Parkside impact wrench [Lidl Auto Essentials] any good?
M.C
PostPosted: 21:13 - 25 Mar 2016    Post subject: Parkside impact wrench [Lidl Auto Essentials] any good? Reply with quote
Lidl have an impact wrench in the upcoming auto essentials: https://www.lidl.co.uk/en/our-offers-2491.htm?action=showDetail&id=32190 Anyone have any experience with these or think they'll be any good?
Used battery snap-on ones before but obviously in a different league. Would the above deal with a fork damper bolt spinning for example?
StevenF
PostPosted: 22:40 - 25 Mar 2016    Post subject: Reply with quote
I'm considering getting one as well. It's much cheaper than a battery powered one and it's limited to 100Nm, which means less chance of over tightening. The max loosening torque is 320Nm which should loosen most stubborn bolts on cars and bikes.
Edit: Forgot to mention that undoing the upper mount nut on a car strut is one of the reason I want one. I managed to round the upper torx which stops the strut spinning while undoing the nut. From what I've read an impact wrench should be able to spin it straight off.
M.C
PostPosted: 15:33 - 29 Mar 2016    Post subject: Reply with quote
Picked one up today. They only had 2 left, dunno if that's an indication it was a good buy. Will see how it goes.
DrSnoosnoo
PostPosted: 15:37 - 29 Mar 2016    Post subject: Reply with quote
I bought one too. I reckon it might come in handy when/if I want to get the centre stand off my bike ...
I just need any reason to take a wheel off my car. Just to feel like I'm in the F1 pits.
M.C
PostPosted: 15:42 - 29 Mar 2016    Post subject: Reply with quote
Never seen F1 teams trip over the power cord Very Happy
TBH when I worked in a garage that's what we mainly used these for, taking wheels off & on. I'm gonna see if this will get my fork damper bolt out, just need to buy a long 10mm allen key bit.
Fizzer Thou
PostPosted: 17:56 - 29 Mar 2016    Post subject: Reply with quote
I bought one yesterday,while they still had plenty in stock.
Not used it yet,but will be useful,especially for those fork damper bolts that many people have problems with,including myself Embarassed
Always have a 'Plan B'
Confusion
PostPosted: 22:54 - 29 Mar 2016    Post subject: Re: Parkside impact wrench [Lidl Auto Essentials] any good? Reply with quote
https://www.biker.ie/forum/showpost.php?p=3379435&postcount=7
Bandit 650SA, ZZ-R1100
DRZ4Hunned
PostPosted: 23:33 - 29 Mar 2016    Post subject: Reply with quote
I bought one in hope that it'll get my front sprocket nut loose, I've tried a 3' breaker bar with no success so I'll report back tomorrow if I manage to get the fecker off.
Quality seems good for £30 and if not it's got a 3 year warranty...
What's the likely-hood of me shattering a regular chrome socket (30mm) undoing a 100ft/lb nut (possibly loctited)?
DRZ400-SM
FZS600
mysterious_rider
PostPosted: 06:35 - 30 Mar 2016    Post subject: Reply with quote
Holy jesus what a bargain. I have the snapon 18v cordless withsimilar spec. It cost me 200 second hand!!
Buy it! You can use whatever sockets you like. But after years of use itll wear them. This is normal. They last ages. I abuse my halfords sockets fine. Try choosing 6 sided ones over 12 if you can due to rounding.
The trick with stuck bolts is deblock penetrating oil or heat. And use a gun. But im talking of massive ones like wishbone bolts etc.
For 30 squid if it lasts for a couple of specialist jobs its paid for itself. Rinse and repeat.
KAWASAKIIIII
DrSnoosnoo
PostPosted: 07:50 - 30 Mar 2016    Post subject: Reply with quote
Oh! Front sprocket bolts ... If it works for those, that'll make a once in a blue moon job soooo much easier.
yen_powell
PostPosted: 11:45 - 30 Mar 2016    Post subject: Reply with quote
I've bought one, had a quick ride to the Aldi at Witham and they still had loads left.
Looks okay. The quick release air fitting is a different size to the one on my compressor. I have pinched the fitting off my blowie uppie tyre thingie so I can try it out on one of my rear axle nuts. Will give it a go in a minute and report back.
XT1200Z and a DR350 in bits
bugeye_bob
PostPosted: 11:50 - 30 Mar 2016    Post subject: Reply with quote
As its mains Im not surprised its a different size lol
yen_powell
PostPosted: 12:23 - 30 Mar 2016    Post subject: Reply with quote
Yes, mains atmosphere type.
