Stump remover for getting a fence post out?
Ribenapigeon
PostPosted: 12:35 - 24 Mar 2016    Post subject: Stump remover for getting a fence post out? Reply with quote
Would stump remover work on a fence post.
Cheers.
andyscooter
PostPosted: 12:37 - 24 Mar 2016    Post subject: Reply with quote
No
A stump is living still (normally)
A post is treated dead wood
duhawkz
PostPosted: 12:42 - 24 Mar 2016    Post subject: Reply with quote
Why can't you just dig it out?
Ribenapigeon
PostPosted: 12:47 - 24 Mar 2016    Post subject: Reply with quote
Its jammed in between some concrete and stones. I was hoping Stump remover worked by rotting down the wood. Then was hoping to just be able to pick axe the top ten inches down.
Tracey Suntan-King
PostPosted: 13:31 - 24 Mar 2016    Post subject: Reply with quote
Soak with diesel, set it on fire.
Alpineandy
PostPosted: 14:41 - 24 Mar 2016    Post subject: Reply with quote
Any idea how much of it is below ground?
How much is above ground?
Do you want to remove it entirely or just to ground level?
Sorry just added;
What time frame to get rid of it...
This summer or this minute?
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
mudcow007
PostPosted: 15:15 - 24 Mar 2016    Post subject: Reply with quote
sump grinder?
stick "block & tackle" around it an yank it out?
PostPosted: 15:19 - 24 Mar 2016    Post subject: Reply with quote
Dig out the stones and concrete?
Ribenapigeon
PostPosted: 19:39 - 24 Mar 2016    Post subject: Reply with quote
Id just like it a few inches below level. The thing is damned deep and I suspect put in properly so maybe with small cross pieces at its base as the post wouldent rock at all even with a foot of earth removed to one side of it.
J4mes
PostPosted: 19:54 - 24 Mar 2016    Post subject: Reply with quote
I drilled a 30mm hole in one, slid a pipe through it and then used a bottle jack to pump it out the ground. Took about 10 minutes.
Ribenapigeon
PostPosted: 21:27 - 24 Mar 2016    Post subject: Reply with quote
Now that is a good idea.
Chuffin Nora
PostPosted: 07:27 - 25 Mar 2016    Post subject: Reply with quote
Failed the foundation course in Earth Sciences, did we? Thinking
Not such a good idea if the post is so solidly grounded that the jack actually pushes the planet out of orbit. :dough:
Use your loaf!
There's a fine line between integrity
Ribenapigeon
PostPosted: 09:18 - 25 Mar 2016    Post subject: Reply with quote
How does stump remover work anyway?
pepperami
PostPosted: 10:55 - 25 Mar 2016    Post subject: Reply with quote
It is a translocated/systemic hormonal poison, it is absorbed into the living vessels (xylem & phloem) of the stump and moved around the stump, as it does the hormones cause a breakdown of the cells of the plant and this in turn stops the remainder of the plant from functioning and it dies.
nickyboy4
PostPosted: 11:07 - 25 Mar 2016    Post subject: Reply with quote
Sometimes you need to bite the bullet and do some hard physical work, just dig it out i've done dozens and if you put the effort in, be methodical it'll be out in 30 minutes
Ribenapigeon
PostPosted: 11:42 - 25 Mar 2016    Post subject: Reply with quote
Cheers, useless for my post then I was hoping it dissolved or caused wood to go soft.
PostPosted: 12:02 - 25 Mar 2016    Post subject: Reply with quote
Chop chop dig dig.
Hurry up, nobody else is going to do it. Razz Thumbs Up
Alpineandy
PostPosted: 17:24 - 25 Mar 2016    Post subject: Reply with quote
You could try running a large wood bore bit down it. The larger the better...
https://www.ebay.co.uk/sch/i.html?_odkw=wood+bore+3+inch&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xwood+bore+2+inch.TRS0&_nkw=wood+bore+2+inch&_sacat=0
Ribenapigeon
PostPosted: 17:51 - 25 Mar 2016    Post subject: Reply with quote
I'm considering a chainsaw. That or genetically modified super woodworm.
MCN
PostPosted: 17:56 - 25 Mar 2016    Post subject: Reply with quote
This:
https://www.ebay.co.uk/itm/6-2KG-5-Foot-Long-Ball-Joint-Splitter-Road-Wrecking-Bar-Pry-Crowbar-Chisel-Point-/261994383808?hash=item3d001509c0:g:-NMAAOSwPcVVwyC0
This:
https://www.ebay.co.uk/itm/New-Fibreglass-Handle-Drain-Spade-and-Post-Hole-Digger-Shovel-Twin-Shovel-Set-/381563339917?hash=item58d6f2848d:g:7egAAOSwl8NVXzS9
And stop fucking about and just do it.
grr666
PostPosted: 21:27 - 25 Mar 2016    Post subject: Reply with quote
Coat it with peanut butter daily and the local squirrels will gradually eat it over a 2 to 3 year period. Thumbs Up
duhawkz
PostPosted: 22:05 - 25 Mar 2016    Post subject: Reply with quote
I don't think thats what he ment when said he wanted his stump removing. Shocked
PostPosted: 22:34 - 25 Mar 2016    Post subject: Reply with quote
https://i.imgur.com/UhkKtai.jpg
https://i.imgur.com/6O6YGmW.jpg
Evil Hans
PostPosted: 16:50 - 01 Apr 2016    Post subject: Reply with quote
Put a rope around it and drag it out with a Land Rover, always works for me.
The last post was made 10 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 122.88 Kb
