Kawasaki ER6 charging problems
marlc0
PostPosted: 14:37 - 19 Mar 2016    Post subject: Kawasaki ER6 charging problems Reply with quote
So, as per the title. A little backstory, too.
Bike had been stood for a few months over winter, took it for it's MOT, passed no issues, then rode it 30 mins into town, just after shutting the engine off, went to re-start it, and the battery was dead. Got a jump start on it, and it sat running fine for 5 mins, then 2 mins after setting off, it died, and i had to get it towed home.
Changed the battery, charged it, and ran the bike up and checked it with a multi-meter, and it's only just to say charging it, when i put any lights on, the level just dies off.
So, backstory over, i know it's not charging properly, I've had a look for spares, it's not just a one part change out, so what does BCF think i need to spend my money on, generator bits, or a reg/rec?
2010 Kawasaki ER6-f - Given to the Mrs.
2016 Triumph Tiger 800
Islander
PostPosted: 14:52 - 19 Mar 2016    Post subject: Reply with quote
Voltages at the battery terminals with the ignition on, the engine idling and revving at 4-5k?
Taught2BCauti...
PostPosted: 17:47 - 19 Mar 2016    Post subject: Reply with quote
If you don't know exactly what to check for or how old your battery is, the best way forward is to start with a known good battery and check the voltages like Islander said.
Charging systems won't usually charge a duff battery, and that is normally the cheapest component.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
marlc0
PostPosted: 20:07 - 19 Mar 2016    Post subject: Reply with quote
Okay, some volts for you.
With the ignition off, and been off charge for a few days, it was 13.16V
On idle, 12.28V
sitting between 3-4K, 12.28V
This is a band new battery, about a month old, so no concerns about that, so i'm thinking it's the bike.
Now what do you think i should do?
RhynoCZ
PostPosted: 20:17 - 19 Mar 2016    Post subject: Reply with quote
Check the stator gives you AC voltage out. There is no charging going on at the moment as the voltage is the same no matter how high you rev it. If you get AC voltage out of the stator, then your rectifier is dead. A rectifier is a diode that converts AC to DC, if the diode is dead, no current nor voltage will get past the dead rectifier.
I'm pretty positive it's the REG/REC unit. But, check the stator first, just in case. Thumbs Up
Kawasaki p.n. 21066-0705 (pretty generic part = not expensive)
Islander
PostPosted: 20:32 - 19 Mar 2016    Post subject: Reply with quote
On idle, 12.28V
That sounds like a reg/rec problem.
Taught2BCauti...
PostPosted: 10:29 - 20 Mar 2016    Post subject: Reply with quote
Disconnect the Reg/Rec and look for the 3 yellow wires that come from the alternator. Label them 'A', 'B', and 'C'.
Now with the multimeter set to read AC Volts and the engine ticking over, check the voltage from A - B, A - C, and B - C.
The readings you get will help to eliminate the alternator windings and the Reg/Rec without taking anything else apart.
Robby
Dirty Old Man
PostPosted: 18:45 - 20 Mar 2016    Post subject: Reply with quote
It'll be a dead reg/rec. I recommend changing it for a MOSFET one. Second hand is ok, MOSFET reg/recs are tough.
marlc0
PostPosted: 11:33 - 24 Mar 2016    Post subject: Reply with quote
Changed the reg/rec for a new unit, and it's still not charging. Probably should have checked the alternator output first, really.
So, what's next guys?
RhynoCZ
PostPosted: 11:44 - 24 Mar 2016    Post subject: Reply with quote
Well, check the stator gives you AC voltage, which I suspect it doesn't. You have to do the AC test with the engine running. The Ohm test (resistance) is done with the engine off. Thumbs Up
Do as Taught2BCautious says, the 3 yellow wires. The alternator cover is on the sprocket side, there will be a black cable going out of the engine cover.
Like so - between the sprocket cover and the silver engine lid (I think I can see the plug, next to the injector unit. Unplug it, and check it is the 3 yellow wires under the cable sleeve):
https://www.seastarsuperbikes.co.uk/Kawasaki%20images/er6n/er6n%20eng%20lg.jpg
marlc0
PostPosted: 18:52 - 29 Mar 2016    Post subject: Reply with quote
Right then, got a few pics, to show you what i've done.
https://goo.gl/photos/axfgedesRqZUnxL79
So, that pic shows what i'm calling A-B, and the battery volts.
A-C = 1.7, B-C = 2.0
So, i've no idea what i'm looking for, just want to make sure i'm doing it right, and if so, what does it mean?
Islander
PostPosted: 21:28 - 29 Mar 2016    Post subject: Reply with quote
You won't read battery voltage at the stator. You need to measure the output of the stator with the engine running - note that you need to change ranges to AC volts rather than DC.
marlc0
PostPosted: 21:59 - 29 Mar 2016    Post subject: Reply with quote
Sorry, I should have said, the battery pic was just supplementary, mostly just posted so you could tell me if I was testing it right, I'm not much of a sparkie.
The engine was running, on idle, and that's the readings I got from the engine side of the wire.
What do now?
Islander
PostPosted: 22:29 - 29 Mar 2016    Post subject: Reply with quote
It looks like you have no output from the alternator. Did you measure the resistance of the stator windings? It might be worth checking that as a belt and braces approach but from the voltage readings it does look like a dead stator.
marlc0
PostPosted: 09:47 - 01 Apr 2016    Post subject: Reply with quote
I'm guessing I was to check the resistance at the same points? If so, a-b was 0.8 ohm's, a-c 0.6 and b-c 0.6ohms.
This was with the meter set at 200 in the ohm's scale.
So, new stator needed?
Islander
PostPosted: 13:08 - 01 Apr 2016    Post subject: Reply with quote
Looks like it.
marlc0
PostPosted: 18:12 - 01 Apr 2016    Post subject: Reply with quote
https://goo.gl/oUe4kj
Got the stator out, and it looks a like it's burnt out. Ah well, best get looking for a new one.
RhynoCZ
PostPosted: 18:15 - 01 Apr 2016    Post subject: Reply with quote
Yep, it's dead. You could find a bloke, who'd rewind it for you, but I wouldn't bother, just buy a new part. It is a generic part, no need to be looking for a ER6 specific one.
p.n. 21003-0042 Thumbs Up
Islander
PostPosted: 18:21 - 01 Apr 2016    Post subject: Reply with quote
Yep, that looks a bit toasted. Laughing
The last post was made 10 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 103.36 Kb