I haven't got a psi reducer wossname so I ran my compressor up to 90psi before trying out the impact wrench on my Versys rear axle nut (27mm nut done up to 80 ft/lbs).
I noticed it didn't move at all, just hammered away, so I switched to the rear axle nut on my Africa Twin (24mm Nylock nut done up to 69 ft/lbs). It did exactly the same for a few seconds, no movement, then it started to slowly undo, then it span off like a good'n.
I decided to have another go on the Versys and this time I noticed that the split pin hole was not aligned anymore so it was actually moving very very very slowly. I decided to just leave it going and it did the same as the AT, after about a count of 5 seconds, very slow movement, then unspun quickly. No damage/edge wear to the nut.
smallfrowne
PostPosted: 12:30 - 30 Mar 2016    Post subject: Reply with quote
Looks like the same thing I got off ebay for about the same price. I desperately needed one to remove the engine mount locknuts on my vfr. It worked, where before all I was doing with my breaker bar was bending the special tool's castellated prongs and camming out.
I was looking at compressors 'cause battery powered ones were hella £££ but then somehow a corded one appeared which offered more meat than (relatively) cheap battery ones and even mid priced air guns. Used it about 4 times now, well worth it.
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
conker
PostPosted: 14:38 - 30 Mar 2016    Post subject: Reply with quote
Aldi are selling an air impact wrench, lidl the mains powered one. I've bought the lidl one, I'e not used it, but is fairly weighty.
How do impact sockets differ from normal ones?
Jmh600
PostPosted: 15:02 - 30 Mar 2016    Post subject: Reply with quote
Impact sockets aren't hardened, so they don't shatter in your face.....
If you wrap insulation tape around a normal socket, it stops it happening... As in, when they do break, they stay in the tape
Joe
Jmhmotorcycles
PostPosted: 15:55 - 30 Mar 2016    Post subject: Reply with quote
320nm isn't too bad for the price/450w.
While we're on the subject, if you're after something a bit more portable, these are worth considering:
https://www.amazon.co.uk/Liftmaster-Impact-Digital-Display-Configuration/dp/B0036YHBMM
(I've got a similar, though different brand one.)
They work by spinning up a flywheel which engages at an appropriate rpm for the torque set.
A lot slower than mains/battery/electric ones, but run from most 12v batteries and at 'only' 70w, should work fine from a bike too.
Takes a while, but got my wheels off nicely enough after they'd been put on at a tyre place.
DRZ4Hunned
PostPosted: 17:00 - 30 Mar 2016    Post subject: Reply with quote
To those of you in doubt as to whether they're any good (like I was), here's proof that it can get a stubborn sprocket nut off. Cheers for the tape on the socket tip Thumbs Up
https://i.imgur.com/njvXtsL.jpg
DRZ400-SM
FZS600
t121anf
PostPosted: 17:50 - 30 Mar 2016    Post subject: Reply with quote
Bought one cos a man needs tools.
Loads still in Lidl, Sunderland on Durham Road (A690)
R1stu
Shrek!
PostPosted: 19:27 - 30 Mar 2016    Post subject: Reply with quote
I brought the Clarke one a while ago, this looks similar spec so should be great. Also notice Audi has Bluetooth headset £40
https://www.aldi.co.uk/motorbike-bluetooth-headset/p/068426020842400
Any good ?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
PostPosted: 19:37 - 30 Mar 2016    Post subject: Reply with quote
If it's the 1000w clarke one - then over twice the power and 1/3rd more torque I think.
DrSnoosnoo
PostPosted: 09:25 - 31 Mar 2016    Post subject: Reply with quote
Good news. Did it happen quickly enough or did you still have to try penetrating oil soaking etc? Karma
DRZ4Hunned
PostPosted: 11:42 - 31 Mar 2016    Post subject: Reply with quote
I firstly heated it with a gas torch just in case it was loctited on, then I tried my 3' breaker bar as I was a bit skeptical about using a non impact-socket, that didn't work so I had to resort to the impact wrench.
First blast didn't seem to do anything about from make a horrible noise as though it had cracked, checked it, all ok. Second blast for a bit longer made a similar noise but this time it flew off Very Happy So definitely a worthwhile investment.
DRZ400-SM
FZS600
2 litre
PostPosted: 21:51 - 31 Mar 2016    Post subject: Reply with quote
Disconnect the strut from the bottom hub, pull it outwards (out of the arch) it nips the shocker thread so you can undo the bolt without using anything else.
The last post was made 10 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 130.14 Kb
