| Yasine |
 Yasine Two Stroke Sniffer
 Posted: 12:21 - 22 Mar 2016 Post subject: Bought a Yamaha XJ6N, need some advice on chain and clutch. |
The CBR600FS has been sold and replaced by a 2009 Yamaha XJ6N. Although the CBR was quick, the XJ6N appears much more comfortable for London streets.
It has 40,000 miles, has good history with servicing done on time. It starts first time and does not make any negative/ worrying noises.
However the chain seems a bit loose and on the swingarm there is only once notch left to pull the wheel back and give it more tension. Does this mean that the chain has stretched and needs replacing?
Also the clutch cable seems to be adjusted quite far out, would this indicate a new clutch is required soon?
And lastly how long should this engine be expected to last if properly maintained?
Thanks in advance  ____________________ Yamaha XJ6N |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
 Posted: 12:49 - 22 Mar 2016 Post subject: |
In my opinion, I'd have to ride the bike more to see how the chain wears. For example, when I put a new chain on mine, it took a lot of adjusting and it sort of bedded in. In that, I mean I generally only have to adjust the chain on the order of 000's of miles now. Ride it, keep an eye on tension. You have already bought it now so just see how it goes.
Clutch cable meaning the clutch is going.
No, it could mean that the clutch cable is going (stretched). Although on my bike, I can adjust the clutch cable down by the clutch cover and at the lever, has somebody just tried to tighten the cable up at the top without trying to adjust it at the other end? ____________________ I'm Sam; Northern, Ginger, Lover
Did have: '95 ZZR600 '83 CG125 '97 ZZR1100 '15 Hypermotard 821 SP Do Have: '10 ZX10R |
| Val |
 Val World Chat Champion
| Yasine |
| Yasine |
| Ste |
 Ste Not Work Safe
 Posted: 14:09 - 22 Mar 2016 Post subject: |
If you run out of adjustment then your chain and probably sprockets almost certainly do need replacing.
Post some pics or the chain and sprocket(s).  |
| chickenstrip |
 chickenstrip Super Spammer
I wouldn't even bother measuring for stretch on the chain links if you've only one notch left on the adjustment. Needs replacing soon, and replace the sprockets while you're at it if they have any visible signs of wear, i.e., haven't been replaced very recently. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
| evilzed |
 evilzed Scooby Slapper
| Yasine |
| Yasine |
 Posted: 15:55 - 22 Mar 2016 Post subject: |
Thanks a bunch for this!! I will have a look through the manual  ____________________ Yamaha XJ6N |
| Val |
| talkToTheHat |
 talkToTheHat World Chat Champion
| Robby |
 Robby Dirty Old Man
The last post was made 10 years, 201 days ago. Instead of replying here, would creating a new thread be more useful? |
