.
Don't do it if the solid line is bracketing a chevron though, that's a 3-pointer.
ADSrox0r
PostPosted: 19:46 - 19 Mar 2016    Post subject: Reply with quote
The ones in York are on a pressure sensor under a fairly obvious rectangle before the lights. The Viff's lardy arse easily triggers them but I have noticed that if I'm behind a bus and it triggers one of the short-lit ones, it won't trigger again with me on it so I end up having to go through a red or the bus driver that inevitably ends up behind me gets in a right radge (cool story bro tell it again!)
PostPosted: 20:33 - 19 Mar 2016    Post subject: Reply with quote
Most sensors are induction-loop so they will be triggered by the mass of the crankshaft or gearbox. For best results stop with your engine over the sensor.
PostPosted: 21:47 - 19 Mar 2016    Post subject: Reply with quote
Empirical or anecdotal?
PostPosted: 22:50 - 19 Mar 2016    Post subject: Reply with quote
We sometimes have to cut the grooves for the loops.
ADSrox0r
PostPosted: 10:51 - 20 Mar 2016    Post subject: Reply with quote
Ah, so is that what the rectangular tar snake is then?
PostPosted: 10:57 - 20 Mar 2016    Post subject: Reply with quote
Yep:
https://en.wikipedia.org/wiki/Induction_loop
ADSrox0r
PostPosted: 17:33 - 20 Mar 2016    Post subject: Reply with quote
Learn summert new eh, all these years I thought it was pressure thing Rolling Eyes
The last post was made 10 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 109.94 Kb
