Bearings - bike specific?
mudcow007
PostPosted: 20:11 - 22 Mar 2016    Post subject: Bearings - bike specific? Reply with quote
Are bearings bike specific?
just stripped my DT175 down to the frame etc, an the amount of parts are eye watering if i went straight to Mr Yamaha
with bearings do i just need to know dimensions etc? or are there anything else to know?
fanks
CaNsA
PostPosted: 20:13 - 22 Mar 2016    Post subject: Reply with quote
I get my bearings from here.
https://simplybearings.co.uk/shop/
SQL
PostPosted: 20:24 - 22 Mar 2016    Post subject: Reply with quote
This or Ebay
Islander
PostPosted: 20:29 - 22 Mar 2016    Post subject: Reply with quote
Go to a bearing factor or measure them and buy them online from a bearing specialist. Thumbs Up
PostPosted: 20:29 - 22 Mar 2016    Post subject: Re: Bearings - bike specific? Reply with quote
fanks
Mostly, no. Some manufacturers use bearings which are a non-standard size but there's very few legitimate reasons for doing that.
Most ball and needle roller bearings you'll find on your bike are sized by ID OD and width. The easiest way to size a bearing is to look for a number on the side shield, if it has one. If you see a number like 6204 on the side all you need to do is buy a good replacement with the same number. Otherwise measure the inside and outside diameter and the width and put those numbers into one of the popular bearing sites.
PostPosted: 21:19 - 22 Mar 2016    Post subject: Reply with quote
As I understand it, one example of specific bearings are main bearings on the RD LC. Basically a standard bearing with a small bit removed from the bearing race.
Katy
PostPosted: 22:00 - 22 Mar 2016    Post subject: Reply with quote
There are many examples of non-standard especially grooved or pinned gearbox bearings but the vast majority will be stock items, especially the ones which need changing most regularly like wheel and headstock bearings..
temeluchus
PostPosted: 22:01 - 22 Mar 2016    Post subject: Reply with quote
the only bearings I found to be more or less bike specific are one of the bearings in a late model FJ1200s suspension linkage and for the mid joint in BMW paralever swingarms.
MarkJ
PostPosted: 02:11 - 25 Mar 2016    Post subject: Reply with quote
Aprilia had a funny needle roller bearing in their suspension linkages of RSVs too. They removed the cage so the rollers were loose, and crammed twice as many rollers in. From what I remember people replaced them with standard caged needle roller bearings and they didn't seem to wear any quicker.
The last post was made 9 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 61.42 Kb
