| RhinoBiker |
 RhinoBiker L Plate Warrior
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 23:46 - 21 Mar 2016 Post subject: Re: Back Brake |
| RhinoBiker wrote: | ...a healthy amount of WD40...; ... a lot of force!... |
Well, those were not smart things to do.
When you sprayed the calliper with the WD40 the seals in the calliper might have swollen a bit.
Also, and I know some won't agree, you should never require ''a lot of force'' to push the pots/pistons back into the calliper. That being said, it's time for a rebuild of your calliper.
Side note: My personal experience; every motorcycle I bought had a stubborn rear brake. All I ever did to make the rear brake work again was, I just started to use it more often and it never took long and the brake was fully operational. Then I just changed the brake fluid and that was it. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| bladeblaster |
 bladeblaster Trackday Trickster
| tom_e |
 tom_e Brolly Dolly
| Pete. |
 Pete. Super Spammer
 Posted: 21:46 - 22 Mar 2016 Post subject: |
I'm guessing it's a Suzuki?
If so they have a habit of getting a build-up of crud in the bottom of the seal groove. I have made a tool for scraping the oxidisation out but one of those skinny brass wire wheels on a dremel would probably do a great job. Otherwise scrape them clean by hand. ____________________ a.k.a 'Geri'
The last post was made 10 years, 190 days ago. Instead of replying here, would creating a new thread be more useful? |
