bump starting
highland biker
PostPosted: 14:26 - 26 Mar 2016    Post subject: bump starting Reply with quote
Probably a noob question but how successful will i be at bump starting my 4xv after its been sat in a shed for 5 months without any sort of trickle charger?
done it before on previous bikes but they had only been sat for a week max
past: klx 250, cbr125, SRAD 600, cbr600rr
present: uber practial r1 for the daily commute
M.C
PostPosted: 14:37 - 26 Mar 2016    Post subject: Reply with quote
It'll bump start, depends whether or not the battery's f**ked.
PostPosted: 15:19 - 26 Mar 2016    Post subject: Reply with quote
Oops, I read that as 4x4 and reflexively Off Topic'd. My bad. Embarassed [frantically Thumbs Up rates other posts]
Carbed, right? It should bump, although I'd prefer to roll it downhill or have someone else push it rather than try to jump aboard. A charger or jumper cables are cheaper than replacing fairings.
But do you reckon the battery is dead? Workmate leaves his Bandit outside over winter and it fires on the button every spring. It's like a cockroach, it just won't die.
The Tot
PostPosted: 15:24 - 26 Mar 2016    Post subject: Reply with quote
Have you got access to a multimeter? I've managed to bump start my 4C8 when it was reading 11.8V across the terminals. Horn would still sound loudly but wouldn't crank up. Wouldn't hurt to give it a try, but a small decline would help you get to 10mph.
Never argue with autism
M.C
PostPosted: 15:29 - 26 Mar 2016    Post subject: Reply with quote
Took 3 attempts on a fairly steep hill to get my MT-03 going, then the battery wouldn't hold a charge (although it had been sat for ages). Honestly I'd just take the battery off & try charging it/get a new one if you need to. Bump starting a bike's dodgy, people have killed themselves doing it Confused
Tdibs
PostPosted: 15:42 - 26 Mar 2016    Post subject: Reply with quote
Cheaper to get a multimeter and a charger than drop that imo.
PostPosted: 16:08 - 26 Mar 2016    Post subject: Reply with quote
Might as well try bumping. Just find a friend or a hill. Thumbs Up
The Tot
PostPosted: 20:34 - 26 Mar 2016    Post subject: Reply with quote
I was going to say, as with the above
Arrow Make sure you have your choke on. I was kicking myself when my XR125 would fire up after 2 attempts on a hill. Then flicked the choke on and it fired into life Rolling Eyes Wink
Arrow Use 2nd gear instead of 1st. Less likely to lock the back wheel up when you disengage your clutch.
Arrow Compared to singles and twins, IL4s don't have serious amounts of compression that would make it difficult to bump, so M.C. that would be why your bike took 3 attempts (battery condition permitting).
SQL
PostPosted: 20:48 - 26 Mar 2016    Post subject: Reply with quote
the mt was a prick to bump, easier in third then clutch in and keep the revs up
Wonko The Sane
PostPosted: 21:12 - 26 Mar 2016    Post subject: Reply with quote
I had to bump start the ZZR with a load of luggage tied down to the pillion seat and it won't go into 2nd when stood.
Running along with it, dropping the clutch but ready to grab it again did the job quite easily, but I was re-starting after fuel so the bike was warm which probably helped.
I wouldn't try jumping aboard
Piercee100
PostPosted: 09:21 - 27 Mar 2016    Post subject: Reply with quote
I was helping a young lad at work try and bump start his Triumph one day after he left his lights on. Nearly killed me, an hour of pushing it round our yard. The combination of a fuel pump that wouldn't prime and an immobiliser that wouldn't deactivate was a real pain. Ended up pushing it out to the road, cutting the power lead off an old tv to fashion some jump leads and then jumping from my wife's chinky scooter.
Started first try with a jump. Got something you can jump it off?
Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition).
MCN
PostPosted: 12:13 - 27 Mar 2016    Post subject: Reply with quote
If the battery has enough Volts it will bump.
(If the fuel system and get the correct amount of fuel to the combustion space.)
5 months is not critical to a good battery. But may be bad if the battery is/was in poor condition prior to storing the beast.
You can only fail or win.
The last post was made 9 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 77.58 Kb
